查看: 3706|回复: 3
STM32F407ZGT6多路PWM控制舵机源程序
ID:817595 发表于 2020-9-22 09:43 | 显示全部楼层 |阅读模式
TIME4控制4路PWM  C程序
#include "pwm1.h"
#include "led.h"
//TIM4 PWM部分初始化
//PWM输出初始化
//arr:自动重装值
//psc:时钟预分频数
//定时器3中断服务程序
void TIM4_IRQHandler(void)   //TIM4中断
        if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)  //检查TIM4更新中断发生与否
                TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );  //清除TIMx更新中断标志
                LED1=!LED1;
void TIM4_PWM_Init(u32 arr,u32 psc)
        //此部分需手动修改IO口设置
        GPIO_InitTypeDef GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
//  NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);          //TIM4时钟使能
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);         //使能PORTC时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;           //GPIOB6
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;        //复用功能
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;        //速度100MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;      //推挽复用输出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;        //上拉
        GPIO_Init(GPIOB,&GPIO_InitStructure);              //初始化PC6
//设置该引脚为复用输出功能,输出TIM4 CH1的PWM脉冲波形GPIOB.6
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_TIM4); //GPIOB6复用为定时器3
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_TIM4);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource8,GPIO_AF_TIM4);
  GPIO_PinAFConfig(GPIOB,GPIO_PinSource9,GPIO_AF_TIM4);
        TIM_TimeBaseStructure.TIM_Prescaler=psc;  //定时器分频
        TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
        TIM_TimeBaseStructure.TIM_Period=arr;   //自动重装载值
        TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);//初始化定时器3
        //初始化TIM4 Channel PWM模式
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性:TIM输出比较极性低
        TIM_OC1Init(TIM4, &TIM_OCInitStructure);  //根据T指定的参数初始化外设TIM4OC1
        TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);  //使能TIM4在CCR1上的预装载寄存器
  TIM_OC2Init(TIM4, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_OC3Init(TIM4, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_OC4Init(TIM4, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4,ENABLE);//ARPE使能
        TIM_Cmd(TIM4, ENABLE);  //使能TIM4
全部程序51hei下载地址:
PWM -20200919.7z (345.67 KB, 下载次数: 105)
ID:456557 发表于 2020-9-25 16:03 | 显示全部楼层
有用,谢谢楼主,tim4 终于能输出pwm波了
ID:340398 发表于 2020-11-22 10:07 | 显示全部楼层
编译有一个致命错误
ID:827663 发表于 2020-12-4 18:08 | 显示全部楼层
请问有没有高级定时器
