查看: 1884|回复: 0
求帮助:用HC-SR04测距让后用LCD1602显示,为什么显示错误
ID:761375 发表于 2020-9-22 16:26 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define LCD_DATA P0
sbit LCD_E=P2^7;
sbit LCD_RW=P2^5;
sbit LCD_RS=P2^6;
sbit led = P2^0;
sbit led1 = P2^1;
sbit led2 = P2^2;
sbit key = P3^1;
sbit trg = P1^2;           //超声波模块控制端
sbit ech = P1^3;           //超声波模块接收端
unsigned char i;
unsigned char flag = 0;
unsigned int count = 0;           //超声波模块时间变量
unsigned long dis;   //超声波测量的距离
unsigned char num[10] = "0123456789";
unsigned char thousend,hundred,ten,unit;
延时函数delay延时 1ms入口参数  c
void delay(unsigned int c)
    unsigned char a,b;
        for (c; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
/****10us延时****/
void Delay10us()                //@12.000MHz
        unsigned char i;
        _nop_();
        _nop_();
        i = 27;
        while (--i);
void Lcd_Write_Cmd(unsigned int cmd)
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_DATA = cmd;
        delay(5);
        LCD_E = 1;
        LCD_E = 0;
void Lcd_Write_Dat(unsigned char dat)
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_DATA = dat;
        delay(5);
        LCD_E = 1;
        LCD_E = 0;
void Lcd_Init()
        Lcd_Write_Cmd(0x38);
        Lcd_Write_Cmd(0x0f);
        Lcd_Write_Cmd(0x06);
        Lcd_Write_Cmd(0x01);
/****定时器初始化****/
void T0_T1_Int0_Init()
        TMOD = 0x11;     //配置定时器工作模式及方式寄存器(TCON为定时器控制寄存器)
        TH0 = (65535 - 5000) / 256;
        TL0 = (65535 - 5000) % 256;
        TH1 = 0;                 //为定时器1设初值
        TL1 = 0;                 //高八位与低八位均为0
        EA = 1;                         //开放总中断
        ET1 = 1;                 //开放定时器1中断
        ET0 = 1;
void T0_ser() interrupt 1
        unsigned char n;
        n++;
        if(n >= 16)
                n = 0;
                trg = 1;                                   //向控制端
                Delay10us();                           //提供
                Delay10us();                          //20us
                trg = 0;
                led = ~led;
void T1_ser() interrupt 3
        TH1 = 0;
        TL1 = 0;
void Distance()
        while(!ech);
        TR1 = 1;
        while(ech);
        TR1 = 0;
void Dis_Count()
        count = TH1 * 256 + TL1;
        dis = (long)(count * 0.017); //计算小车到障碍物的距离(cm)
        thousend = dis / 1000;
        hundred = dis % 1000 / 100;
        ten = dis % 100 / 10;
        unit = dis % 10;
        Lcd_Init();
        T0_T1_Int0_Init();
        Lcd_Write_Cmd(0x80);
        TR0 = 1;
                Distance();
                Dis_Count();
                Lcd_Write_Dat(num[thousend]);
                delay(1);
                Lcd_Write_Dat(num[hundred]);
                delay(1);
                Lcd_Write_Dat(num[ten]);
                delay(1);
                Lcd_Write_Dat(num[unit]);
                delay(100);
                if(dis < 50)
                        led2 = 0;
                if(dis > 50)
                        led2 = 1;
LCD1602显示的数字一直再增加
不知道哪里出了问题
