查看: 4193|回复: 2
51单片机12864显示汉字源程序
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add         0xb8
#define LCDCol_Add       0x40
#define Start_Line       0xC0
#define data_ora P0
sbit LCD_CS1=P2^4 ;
sbit LCD_CS2=P2^3 ;
sbit RESET=P2^3 ;
sbit LCDDi=P2^2 ;
sbit LCDRW=P2^1 ;
sbit LCDEnable=P2^0 ;
char code Hz_sun[]=
0x0 ,0x2 ,0x82 ,0x82, 0xF2, 0x4A, 0x26, 0x80 ,0x60, 0x0 ,0xFF, 0x20 ,0x40 ,0x80 ,0x0 ,
        0x0 ,0x1, 0x1 ,0x40, 0x80, 0x7F ,0x4 ,0x2 ,0x1 ,0x40, 0x80, 0x7F, 0x0 ,0x0 ,0x1 ,0x3 ,0x0
char code Hz_wen[]=
0x8, 0x8 ,0x8, 0x18, 0x68, 0x88, 0x9, 0xE ,0x8, 0x8 ,0xC8, 0x38, 0x8 ,0xC, 0x8 ,0x0, 0x80,
        0x80 ,0x40, 0x40, 0x20, 0x11, 0xA ,0x4, 0xA ,0x11 ,0x10, 0x20, 0x40, 0xC0, 0x40, 0x0
char code Hz_chao[]=
0x40, 0x48, 0x48, 0xFF ,0x48 ,0x48, 0x82 ,0x42, 0x3E, 0x2 ,0x22, 0x42, 0x3F ,0x2, 0x0, 0x0 ,0x40,
        0x3F ,0x10, 0x1F ,0x22 ,0x42, 0x40, 0x5F, 0x51, 0x51 ,0x51, 0x51 ,0x5F, 0x60, 0x20, 0x0
char code Hz_zhen[]=
0x0 ,0x4, 0x4, 0xF4, 0x54 ,0x54, 0x54, 0x5F ,0x54 ,0x54 ,0x54, 0xFC, 0x16 ,0x4, 0x0, 0x0, 0x10 ,0x10 ,
        0x90 ,0x5F, 0x35 ,0x15, 0x15, 0x15 ,0x15 ,0x15, 0x35 ,0x5F, 0xD0, 0x18, 0x10, 0x0
char code Hz_shuai[]=
0x0 ,0xFC ,0x0, 0x0, 0xFF, 0x0 ,0x0, 0xF8 ,0x8, 0x8, 0xFF, 0x8, 0x8, 0xFC ,0x8, 0x0, 0x0 ,0x87, 0x40,
        0x30 ,0xF, 0x0, 0x0, 0x3F ,0x0 ,0x0 ,0xFF, 0x10 ,0x20, 0x1F, 0x0 ,0x0
char code Hz_te[]=
0x20 ,0x1C ,0x10 ,0xFF, 0x90, 0x50, 0x48, 0x48, 0x48, 0x7F ,0x48 ,0xC8, 0x4C, 0x68, 0x40, 0x0, 0x2,
        0x2 ,0x1, 0xFF, 0x0, 0x2 ,0x2 ,0x6 ,0x1A ,0x42, 0x82 ,0x7F, 0x2 ,0x3 ,0x2 ,0x0
char code Hz_mo[]=
0x0 ,0x4 ,0x4, 0xE4 ,0xA4 ,0xBF, 0xA4 ,0xA4, 0xA4, 0xBF, 0xA4 ,0xF4, 0x26 ,0x4 ,0x0 ,0x0 ,0x8 ,
        0x88 ,0x88 ,0x8B, 0x4A ,0x4A ,0x2A ,0x1E, 0x2A, 0x4A, 0x4A, 0x8B ,0x88, 0x8C, 0x8, 0x0
char code Hz_a[]=
0xFC ,0x4 ,0xFE ,0x4, 0xFE ,0x42, 0xB2 ,0xE, 0x0, 0xE2 ,0x22 ,0xF2, 0x22, 0xFF, 0x2, 0x0 ,0xF ,
        0x4 ,0xF ,0x0 ,0xFF ,0x8 ,0x11 ,0xE,0x0, 0xF, 0x4 ,0x4F, 0x80 ,0xFF ,0x0, 0x0
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
void CheckState()
   unsigned char dat,DATA;
   LCDDi=0;
   LCDRW=1;
   do
      DATA=0x00;
      LCDEnable=1;
          LCDdelay(2);
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat;
    while(dat!=0x00);
void write_com(unsigned char cmdcode)
    CheckState();
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void write_data(unsigned char LCDDispdata)
    CheckState();
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void Clr_Scr()
        unsigned char j,k;
        LCD_CS1=0;
        LCD_CS2=0;
         write_com(Page_Add+0);
         write_com(LCDCol_Add+0);
         for(k=0;k<8;k++)
                write_com(Page_Add+k);
                  for(j=0;j<64;j++)
                      write_com(LCDCol_Add+j);
                        write_data(0x00);
void hz_LCDDisp16(unsigned char page,unsigned char column, unsigned char code *hzk)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<16;i++)
                        write_data(hzk[16*j+i]);
void init_lcd()
        LCDdelay(100);
        LCD_CS1=1;
        LCD_CS2=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);
        write_com(Start_Line+0);
        write_com(LCDLCDDisp_On);
全部资料51hei下载地址:
1.rar (446.7 KB, 下载次数: 63)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:830257 发表于 2020-11-24 19:01 | 只看该作者
怎么修改字哟
ID:867005 发表于 2021-5-6 16:58 | 只看该作者
生成字模,然后替换取模函数里的汉字内容
