查看: 3397|回复: 0
51单片机12864静态显示
ID:747099 发表于 2020-10-6 16:52 | 显示全部楼层 |阅读模式
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add         0xb8
#define LCDCol_Add       0x40
#define Start_Line       0xC0
#define data_ora P0
sbit LCD_CS1=P2^4 ;
sbit LCD_CS2=P2^3 ;
sbit RESET=P2^3 ;
sbit LCDDi=P2^2 ;
sbit LCDRW=P2^1 ;
sbit LCDEnable=P2^0 ;
sbit k1=P3^1;
sbit k2=P3^3;
sbit k3=P3^5;
char code Hz_sun[]=
0x0 ,0x2 ,0x82 ,0x82, 0xF2, 0x4A, 0x26, 0x80 ,0x60, 0x0 ,0xFF, 0x20 ,0x40 ,0x80 ,0x0 ,
        0x0 ,0x1, 0x1 ,0x40, 0x80, 0x7F ,0x4 ,0x2 ,0x1 ,0x40, 0x80, 0x7F, 0x0 ,0x0 ,0x1 ,0x3 ,0x0
char code Hz_wen[]=
0x8, 0x8 ,0x8, 0x18, 0x68, 0x88, 0x9, 0xE ,0x8, 0x8 ,0xC8, 0x38, 0x8 ,0xC, 0x8 ,0x0, 0x80,
        0x80 ,0x40, 0x40, 0x20, 0x11, 0xA ,0x4, 0xA ,0x11 ,0x10, 0x20, 0x40, 0xC0, 0x40, 0x0
char code Hz_chao[]=
0x40, 0x48, 0x48, 0xFF ,0x48 ,0x48, 0x82 ,0x42, 0x3E, 0x2 ,0x22, 0x42, 0x3F ,0x2, 0x0, 0x0 ,0x40,
        0x3F ,0x10, 0x1F ,0x22 ,0x42, 0x40, 0x5F, 0x51, 0x51 ,0x51, 0x51 ,0x5F, 0x60, 0x20, 0x0
char code Hz_xing[]=
0x10, 0x10, 0xF0 ,0x1F ,0x10 ,0xF0 ,0x40, 0x3C ,0x10, 0x10, 0xFF ,0x10, 0x10, 0x18, 0x10 ,
        0x0 ,0x40, 0x22 ,0x15, 0x8 ,0x14, 0x63, 0x40 ,0x42 ,0x42 ,0x42, 0x7F, 0x42 ,0x43, 0x62, 0x40 ,0x0
char code Hz_ming[]=
0x0 ,0x0, 0x0, 0x20 ,0x10 ,0x9C ,0xA7 ,0x44 ,0x44, 0x24, 0x14,0xC, 0x0, 0x0, 0x0, 0x0 ,
        0x2 ,0x2,0x2 ,0x1, 0xFF ,0x42 ,0x42, 0x42, 0x42, 0x42, 0x42 ,0x42, 0xFF ,0x2, 0x0 ,0x0
char code Hz_dian[]=
0x0 ,0x0 ,0x0 ,0x0, 0x80, 0xC0 ,0xC0 ,0x80, 0x0 ,0x0 ,0x0, 0x0 ,0x0 ,0x0, 0x0, 0x0 ,0x0, 0x0, 0x0, 0x0,
        0x31 ,0x7B, 0x7B, 0x31, 0x0 ,0x0 ,0x0, 0x0 ,0x0, 0x0 ,0x0 ,0x0
char code Hz_xing1[]=
0x80 ,0x70 ,0x0, 0xFF, 0x90 ,0x60 ,0x1C, 0x10 ,0x10, 0xFF ,0x10, 0x10, 0x18 ,0x10, 0x0 ,0x0 ,0x0, 0x0 ,
        0x0, 0xFF, 0x40, 0x40, 0x42 ,0x42, 0x42 ,0x7F, 0x42 ,0x43, 0x42 ,0x60 ,0x40 ,0x0
char code Hz_bie[]=
0x0, 0x0 ,0x7E ,0x22 ,0xE2 ,0x22 ,0x22, 0xBF, 0x2 ,0x0 ,0xF8 ,0x0 ,0x0, 0xFF, 0x0, 0x0, 0x1 ,0x41,
        0x21 ,0x19 ,0x7 ,0x21 ,0x41 ,0x3F ,0x1 ,0x0,0xF, 0x40 ,0x80 ,0x7F ,0x0 ,0x0
char code Hz_nan[]=
0x0 ,0x0 ,0xFE ,0x92 ,0x92 ,0x92 ,0x92 ,0xFE ,0x92 ,0x92 ,0x92 ,0x92 ,0xFF ,0x2, 0x0, 0x0, 0x4,
        0x84, 0x85, 0x44 ,0x44 ,0x24 ,0x1C ,0x7 ,0x4 ,0x4, 0x44, 0x84, 0x44, 0x3E ,0x4 ,0x0
char code Hz_nian[]=
0x0, 0x20, 0x10, 0xCC ,0x47 ,0x44 ,0x44 ,0xFC ,0x44, 0x44, 0x44, 0x64 ,0x46 ,0x4, 0x0 ,
        0x0, 0x4 ,0x4, 0x4 ,0x7 ,0x4 ,0x4 ,0x4 ,0xFF ,0x4 ,0x4 ,0x4 ,0x4 ,0x4, 0x6, 0x4, 0x0
char code Hz_ling[]=
0x40 ,0x40,0x7E, 0x40, 0x7F, 0x48, 0x48, 0x68,0x10, 0x2C ,0xC3 ,0xC, 0x30 ,0x60 ,0x20, 0x0,
        0x0 ,0xFF ,0x50 ,0x48 ,0x47 ,0x48, 0x50, 0xFF, 0x2, 0x12, 0x22 ,0xD2 ,0xA, 0x6, 0x0, 0x0
char code Hz_2[]=
0x0 ,0x0 ,0x20, 0x70 ,0x78, 0x8, 0x8, 0x8, 0x8, 0x8, 0x8, 0xD8, 0xF0, 0x70, 0x0, 0x0 ,0x0, 0x0 ,
        0x30 ,0x30, 0x28,0x28, 0x24, 0x24 ,0x22, 0x22, 0x21 ,0x21 ,0x30 ,0x38, 0x0, 0x0
char code Hz_0[]=
0x0 ,0x0 ,0xC0 ,0xE0, 0xF0 ,0x18, 0x8, 0x8 ,0x8 ,0x8, 0x8 ,0x30 ,0xF0, 0xE0, 0xC0, 0x0, 0x0, 0x0 ,0x7,
        0x1F ,0x1F ,0x30 ,0x20 ,0x20, 0x20 ,0x20, 0x20 ,0x38 ,0x1F ,0xF ,0x7 ,0x0
char code Hz_you[]=
0x40, 0x20, 0xF8, 0x27, 0x20, 0x20 ,0x20, 0xE0, 0x3F, 0xE0 ,0x22 ,0x2C ,0x20, 0x30, 0x20, 0x0, 0x0 ,0x0,
        0xFF, 0x80, 0x40, 0x30, 0xE, 0x1, 0x0 ,0x3F, 0x40, 0x40, 0x40 ,0x40 ,0x70, 0x0
char code Hz_dian1[]=
0x0 ,0x0 ,0xC0,0x40, 0x40 ,0x40 ,0x7F ,0x48, 0x48, 0x48 ,0x48, 0xE8, 0x4C, 0x8,0x0 ,0x0, 0x80, 0x40, 0x37,
        0x4 ,0x14, 0x64 ,0x4 ,0x14 ,0x24 ,0x64 ,0x4 ,0x17, 0x20, 0xC0 ,0x0, 0x0
char code Hz_quan[]=
0x80, 0x80 ,0x40, 0x20, 0x50, 0x48 ,0x44 ,0xC3 ,0x44,0x68, 0x50, 0x20, 0x40, 0xC0, 0x40, 0x0, 0x0, 0x40,
        0x40,0x40,0x44 ,0x44, 0x44 ,0x7F ,0x44, 0x46,0x44 ,0x40 ,0x60, 0x40, 0x0, 0x0
char code Hz_shi[]=
0x0 ,0x0 ,0x0 ,0x0, 0x7F ,0x49 ,0x49, 0x49, 0x49,0x49, 0x7F, 0x0, 0x0,0x80 ,0x0, 0x0, 0x1, 0x81, 0x41 ,0x21 ,
        0x1D ,0x21, 0x41, 0x7F, 0x89 ,0x89 ,0x8D, 0x89, 0x81, 0xC1 ,0x41, 0x0
char code Hz_de[]=
0x40, 0x20 ,0x10, 0x8C ,0x63 ,0x80, 0xBE ,0xAA, 0xAA ,0xAA ,0xAA, 0xAA, 0xBF ,0x82, 0x0, 0x0, 0x4, 0x2 ,0x1,
        0xFF ,0x4 ,0x4 ,0xC, 0x34, 0x4, 0x44, 0x84 ,0x7F ,0x4 ,0x6, 0x4, 0x0
char code Hz_cai[]=
0x0 ,0xFE,0x2 ,0xFA ,0x2, 0xFF, 0x12 ,0x10, 0x10, 0x10, 0xD0 ,0xFF, 0x10,0x18, 0x10 ,0x0 ,0x40, 0x27 ,0x18 ,
        0x7 ,0x8 ,0x37 ,0x8 ,0x4 ,0x2 ,0x41 ,0x80, 0x7F, 0x0, 0x0 ,0x0 ,0x0
char code Hz_fu[]=
0x10, 0xC ,0x4 ,0xD4 ,0x54 ,0x54 ,0x55 ,0x56, 0x54, 0x54 ,0x5C, 0xD4,0x4 ,0x14, 0xC ,0x0 ,0x0, 0x0 ,0xFC, 0x55,
        0x55 ,0x55, 0x55 ,0x7D, 0x55, 0x55 ,0x55, 0x55, 0xFE, 0x4 ,0x0 ,0x0
char code Hz_zhi[]=
0x80 ,0x40, 0x20, 0xF8, 0x7, 0x4, 0xE4, 0xA4 ,0xA4 ,0xBF, 0xA4, 0xA4, 0xF6, 0x24, 0x0 ,0x0, 0x0, 0x0, 0x0 ,0xFF ,
        0x40 ,0x40, 0x7F, 0x4A, 0x4A, 0x4A, 0x4A, 0x4A, 0x7F, 0x40 ,0x40, 0x0
char code Hz_tanhao[]=
0x0 ,0x0, 0x0 ,0x0, 0x0 ,0x0 ,0x7C ,0xFE ,0xFE, 0x7C, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 ,0x0 ,0x0 ,0x0 ,0x0, 0x0 ,0x0,
        0x10 ,0x3B, 0x3B, 0x10 ,0x0, 0x0 ,0x0 ,0x0, 0x0, 0x0
char code Hz_yu[]=
0x80, 0x80, 0x40, 0x20, 0x50, 0x48 ,0x44 ,0xC3, 0x44, 0x48 ,0x50, 0x20,0x40, 0xC0 ,0x40, 0x0 ,0x0 ,0x40, 0x22, 0x12 ,
        0x1A, 0x42, 0x82 ,0x7F, 0x2, 0x2, 0xA ,0x13, 0x32 ,0x60 ,0x0, 0x0
char code Hz_e[]=
0x10, 0x8C, 0x44, 0xB5,0x26 ,0xA4, 0x74, 0xC,0x2, 0xF2 ,0x1A ,0xD6, 0x12, 0xFB, 0x12, 0x0 ,0x10 ,0x8, 0xFC ,0x4A ,
        0x49 ,0x4A, 0x7C ,0x8 ,0x80 ,0x4F, 0x20, 0x1F, 0x20 ,0x4F, 0xC0, 0x0
char code Hz_w[]=
0x0 ,0x80 ,0x80, 0x80 ,0x0, 0x0 ,0x0 ,0x80 ,0x80, 0x80, 0x0, 0x0, 0x0 ,0x80, 0x80, 0x0, 0x0, 0x0 ,0x1 ,0x7, 0x1E,
        0x38, 0x1C, 0x7, 0x3 ,0xF ,0x3C, 0x38, 0xE ,0x3, 0x0 ,0x0
char code Hz_1[]=
0x0, 0x0 ,0x0 ,0x0, 0x10, 0x10, 0x10, 0xF0, 0xF8 ,0xF8, 0x0, 0x0 ,0x0, 0x0 ,0x0 ,0x0 ,0x0, 0x0, 0x0 ,0x0 ,0x20 ,
        0x20, 0x20, 0x3F ,0x3F, 0x3F, 0x20, 0x20 ,0x20, 0x0 ,0x0, 0x0
char code Hz_8[]=
0x0 ,0x0 ,0x60, 0x70 ,0xD8, 0x88, 0x88, 0x88, 0x88 ,0x8, 0x88, 0x88, 0xF0 ,0x70, 0x0 ,0x0 ,0x0, 0x8, 0x1C, 0x1E,
        0x23 ,0x21 ,0x21, 0x21 ,0x21 ,0x21 ,0x23, 0x23 ,0x1E ,0x1C ,0x8 ,0x0
char code Hz_3[]=
0x0, 0x0 ,0x20, 0x30, 0x38, 0x0 ,0x8 ,0x8, 0x8 ,0x88, 0x88, 0xF8, 0x70 ,0x20, 0x0, 0x0 ,0x0 ,0x0, 0x18, 0x18 ,
        0x38 ,0x20, 0x20, 0x21, 0x21, 0x21, 0x21 ,0x33 ,0x1E ,0x1E, 0x0, 0x0
char code Hz_4[]=
0x0 ,0x0 ,0x0 ,0x0, 0x0 ,0x80, 0x40 ,0x20 ,0x20 ,0xF0, 0xF8, 0xF8 ,0x0, 0x0, 0x0 ,0x0, 0x0, 0x0 ,0x6, 0x2,
        0x1 ,0x0, 0x0 ,0x20, 0x20 ,0x3F ,0x3F, 0x3F ,0x20 ,0x20 ,0x20, 0x0
char code Hz_5[]=
0x0, 0x0 ,0x0 ,0xF8, 0xF8, 0x88 ,0x88, 0x88 ,0x88 ,0x88, 0x88, 0x88, 0x8 ,0x8 ,0x0 ,0x0, 0x0, 0x0, 0x18, 0x19,
        0x39 ,0x20 ,0x20, 0x20, 0x20, 0x20, 0x20, 0x31, 0x1F, 0xF ,0x4 ,0x0
char code Hz_6[]=
0x0 ,0x0, 0xC0, 0xE0, 0xF0, 0x10,0x88 ,0x88, 0x88 ,0x88 ,0x88 ,0x98 ,0x98, 0x10 ,0x0 ,0x0, 0x0 ,0x0 ,0xF, 0x1F,
        0x1F, 0x31, 0x20, 0x20, 0x20, 0x20, 0x20, 0x21 ,0x1F ,0x1F, 0xE ,0x0
char code Hz_7[]=
0x0 ,0x0, 0x20, 0x38, 0x18, 0x8 ,0x8, 0x8, 0x8 ,0x88, 0xC8, 0x28 ,0x18, 0x18, 0x8 ,0x0 ,0x0 ,0x0 ,0x0, 0x0, 0x0 ,0x0 ,
        0x3C ,0x3E ,0x3F, 0x1 ,0x0,0x0 ,0x0, 0x0, 0x0, 0x0
char code Hz_tu[]=
0x0 ,0x0 ,0x0, 0x78, 0x84 ,0x64 ,0xF4 ,0xE8 ,0xE8 ,0xF4,0x64 ,0x84, 0x78, 0x0 ,0x0, 0x0, 0x0, 0x0,
        0x0 ,0x0, 0x0, 0x1 ,0x2, 0x5 ,0x5, 0x2, 0x1 ,0x0 ,0x0 ,0x0 ,0x0, 0x0
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
void CheckState()
   unsigned char dat,DATA;
   LCDDi=0;
   LCDRW=1;
   do
      DATA=0x00;
      LCDEnable=1;
          LCDdelay(2);
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat;
    while(dat!=0x00);
void write_com(unsigned char cmdcode)
    CheckState();
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void write_data(unsigned char LCDDispdata)
    CheckState();
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void Clr_Scr()
        unsigned char j,k;
        LCD_CS1=0;
        LCD_CS2=0;
        write_com(Page_Add+0);
        write_com(LCDCol_Add+0);
        for(k=0;k<8;k++)
                write_com(Page_Add+k);
                  for(j=0;j<64;j++)
                      write_com(LCDCol_Add+j);
                        write_data(0x00);
void hz_LCDDisp16(unsigned char page,unsigned char column, unsigned char code *hzk)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<16;i++)
                        write_data(hzk[16*j+i]);
void init_lcd()
        LCDdelay(100);
        LCD_CS1=1;
        LCD_CS2=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);
        write_com(Start_Line+0);
        write_com(LCDLCDDisp_On);
2.rar
55.53 KB, 下载次数: 19, 下载积分: 黑币 -5
