查看: 1916|回复: 0
单片机舵机控制程序
ID:825404 发表于 2020-10-9 09:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  2. typedef unsigned char u8;
  3. typedef unsigned int u16;
  4. sbit PWM_OUT=P0^0;                                        //PWM输出口
  5. u16 PWM_Value;                                                //定义pwm值
  6. u8 order=0;
  7. void Delay(unsigned int s);              //延时函数声明
  8. u8 flag;
  9.                                                         //舵机按键标志
  10. void Delay(unsigned int s)
  11. {
  12. unsigned int i;
  13. for(i=0; i<s; i++);
  14. for(i=0; i<s; i++);
  15. }
  16. /*定时器初始化*/
  17. void Init_Timer0()
  18. {
  19. TMOD=0x11;
  20. TH1=(65536-1500)/256;
  21. TL1=(65536-1500)%256;
  22. EA = 1;
  23. ET1= 1;
  24. TR1 = 1;
  25. PT1=1;
  26. }
  27. /*主函数*/
  28. void main(void)
  29. {
  30.
  31.         Delay(6000);
  32.         PWM_Value =101;
  33.                                                 //pwm初值为1500
  34.         Init_Timer0();
  35.         while(1)
  36.         {
  37.                 PWM_Value += 10;
  38.                 Delay(1000);
  39.
  40.                 //PWM_Value -= 1;
  41.                 //Delay(1000);
  42.         }
  43. }
  44.    /*****中断程序*******/
  45. void timer0(void) interrupt 3
  46. {
  47.
  48.         if(PWM_Value>=2500)        //如果pwm的值大于2500
  49.         PWM_Value = 2500;        //则保持在2500
  50.         if(PWM_Value<=100)        //如果pwm的值小于500
  51.         PWM_Value=500;        //则保持在500
  52.         switch(order)
  53.         {
  54.                 case 1:PWM_OUT=1;
  55.                            TH1=(65536-PWM_Value)>>8;
  56.                            TL1=(u8)(65536-PWM_Value);
  57.                            break;
  58.                 case 2:PWM_OUT=0;
  59.                            TH1=(65536-(5000-PWM_Value))>>8;
  60.                            TL1=(u8)(65536-(5000-PWM_Value));
  61.                            break;
  62.                 case 3:
  63.                            TH1=60536>>8;
  64.                            TL1=(u8)60536;
  65.                            break;
  66.                 case 4:
  67.                            TH1=60536>>8;
  68.                            TL1=(u8)60536;
  69.                            order=0;
  70.                            break;
  71.         default: order=0;
  72.                            break;
  73.         }
  74.           order++;
  75. }
舵机.zip
30.78 KB, 下载次数: 16, 下载积分: 黑币 -5
