查看: 3290|回复: 0
mpu6050体感云台 STM32源程序
ID:828183 发表于 2020-10-12 11:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
视频链接:https://www.bilibili.com/video/BV1kv41117Bc
  1. /*
  2. 引脚定义
  3. MPU6050_PIN:  SCL:PB(10)  SDA:PB(11)
  4. OLED_PIN:     SCL:PA(5)   SDA:PA(4)
  5. ADC_PIN:       CH6:PA(2)   CH7:PA(3)   CH0:PA(0)   CH1:PA(1)
  6. LED_PIN:      LED1:PB(12) LED2:PB(13)
  7. KEY_PIN:      KEY:PA(8)
  8. PWM_PIN:      PA(6) PA(7) PB(0) PB(1)
  9. 作者:B站~保你江山半壁 UID:475029472
  10. 拿了我的的代码还是给个三连吧!
  11. */
  12. #include "oled.h"
  13. #include "delay.h"
  14. #include "sys.h"
  15. #include "usart.h"
  16. #include "mpu6050.h"
  17. #include "inv_mpu.h"
  18. #include "inv_mpu_dmp_motion_driver.h"
  19. #include "adc.h"
  20. #include "led.h"
  21. #include "key.h"
  22. #include "timer.h"
  23. u8 flag=1;
  24. extern u16 ADC_DMA_IN[4]; //声明外部变量
  25. int main(void)
  26. {
  27.   char oledBuf[20];
  28.         float Pitch,Roll,Yaw;                 //欧拉角
  29.   LED_Init();
  30.         KEY_Init();
  31.         TIM3_PWM_Init(1999,719);        //定时器3产生PWM初始化,装载值1999,预分频数719,周期20ms
  32.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  33.         uart_init(115200);                 //串口初始化为115200
  34.         delay_init();        //延时初始化
  35.         ADC_Configuration();//
  36.
  37.         OLED_Init();
  38.         OLED_ColorTurn(0);//0正常显示,1 反色显示
  39.   OLED_DisplayTurn(0);//0正常显示 1 屏幕翻转显示
  40.         OLED_Clear();
  41.
  42.         LED_YON();
  43.
  44.         while(1)
  45.         {
  46.                         if(KEY1 == 0)
  47.                         {
  48.
  49.                                 delay_ms(20);
  50.                                 if(KEY1 == 0)
  51.                                 {
  52.                                         flag=!flag;
  53.                                         LED1 =!LED1;
  54.                                         LED2 =!LED2;
  55.                                         OLED_Clear();
  56.                                         if(flag == 0)
  57.                                         {
  58.                                                         MPU_Init();                                        //初始化MPU6050
  59.                                                         mpu_dmp_init();
  60.                                         }
  61.                                         while(!KEY1);
  62.                                 }
  63.                         }
  64.                         if(flag == 1)
  65.                         {
  66.                                         sprintf(oledBuf,"YAO_GAN");
  67.                                         OLED_ShowString(32,0,(u8*)oledBuf,16);//OLED第一行
  68.                                   sprintf(oledBuf," YG_1  |  YG_2");
  69.                                         OLED_ShowString(0,16,(u8*)oledBuf,16);//OLED第二行
  70.                                         sprintf(oledBuf,"X:%4d | X:%4d",ADC_DMA_IN[0],ADC_DMA_IN[2]);
  71.                                         OLED_ShowString(0,32,(u8*)oledBuf,16);//OLED第三行
  72.                                         sprintf(oledBuf,"Y:%4d | Y:%4d",ADC_DMA_IN[1],ADC_DMA_IN[3]);
  73.                                         OLED_ShowString(0,48,(u8*)oledBuf,16);//OLED第四行
  74.                                         OLED_Refresh();
  75.                                   TIM_SetCompare1(TIM3,(int)((ADC_DMA_IN[0]*1000)/20475+50));
  76.                                   TIM_SetCompare2(TIM3,(int)((ADC_DMA_IN[1]*1000)/20475+50));
  77.                                   TIM_SetCompare3(TIM3,(int)((ADC_DMA_IN[2]*1000)/20475+50));
  78.                                   TIM_SetCompare4(TIM3,(int)((ADC_DMA_IN[3]*1000)/20475+50));
  79.                          }//(int)(((float)ADC_DMA_IN[0])/20.475+50)
  80.                         else
  81.                         {
  82. //                                        delay_ms(2);
  83.                                         mpu_dmp_get_data(&Pitch,&Roll,&Yaw);
  84.                                         sprintf(oledBuf,"MPU6050");
  85.                                         OLED_ShowString(32,0,(u8*)oledBuf,16);//OLED第一行
  86.                                         sprintf(oledBuf,"X:%.2f ",Pitch);
  87.                                         OLED_ShowString(0,16,(u8*)oledBuf,16);//OLED第二行
  88.                                         sprintf(oledBuf,"Y:%.2f ",Roll);
  89.                                         OLED_ShowString(0,32,(u8*)oledBuf,16);//OLED第三行
  90.                                         sprintf(oledBuf,"Z:%.2f ",Yaw);
  91.                                         OLED_ShowString(0,48,(u8*)oledBuf,16);//OLED第四 行
  92.                                         OLED_Refresh();
  93.                                   TIM_SetCompare2(TIM3,(int)((Roll+90)*10/9+50));
  94.                                   TIM_SetCompare3(TIM3,(int)((Pitch+90)*10/9+50));
  95.                                         TIM_SetCompare4(TIM3,(int)((Yaw+90)*10/9+50));
  96.                         }
  97.
  98.         }
  99. }
所有代码51hei提供下载:
MPU6050_YG_CONTROL.7z (251.48 KB, 下载次数: 52)
收藏收藏3 分享淘帖 顶顶 踩踩
