查看: 2839|回复: 1
STC8A8K64S4A12单片机同时使用串口1 和 串口2 冲突?
ID:342197 发表于 2020-10-14 09:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题: 求大神解惑,谢谢
程序如下:同时调用 串口1 和 串口2 ,调试结果为 同一时间 只能够 有一个串口 产生作用。为什么?
#include "reg51.h"
#include "intrins.h"
#define FOSC            11059200UL
#define BRT             (65536 - FOSC / 115200 / 4)
sfr     AUXR        =   0x8e;
sfr     T2H         =   0xd6;
sfr     T2L         =   0xd7;
bit busy;
char wptr;
char rptr;
char buffer[16];
void UartIsr() interrupt 4
    if (TI)
        TI = 0;
        busy = 0;
    if (RI)
        RI = 0;
        buffer[wptr++] = SBUF;
        wptr &= 0x0f;
void UartInit()
    SCON = 0x50;
    T2L = BRT;
    T2H = BRT >> 8;
    AUXR = 0x15;
    wptr = 0x00;
    rptr = 0x00;
    busy = 0;
void UartSend(char dat)
    while (busy);
    busy = 1;
    SBUF = dat;
void UartSendStr(char *p)
    while (*p)
        UartSend(*p++);
void Uart2Isr() interrupt 8
    if (S2CON & 0x02)
        S2CON &= ~0x02;
        busy = 0;
    if (S2CON & 0x01)
        S2CON &= ~0x01;
        buffer[wptr++] = S2BUF;
        wptr &= 0x0f;
void Uart2Init()
    S2CON = 0x10;
    T2L = BRT;
    T2H = BRT >> 8;
    AUXR = 0x14;
    wptr = 0x00;
    rptr = 0x00;
    busy = 0;
void Uart2Send(char dat)
    while (busy);
    busy = 1;
    S2BUF = dat;
void Uart2SendStr(char *p)
    while (*p)
        Uart2Send(*p++);
    UartInit();
    ES = 1;
    EA = 1;
    UartSendStr("Uart Test !\r\n");
    while (1)
        if (rptr != wptr)
            UartSend(buffer[rptr++]);
            rptr &= 0x0f;
ID:824481 发表于 2020-10-14 16:17 | 只看该作者
没有清除中断标志位
