查看: 3035|回复: 2
STM32 DHT11串口显示 串行文本输出 波特率115200
ID:302293 发表于 2020-10-22 15:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM32单片机源程序如下:
  1. #include "dht11.h"
  2. #include "stdio.h"
  3. u8 T;
  4. u8 H;
  5. u8 t=0;
  6. int fputc(int ch, FILE *f)
  7. {
  8. /* 将Printf内容发往串口 */
  9.   USART_SendData(USART1, (unsigned char) ch);
  10.   while (!(USART1->SR & USART_FLAG_TXE));
  11.   return (ch);
  12. }
  13. void USART1_init(void)
  14. {
  15.   //GPIO端口设置
  16.   GPIO_InitTypeDef GPIO_InitStructure;
  17.         USART_InitTypeDef USART_InitStructure;
  18.         NVIC_InitTypeDef NVIC_InitStructure;
  19.
  20.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);        //使能USART1,GPIOA时钟
  21.
  22.         //USART1_TX   GPIOA.9
  23.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  24.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  25.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  26.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  27.
  28.   //USART1_RX          GPIOA.10初始化
  29.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
  30.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  31.   GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
  32.   //Usart1 NVIC 配置
  33.     NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  34.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0 ;//抢占优先级0
  35.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;                //子优先级2
  36.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
  37.         NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
  38.
  39.    //USART 初始化设置
  40.         USART_InitStructure.USART_BaudRate = 115200;//串口波特率
  41.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
  42.         USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
  43.         USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
  44.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
  45.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
  46.   USART_Init(USART1, &USART_InitStructure); //初始化串口1
  47.   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
  48.   USART_Cmd(USART1, ENABLE);                    //使能串口1
  49. }
  50. //void gpio()
  51. //{
  52. //    GPIO_InitTypeDef GPIO_InitStructure;
  53. //          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);        //使能USART3,GPIOB时钟
  54. //          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  55. //          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  56. //          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //复用推挽输出
  57. //          GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PB10
  58. //   GPIO_SetBits(GPIOC,GPIO_Pin_13);
  59. //}
  60. int main(void)
  61. {
  62.          USART1_init();
  63. //   gpio();
  64. // DHT11_Rst();
  65.
  66. while(1)
  67.         {
  68.
  69.
  70. if(t%10==0)
  71.          {
  72.
  73.                 DHT11_Read_Data(&T,&H);                //读取温湿度值
  74.                 printf("温度:%d\r\n ",T);
  75.     printf("湿度:%d\r\n ",H);
  76.
  77.
  78.          }
  79.      delay_ms(100);
  80.          t++;
  81. //     printf("湿度:%d\r\n ",1);
  82.         }
  83. }
(程序目前还有问题,不能运行,求大神帮忙修改): 实验0 Template工程模板.7z (177.86 KB, 下载次数: 35)
收藏收藏 分享淘帖 顶1 踩1
ID:379545 发表于 2020-11-16 23:36 | 只看该作者
这个有错误,用的正点原子的库,dht11初始化函数都没写对,没敢贴上来初始化函数。
ID:538722 发表于 2020-12-7 16:51 | 只看该作者
很好用,在DHT11这卡了好久了
