查看: 2231|回复: 3
这个单片机程序怎么样能加快计数到20或者10?
ID:712295 发表于 2020-11-4 10:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <REGX51.H>
#include <math.H>
#define FOSC 12000000L
#define T1MS (65536-FOSC/12/1000*10)   //10ms timer calculation method in 12T mode
#define PI 3.1415926
#define On        0
#define Off        1
void Timer0_Init(void);
void LEDBlink(void);
unsigned int KeyScan(void);
#define LEDPORT P1
#define dx        (PI*2/100)
#define PWM_PERIOD        100
#define LEDNUM         8
sbit LED0 = P1^0;
sbit LED1 = P1^1;
sbit LED2 = P1^2;
sbit LED3 = P1^3;
sbit LED4 = P1^4;
sbit LED5 = P1^5;
sbit LED6 = P1^6;
sbit LED7 = P1^7;
sbit KEY1 = P2^0;
sbit KEY2 = P2^1;
unsigned char led_tab[8] = {
0XFE,0XFD,0XFB,0XF7,0XEF,0XDF,0XBF,0X7F};
unsigned int TimeTikTok = 0;
unsigned int TimeBase = 0;
void main(void)
        unsigned int i = 0;
        unsigned int keycount = 0;
        double x = 0.0;
        Timer0_Init();
                        if (TimeBase) 只有为1的时候会继续
                                TimeBase = 0;
                                TimeTikTok ++;if(TimeTikTok > 60000) TimeTikTok = 0;
                                if(! (TimeTikTok % 10)) //100ms      //怎么样能够加快计数到10
                                                //LEDBlink();
                                if(! (TimeTikTok % 20)) //200ms    //怎么样能加快计数到20
                                                if(KeyScan() == 1)
                                                        LED0 ^=1 ;
                                                if(KeyScan() == 2)
                                                        LED1 ^=1 ;
    TMOD = 0x01;                    //set timer0 as mode1 (16-bit)
    TL0 = T1MS;                     //initial timer0 low byte
    TH0 = T1MS >> 8;                //initial timer0 high byte
    TR0 = 1;                        //timer0 start running
    ET0 = 1;                        //enable timer0 interrupt
    EA = 1;                         //open global interrupt switch
        //LEDPORT |= (0X01<<LEDX);
//unsigned int LEDX,unsigned int delay
void LEDBlink(void)
        static int statue = 0;
        switch (statue)
                case 0:         LEDPORT = 0xFE;                statue = 1;                break;
                case 1:          LEDPORT = 0XFD;                statue = 2;          break;
                case 2:         LEDPORT = 0XFB;                statue = 3;                break;
                case 3:          LEDPORT = 0XF7;                statue = 4;          break;
                case 4:         LEDPORT = 0XEF;                statue = 5;                break;
                case 5:          LEDPORT = 0XDF;                statue = 6;          break;
                case 6:         LEDPORT = 0XBF;                statue = 7;                break;
                case 7:          LEDPORT = 0X7F;                statue = 0;          break;
                unsigned int keyVal = 0;
                switch (statue)
                                case 0:   statue = 1;                break;
                          case 1:
                                                if(!KEY1)          等价于KEY1=0                                                        keyVal = 1;
                                                if(!KEY2)        keyVal = 2;
                                                if((!KEY1) && (!KEY2))        keyVal = 3;
                                                statue = 2;          break;
                                case 2:         statue = 0;                break;
                return keyVal;
/* Timer0 interrupt routine */
//unsigned int PWM_CHANGE_cnt = 0;
void TM0_isr() interrupt 1
    TL0 = T1MS;                     //reload timer0 low byte
    TH0 = T1MS >> 8;                //reload timer0 high byte
                TimeBase = 1;
ID:654028 发表于 2020-11-4 14:29 | 只看该作者
你把进定时器中断时间改小一点不就好了
ID:416287 发表于 2020-11-4 14:42 | 只看该作者
减少你进中断的时间 T1MS (65536-FOSC/12/1000*10)
ID:311846 发表于 2020-11-4 16:51 | 只看该作者
你这是别人写的吧!
void main(void)
        unsigned int i = 0;
        double x = 0.0;
        Timer0_Init();
                                TimeBase = 0;
                               // if(! (TimeTikTok % 10)) //100ms      //怎么样能够加快计数到10
                                                //直接写你的10ms的程序就好了,看程序应该是定时10ms的
                                                //LEDBlink();
                                if(! (TimeTikTok % 2)) //20ms    //20个计数为200ms那么2个计数即为20ms
                                                if(KeyScan() == 1)
                                                        LED0 ^=1 ;
                                                if(KeyScan() == 2)
                                                        LED1 ^=1 ;
