查看: 12125|回复: 9
proteus8.10仿真stm32控制舵机程序(pwm舵机)
       本贴使用Proteus8.10,如低版本打不开可自行根据原理图绘制(很简单)
单片机型号为:stm32f103系列
运行稳定,舵机角度自行更改程序中的pwm输出函数值即可。
   案例中只做了一个,按键按下舵机转动,实际测试过timer2-4的通道0-3,共12路pwm。
       如有问题,评论区留言,看到回~
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. #define LED0 PCout(2)
  7. #define KEY0  GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_5)                                                 //读取按键0
  8. #define KEY1  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_15)                                               //读取按键1
  9. #define WK_UP GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)
  10. void KEY_Init(void)
  11. {
  12.
  13.         GPIO_InitTypeDef GPIO_InitStructure;
  14.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,ENABLE);  //使能PORTA,PORTC时钟
  15.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);                               //关闭jtag使能SWD,可以用SWD模式调试
  16.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                    //设置成上拉输入
  18.          GPIO_Init(GPIOA, &GPIO_InitStructure);        //初始化GPIOA15
  19.
  20.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_5;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                   //设置成上拉输入
  22.          GPIO_Init(GPIOC, &GPIO_InitStructure);        //初始化GPIOC5
  23.                 GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0;
  24.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  25.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  26.
  27. }
  28. void LED_Init(void)
  29. {
  30. GPIO_InitTypeDef  GPIO_InitStructure;
  31. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);          //使能PA,PD端口时钟
  32. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;                                   //LED0-->PA.8 端口配置
  33. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                   //推挽输出
  34. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                  //IO口速度为50MHz
  35. GPIO_Init(GPIOC, &GPIO_InitStructure);                                        //根据设定参数初始化GPIOA.8
  36. GPIO_SetBits(GPIOC,GPIO_Pin_2);                                                //PA.8 输出高
  37. }
  38. void TIM1_PWM_Init(u16 arr,u16 psc)
  39. {
  40.          GPIO_InitTypeDef GPIO_InitStructure;
  41.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  42.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  43.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  44.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);             //使能GPIO外设时钟使能
  45.
  46.    //设置该引脚为复用输出功能,输出TIM1 CH1的PWM脉冲波形
  47.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;                                      //TIM_CH1
  48.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        //复用推挽输出
  49.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  50.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  51.
  52.         TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值         80K
  53.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值  不分频
  54.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
  55.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
  56.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  57.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2
  58.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
  59.         TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值
  60.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高
  61.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根据TIM_OCInitStruct中指定的参数初始化外设TIMx
  62.   TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主输出使能
  63.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1预装载使能
  64.
  65.         TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的预装载寄存器
  66.
  67.         TIM_Cmd(TIM1, ENABLE);  //使能TIM1
  68.
  69. }
  70. int main(void)
  71. {
  72.         delay_init();
  73.         LED_Init();
  74.         KEY_Init();
  75.         TIM1_PWM_Init(1999,72);
  76.         TIM_SetCompare1(TIM1,1899);
  77.         while(1)
  78.         {
  79.                 if(WK_UP==1)
  80.                 {
  81.                         LED0=0;
  82.                         TIM_SetCompare1(TIM1,1899);
  83.                 }
  84.                 else
  85.                 {
  86.                         LED0=1;
  87.                         TIM_SetCompare1(TIM1,699);
  88.                 }
  89.         }
  90. }
[ stm32控制舵机.7z (196.33 KB, 下载次数: 389)
本贴为原创,转载请注明出处!
时间:2020/11/
祝好!
收藏收藏10 分享淘帖 顶1 踩
ID:917281 发表于 2021-5-7 22:11 | 只看该作者
想问一下 如果弄4个舵机的话 程序要怎么改
ID:242753 发表于 2021-5-9 10:15 | 只看该作者
最近正在研究舵机,正好可以好好分析了
ID:841381 发表于 2021-5-13 19:27 | 只看该作者
楼主你好,如果拖动4个电机,然后发现功率不够该怎么办?
ID:985711 发表于 2021-11-28 21:13 | 只看该作者
感谢楼主的分享,下来研究下
ID:1013164 发表于 2022-5-8 20:13 | 只看该作者
为啥我就改了PWM频率,他就生成不了.hex文件了,显示有一个fatal error
ID:1024276 发表于 2022-5-10 23:28 | 只看该作者
楼主你好 为啥我按照你的方法配置 配置的PWM  PA8 电平只是在跳动 舵机却没有反应 ,代码也一样 用的正点原子的模板
ID:1024276 发表于 2022-5-10 23:29 | 只看该作者
为啥我按照楼主的配置 PA8  只是电平再跳 ,而舵机没有反应,模板用的正点原子的
ID:1060890 发表于 2023-3-6 13:25 | 只看该作者
试一下能不能用,自己配置的总有问题
ID:316613 发表于 2023-5-21 10:56 | 只看该作者
只能转动一下,813版本,不知道为啥
