查看: 2111|回复: 2
stm32输出pwm的问题
使用STM32f103的tim1_ch1输出pwm,我在keil里面仿真时,PA8脚输出的波形是需要的方波波形,但是放到硬件时,我测芯片PA8脚值时,始终是0.25V,是什么问题呢
  1. void TIM1_config(u32 Cycle)
  2. {
  3.     GPIO_InitTypeDef GPIO_InitStructure;
  4.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  5.     TIM_OCInitTypeDef  TIM_OCInitStructure;
  6.     RCC_APB2PeriphclockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_TIM1|RCC_APB2Periph_GPIOB , ENABLE);
  7.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;                   //TIM1_CH1 PA8
  8.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  9.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  10.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  11.     TIM_TimeBaseStructure.TIM_Period = Cycle-1;
  12.     TIM_TimeBaseStructure.TIM_Prescaler =71;
  13.     TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  14.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  15.     TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  16.     TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  17.     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  18.     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  19.           TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  20.     TIM_OCInitStructure.TIM_Pulse = Cycle/2-1;
  21.     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  22.     TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  23.
  24.     TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  25.     TIM_SelectMasterSlaveMode(TIM1, TIM_MasterSlaveMode_Enable);
  26.     TIM_SelectOutputtrigger(TIM1, TIM_TRGOSource_Update);
  27.
  28.     TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  29.     TIM_ARRPreloadConfig(TIM1, ENABLE);
  30. }
  31. void TIM4_config(u32 PulseNum)
  32. {
  33.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  34.     NVIC_InitTypeDef NVIC_InitStructure;
  35.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  36.     TIM_TimeBaseStructure.TIM_Period = PulseNum-1;
  37.     TIM_TimeBaseStructure.TIM_Prescaler =0;
  38.     TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  39.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  40.     TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  41.     TIM_SelectInputTrigger(TIM4, TIM_TS_ITR0);
  42.     //TIM_InternalClockConfig(TIM4);
  43.     TIM4->SMCR|=0x07;
  44.     //TIM_ITRxExternalClockConfig(TIM4, TIM_TS_ITR0);
  45.     //TIM_ARRPreloadConfig(TIM4, ENABLE);
  46.     TIM_ITConfig(TIM4,TIM_IT_Update,DISABLE);
  47.    // NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
  48.     NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  49.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  50.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  51.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  52.     NVIC_Init(&NVIC_InitStructure);
  53. }
  54. void Pulse_output(u32 Cycle,u32 PulseNum)
  55. {
  56.     TIM4_config(PulseNum);
  57.     TIM_Cmd(TIM4, ENABLE);
  58.     TIM_ClearITPendingBit(TIM4,TIM_IT_Update);
  59.     TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
  60.     TIM1_config(Cycle);
  61.
  62.     TIM_Cmd(TIM1, ENABLE);
  63.     TIM_CtrlPWMOutputs(TIM1, ENABLE);
  64. }
  65. void TIM4_IRQHandler(void)
  66. {
  67.     if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  68.     {
  69.         TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
  70.         TIM_CtrlPWMOutputs(TIM1, DISABLE);
  71.         TIM_Cmd(TIM1, DISABLE);
  72.         TIM_Cmd(TIM4, DISABLE);
  73.         TIM_ITConfig(TIM4, TIM_IT_Update, DISABLE);
  74.
  75.     }
  76. }
int main(void)
         ChipHalInit();
        ChipOutHalInit();
        DA_Init();
//  tmc2660_init();
        TIM_Cmd(TIM2,ENABLE);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  Pulse_output(1000,8000);
ID:847101 发表于 2020-11-22 00:53 | 只看该作者
你这个是全部代码吗?主程序中没看到TIM初始化的调用啊~~
ID:420836 发表于 2020-11-22 09:45 | 只看该作者
PWM输出上有负载吗?
