查看: 2083|回复: 0
基于单片机的温度湿度采集系统程序
原理图
程序:
声明:本程序仅供大家参考学习,未经本人同意禁止用于商业用途。
#include <reg52.h>
#include <intrins.h>
typedef bit BOOL  ;
sbit io = P1^1 ;//(口线定义)
sbit bee=P1^0;
sbit rs = P2^5 ;
sbit rw = P2^6 ;
sbit ep = P2^7 ;
bit flag_300ms ;
sbit K1=P1^2;
sbit K2=P1^3;
sbit K3=P1^4;
uchar yemian=0;//(定义变量)
uchar flat=1;
uchar data_byte;
uchar RH,RL,TH,TL;
uchar WenDu,ShiDu;//报警的温度和湿度
#include "eeprom52.h"
/****************************延时程序****************************/
void delay(uchar ms)
{       // 延时子程序
         uchar i ;
         while(ms--)
                  for(i = 0 ; i<250;i++) ;
void delay1()//延时10us
        uchar i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
void longdelay(uchar s) //长延时
         while(s--)
                  delay(20) ;
/******************把数据保存到单片机内部eeprom中******************/
void write_eeprom()
        SectorErase(0x2000);
         byte_write(0x2000, WenDu);
        byte_write(0x2001, ShiDu);
        byte_write(0x2060, a_a);
/******************把数据从单片机内部eeprom中读出来*****************/
void read_eeprom()
        WenDu   = byte_read(0x2000);
  ShiDu = byte_read(0x2001);
        a_a      = byte_read(0x2060);
/**************开机自检eeprom初始化*****************/
void init_eeprom()
        read_eeprom();                //先读
        if(a_a != 2)                //新的单片机初始单片机内问eeprom
        WenDu   = 30;
        ShiDu   = 80;
                a_a = 2;
                write_eeprom();
/********************报警程序部分*******************/
void warn()  //报警函数
  if(TH>=WenDu)  //检测的温度高于设定温度报警值
      bee=0; //报警
        if(RH>=ShiDu)  //检测的湿度高于设定的湿度值
      bee=0; //报警
        if( TH<WenDu  &&  RH<ShiDu )
                  bee=1; //停止报警
/************************LCD模块******************************************/
BOOL lcd_bz()//测试LCD忙碌状态
         BOOL result ;
         rs = 0 ;
         rw = 1 ;
         ep = 1 ;
         result = (BOOL)(P0 & 0x80) ;
         ep = 0 ;
         return result ;
void write_cmd(uchar cmd)// 写指令
         while(lcd_bz()) ;
        rs = 0 ;
        rw = 0 ;
        ep = 0 ;
        P0 = cmd ;
        ep = 1 ;
        ep = 0 ;
void write_addr(uchar addr)//写地址
         write_cmd(addr|0x80) ;
void write_byte(uchar dat)//写字节
         while(lcd_bz()) ;
          rs = 1 ;
          rw = 0 ;
          ep = 0 ;
          P0 = dat ;
          ep = 1 ;
          ep = 0 ;
void lcd_init()// 初始化
         write_cmd(0x38) ;
         delay(1);
         write_cmd(0x08) ;
         delay(1);
         write_cmd(0x01) ;
         delay(1);
         write_cmd(0x06) ;
         delay(1);
         write_cmd(0x0c) ;
         delay(1);
void display(uchar addr, uchar q)//在某一地址上显示一字节
         delay(1) ;
         write_addr(addr) ;
   write_byte(q) ;
         delay(1) ;
/*********************** DHT11测试模块***************************************/
void start()//开始信号
        io=1;
        delay1();
        io=0;
        delay(20);//>18ms
        io=1;
        delay1();//20-40us
        delay1();
        delay1();
        delay1();
        delay1();
uchar receive_byte()//接收一个字节
        uchar i,temp,count;
        for(i=0;i<8;i++)
        temp=0;
                delay1();delay1();delay1();delay1();
                if(io==1)temp=1;
                count=2;
                while((io)&&count++);
                if(count==1)break;
                data_byte<<=1;
                data_byte|=temp;
        return data_byte;
void receive()//接收数据
        uchar T_H,T_L,R_H,R_L,check,num_check;
        uchar count;
        start();//开始信号
        io=1;
        if(!io)//读取DHT11响应信号
        R_H=receive_byte();
        R_L=receive_byte();
        T_H=receive_byte();
        T_L=receive_byte();
        check=receive_byte();
        io=0;//拉低延时50us
        delay1();delay1();delay1();delay1();delay1();
        io=1;
        num_check=R_H+R_L+T_H+T_L;
        if(num_check=check)
                RH=R_H;
                RL=R_L;
                TH=T_H;
                TL=T_L;
                check=num_check;
void showw()   // 问候语函数
           lcd_init(); //初始化
            delay(10);
     display(0x05,'W');
     display(0x06,'e');
                 display(0x07,'l');
                 display(0x08,'c');
                 display(0x09,'o');
                 display(0x0a,'m');
     display(0x0b,'e');
           delay(250); //短暂延时
           delay(250);
           delay(250);
           display(0x40,' ') ;
                 display(0x41,'h');
                 display(0x42,'e');
/*************定时器0初始化程序***************/
void time_init()
        EA   = 1;                   //开总中断
        TMOD = 0X01;          //定时器0、定时器1工作方式1
        ET0  = 1;                  //开定时器0中断
        TR0  = 1;                  //允许定时器0定时
void key() //按键程序 选择菜单模式
          if(!K1)
                          delay(20);
                            if(!K1)
                                                         while(!K1)
                                                          yemian++;
                                                          flat++;
        if(yemian>=3) { yemian=0; }
shezhi()  //对里面的数值进行修改
    if(!K2)
                          delay(50);
                            if(!K2)
                                                         if(yemian==1)
                                                          WenDu+=1;
        if(WenDu>99) { WenDu=99; }  //湿度上限加
                                                         if(yemian==2)
                                                          ShiDu+=1;
        if(ShiDu>99) { ShiDu=99; }  //湿度下限加
        write_eeprom();       //保存数据
                          if(!K3)
                            delay(50);
                             if(!K3)
                                                           if(yemian==1)
                                                              WenDu-=1;          //湿度下限减
        if(WenDu<1) {WenDu=1; }
                                                           if(yemian==2)
                                                              ShiDu-=1;         //湿度下限减
        if(ShiDu<1) { ShiDu=1; }
/***************************主程序*********************************/
         init_eeprom();                              //读eeprom数据
   time_init();                                //初始化定时器
   showw();    //显示问候语 和名字
                   key();
                //====================yemian==0时 进入工作状态=================================
                         if(yemian==0)
                                if(flat==1)
           flat=0;
                                         lcd_init(); //初始化
                                         display(0x00,'T') ;    //Temp
                       display(0x01,'e');
                       display(0x02,'m');
                                         display(0x03,'p');
           display(0x04,':');
                                         display(0x08,0xdf); // 度
                       display(0x09,'C');
                                         display(0x40,'H') ;    //Humi
                       display(0x41,'u');
                       display(0x42,'m');
                                         display(0x43,'i');
           display(0x44,':');
                                         display(0x47,'%');
                                         display(0x48,'R');
                                         display(0x49,'H');
                                         display(0x0c,'T');
           display(0x0d,':');
           display(0x0e,WenDu/10+0x30);  //报警温度
                       display(0x0f,WenDu%10+0x30);
                                         display(0x4c,'H');
           display(0x4d,':');
                                   display(0x4e,ShiDu/10+0x30);  //报警湿度
                       display(0x4f,ShiDu%10+0x30);
                         if(flag_300ms == 1)
                             flag_300ms = 0;
           receive();
                                         display(0x05,TH/10+0x30);  //温度显示
                       display(0x06,TH%10+0x30);
           display(0x45,RH/10+0x30);  //湿度显示
                       display(0x46,RH%10+0x30);
           warn();
        //====================yemian==1 温度设置===========================
                                if(yemian==1)  //温度
                         if(flat==1)
               flat=0;
                                                          bee=1;
               lcd_init(); //初始化
                                                         display(0x06,'T');
                                                         display(0x07,'e');
                                                         display(0x08,'m');
                                                         display(0x09,'p');
                                                shezhi();
                                                display(0x47,WenDu/10+0x30);  //温度
                        display(0x48,WenDu%10+0x30);
                //====================yemian==1湿度设置==========================
                                if(yemian==2)   //湿度设置
                         if(flat==1)
               flat=0;
                                                          bee=1;
               lcd_init(); //初始化
                                                         display(0x06,'H');
                                                         display(0x07,'u');
                                                         display(0x08,'m');
                                                         display(0x09,'i');
                                                 shezhi();
                                                 display(0x47,ShiDu/10+0x30);  //湿度
                         display(0x48,ShiDu%10+0x30);
/*************定时器0中断服务程序***************/
void time0_int() interrupt 1
        static uchar value;
        TH0 = 0x3c;
        TL0 = 0xb0;     // 50ms
        if(value % 6 == 0)
                flag_300ms = 1;           //300ms
                value = 0;
基于单片机的温度湿度采集系统.zip
64.72 KB, 下载次数: 7, 下载积分: 黑币 -5
