查看: 3027|回复: 7
为什么小于20时奇数取余错了。比如3除2取余显示的是1.0不是1.5
ID:853017 发表于 2020-12-2 17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#define dula P0
#define wela P2
sbit k4=P3^6;
sbit k5=P3^7;
sbit beep=P2^3;
bit stop=1,scp=0;
unsigned char j,k,num0,num1,num2,num3,sec,min,count=0;
unsigned char time_count;
unsigned char code weitable[]={0x8f,0x4f,0x2f,0x1f};
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                                                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                                                        0x87,0xff,0xef};
void delay(unsigned char i)
        for (j=i;j>0;j--)
         for(k=125;k>0;k--);
void display1 (uchar wei,uchar shu)
        wei=wei-1;
        wela|=0xf0;
        if(wei==3)
        P0=table1[shu];
        P0=table[shu];
        wela=wela&weitable[wei];
        delay(10);
        if(sec<10)
        if(wei==1)
        P0=table1[shu];
        P0=table[shu];
        delay(10);
void display(unsigned char c,unsigned char d)
        display1 (4,0);
        display1 (3,5);
        if(sec<10)
                display1 (1,c);
                display1 (2,d);
                else if(sec>9)
                display1 (2,c);
                display1 (1,d);
void start_timer()
        ET0=1;
        EA=1;
        TR0=1;
void stop_timer()
        ET0=0;
        EA=0;
        TR0=0;
        int z=0;
        TMOD=0x01;
        TH0=(65536-46080)/256;
        TL0=(65536-46080)%256;
        if(k4==0)
                        delay(10);
                        if(k4==0)
                                 while(k4==0);
                                        if(stop)
                                        start_timer();
                                        scp=~scp;
                                        stop=~stop;
                                        beep=1;
                                        sec=0;
        if(k5==0)
                   delay(10);
                if(k5==0)
                        while(k5==0);
                        stop_timer();
                        scp=~scp;
                        stop=1;
                if(time_count==20)
                  count=0;
                time_count=0;
                sec++;
                if(sec==100)
                        sec=0;
                beep=0;
                delay(10);
                beep=1;
          if(scp==1)
          num0=sec%10;
          num1=sec/10;
          display(num1,num0);
          else if(scp==0)
          num0=sec/2%10;
          num1=sec/2/10;
          display(num1,num0);
void rimer0()interrupt 1
        time_count++;
ID:451718 发表于 2020-12-2 17:30 | 只看该作者
51不支持浮点运算的,你一定是哪里地方10倍值换算的时候搞错了。
ID:278840 发表于 2020-12-2 17:46 | 只看该作者
3/2取余数不就是1吗????
ID:853017 发表于 2020-12-2 17:55 | 只看该作者
好的谢谢
ID:57657 发表于 2020-12-2 22:03 | 只看该作者
浮点运算需要float或double数据类型
ID:83493 发表于 2020-12-2 22:34 | 只看该作者
3/2取余数就是1啊,没毛病么
ID:213173 发表于 2020-12-3 07:40 | 只看该作者
楼主把小学算术忘了吧,3÷2=1余1。取余,不是取商!
ID:712493 发表于 2020-12-3 09:34 | 只看该作者
