查看: 3598|回复: 2
八位数码管电子时钟 protues模拟
ID:853394 发表于 2020-12-2 21:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
八位数码管电子时钟
代码
#include <reg51.h>
sbit key1 = P1^0;
bit flag1s = 0;
bit KeySta = 1;
unsigned char hour = 8;
unsigned char minute = 31;
unsigned char second = 59;
unsigned char mode = 0;
void FreshTime();
void TimeInit();
void IntInit();
void InitLedBuff();
void keyscan();
unsigned char code LedChar[] = {  //共阴数码管显示字符转换表
    0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
unsigned char LedBuff[8] = {  //数码管显示缓冲区
    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
    TimeInit();
    IntInit();
    InitLedBuff();
  while(1)//显示内容处理
   if(flag1s&&!mode) //时间显示模式
      flag1s = 0;
                  FreshTime();
     else if(mode == 1)  //校准分钟
      LedBuff[0] = 17;
      LedBuff[1] = 17;
      LedBuff[4] = 17;
      LedBuff[5] = 17;//不显示
          LedBuff[6] = 17;
      LedBuff[7] = 17;
      LedBuff[2] = minute/10;
      LedBuff[3] = minute%10;
    else if(mode == 2)  //校准小时
      LedBuff[2] = 17;
      LedBuff[3] = 17;
      LedBuff[4] = 17;
           LedBuff[6] = 17;
      LedBuff[7] = 17;
      LedBuff[0] = hour/10;
      LedBuff[1] = hour%10;
    else if(mode == 3)  //校准完成重新显示
      InitLedBuff();
      mode = 0;
    keyscan();
void InitLedBuff()//初始化时间到显示缓冲区
  LedBuff[4] = second/10;
  LedBuff[5] = second%10;
void FreshTime()//刷新时间到显示缓冲区
  second++;
  if(second == 60)//进位
    second = 0;
    minute++;
    if(minute==60)//进位
      minute=0;
      hour++;
      if(hour == 24)
        hour = 0;
void TimeInit()//定时器初始化
  TMOD = 0X11;    //设置定时器为模式1
  TL0 = 0xB0;
  TH0 = 0x3C;     //定时初值 50ms
  TL1 = 0x18;                //
TH1 = 0xFC;                //定时初值 1ms
  TR0 = 1;    //定时器0开始计时
  TR1 = 1;    //定时器1开始计时
  ET1 = 1;    //使能定时器1
  ET0 = 1;    //使能定时器0
  PT0 = 1;    //提高计时准确性,提高定时器0中断优先级
  EA = 1;     //打开总中断
void IntInit()//外部中断初始化
  IT0 = 1;     //下降沿触发
  EX0 = 1;    //使能外部中断0
void keyscan() //按键扫描及处理
  static bit backup = 1;
  if (KeySta != backup)  //当前值与前次值不相等说明此时按键有动作
    if (backup == 0)   //如果前次值为0,则说明当前是弹起动作
      if(mode == 1)   //校准分钟时,分钟加一
        minute++;
        if(minute==60)
          minute = 0;
      else if(mode == 2)    //校准小时,小时加一
        hour++;
        if(hour==24)
          hour = 0;
    backup = KeySta;   //更新备份为当前值,以备进行下次比较
void Int0() interrupt 0
  mode++;
  if(mode == 4)
    mode = 0;
void Ledfresh() //数码管显示刷新
  static unsigned char i = 0;
  switch(i)
    case 0 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[0]];i++;break;
    case 1 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[1]];i++;break;
    case 2 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//时分间隔线
    case 3 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[2]];i++;break;
    case 4 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[3]];i++;break;
    case 5 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//分秒间隔线
    case 6 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[4]];i++;break;
    case 7 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[5]];i=0;break;
void Time0() interrupt 1 // 50ms
  static unsigned char n = 0;
  TL0 = 0xB0;
  TH0 = 0x3C;
  n++;
  if(n==20)
    n=0;
    flag1s = 1;//1s标志位
void Time1() interrupt 3  // 1ms
  static unsigned char keybuff = 0xff;
  TL1 = 0x18;                //
  Ledfresh();
  keybuff = (keybuff<<1)|key1;
  if (keybuff == 0x00)
  {   //连续8次扫描值都为0,即16ms内都只检测到按下状态时,可认为按键已按下
      KeySta = 0;
  else if (keybuff == 0xFF)
  {   //连续8次扫描值都为1,即16ms内都只检测到弹起状态时,可认为按键已弹起
      KeySta = 1;
  {}  //其它情况则说明按键状态尚未稳定,则不对KeySta变量值进行更新
八位数码管电子时钟.zip
18.14 KB, 下载次数: 64, 下载积分: 黑币 -5
ID:118735 发表于 2022-10-8 23:59 | 只看该作者
程序写的非常不错的
ID:894868 发表于 2023-2-10 15:42 | 只看该作者
我是来拿程序看看的··谢谢分享···
