查看: 4272|回复: 1
hx711电子秤+lm35温度检测+lcd1602+tlc549程序
#include <reg52.h>
#include <intrins.h>
#include <string.h>
bit bdata flag_key;
#include "main.h"
#include "LCD1602.h"
#include "HX711.h"
#include "keyboard.h"
#include "eeprom52.h"
#include "tlc549.h"
#define uint  unsigned int
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
unsigned long Weight_Maopi_0 = 0;
unsigned int qupi=0;
long Weight_Shiwu = 0;
//键盘处理变量
unsigned char keycode;
unsigned char DotPos;                                   //小数点标志及位置
uint GapValue,GapValue1;
unsigned char idata price;     //单价,长整型值,单位为分
unsigned char idata money;     //总价,长整型值,单位为分
unsigned char idata lm35;
//定义标识
volatile bit FlagTest = 0;                //定时测试标志,每0.5秒置位,测完清0
volatile bit FlagKeyPress = 0;  //有键按下标志,处理完毕清0
//校准参数
//因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。
//当发现测试出来的重量偏大时,增加该数值。
//如果测试出来的重量偏小时,减小改数值。
//该值可以为小数
//#define GapValue 349
sbit LED=P3^2;
volatile bit ClearWeighFlag = 0; //传感器调零标志位,清除0漂
/******************把数据保存到单片机内部eeprom中******************/
void write_eeprom()
        SectorErase(0x1000);
        GapValue1=GapValue&0x00ff;
        byte_write(0x2000, GapValue1);
        GapValue1=(GapValue&0xff00)>>8;
        byte_write(0x2001, GapValue1);
        byte_write(0x2060, a_a);
/******************把数据从单片机内部eeprom中读出来*****************/
void read_eeprom()
        GapValue   = byte_read(0x2001);
        GapValue   = (GapValue<<8)|byte_read(0x2000);
        a_a      = byte_read(0x2060);
/**************开机自检eeprom初始化*****************/
void init_eeprom()
        read_eeprom();                //先读
        if(a_a != 1)                //新的单片机初始单片机内问eeprom
                GapValue  = 3500;
                a_a = 1;
                write_eeprom();           //保存数据
//显示单价,单位为元,四位整数,两位小数
void Display_Price()
            LCD1602_write_com(0x8c);
                        LCD1602_write_data(price/100 + 0x30);
                        LCD1602_write_data(price%100/10 + 0x30);
                        LCD1602_write_data('.');
                        LCD1602_write_data(price%10 + 0x30);
//显示重量,单位kg,两位整数,三位小数
void Display_Weight()
            LCD1602_write_com(0x82);
                        LCD1602_write_data(Weight_Shiwu/10000 + 0x30);
        LCD1602_write_data(Weight_Shiwu%10000/1000 + 0x30);
                        LCD1602_write_data(Weight_Shiwu%1000/100 + 0x30);
                        LCD1602_write_data(Weight_Shiwu%100/10 + 0x30);
                        LCD1602_write_data(Weight_Shiwu%10 + 0x30);
        LCD1602_write_word("K ");
//显示总价,单位为元,四位整数,两位小数
void Display_Money()
  // unsigned int i,j;
   if (money>9999)         //超出显示量程
     LCD1602_write_com(0xC2);
     LCD1602_write_word("---.-");
      return;
   if (money>=1000)
       LCD1602_write_com(0XC2);
           LCD1602_write_data(money/1000 + 0x30);
           LCD1602_write_data(money%1000/100 + 0x30);
           LCD1602_write_data(money%100/10 + 0x30);
           LCD1602_write_data(money%10 + 0x30);
   else if (money>=100)
           LCD1602_write_data(0x20);
    else if(money>=10)
            LCD1602_write_com(0XC3);
           LCD1602_write_data(money%10+ 0x30);
           LCD1602_write_com(0xC3);
           LCD1602_write_com(0xC4);
           LCD1602_write_data(0 + 0x30);
void Display_lm35()
            LCD1602_write_com(0xcc);
                  lm35=lm35/10;
                        LCD1602_write_data(lm35*2/100+ 0x30);
                        LCD1602_write_data(lm35*2%100/10+0x30);
                        LCD1602_write_data(lm35*2%10+ 0x30);
//数据初始化
void Data_Init()
   price = 0;
   DotPos = 0;
         lm35=0;
         money=0;
电子秤.7z
82.65 KB, 下载次数: 50, 下载积分: 黑币 -5
ID:611988 发表于 2020-12-8 10:23 | 只看该作者
楼主好人 学习使人进步
