查看: 4267|回复: 1
四位共阴数码管模拟交通灯 Arduino程序
hello大家好,今天早上过马路时等红绿灯时,也想自己做一个玩玩,代码如下,由于作者水平有限,以下代码仅供参考,使用开发板为arduino uno
#define redLed A2
#define greeLed A0
#define yelloLed A1
int redDS=15;
int greenDS=15;
int yellowDS=5;
char signal;
int a = 9;
int b = 8;
int c = 7;
int d = 6;
int e = 5;
int f = 4;
int g = 3;
int dp = 2;
int d4 = 13;
int d3 = 12;
int d2 = 11;
int d1 = 10;
long n = 12030;
int x = 100;
int del = 55;
void setup()
   Serial.begin(9600);
   for(int a=2;a<=13;a++)
    pinMode(a,OUTPUT);
     for(int A0=2;A0<=A2;A0++)
    pinMode(A0,OUTPUT);
void loop()
  jiaotongdeng();
void WX(unsigned char x)//数码管位选
    switch(x)
    case 1:
          digitalWrite(d1,LOW);
          digitalWrite(d2,HIGH);
          digitalWrite(d3,HIGH);
          digitalWrite(d4,HIGH);
     break;
     case 2:
          digitalWrite(d1,HIGH);
          digitalWrite(d2,LOW);
     break;
     case 3:
          digitalWrite(d3,LOW);
     break;
      case 4:
          digitalWrite(d4,LOW);
     break;
        default:
            break;
unsigned char number[10][8] =
{   //a b c d e f g dp
    {1, 1,  1,  1,  1,  1,  0,  0},
    {0, 1,  1,  0,  0,  0,  0,  0},
    {1, 1,  0,  1,  1,  0,  1,  0},
    {1, 1,  1,  1,  0,  0,  1,  0},
    {0, 1,  1,  0,  0,  1,  1,  0},
    {1, 0,  1,  1,  0,  1,  1,  0},
    {1, 0,  1,  1,  1,  1,  1,  0},
    {1, 1,  1,  0,  0,  0,  0,  0},
    {1, 1,  1,  1,  1,  1,  1,  0},
    {1, 1,  1,  0,  0,  1,  1,  0}
void Clear()//清屏函数
  digitalWrite(a,LOW);
  digitalWrite(b,LOW);
  digitalWrite(c,LOW);
  digitalWrite(d,LOW);
  digitalWrite(e,LOW);
  digitalWrite(f,LOW);
  digitalWrite(g,LOW);
  digitalWrite(dp,LOW);
void DX(unsigned char x)//数码管段选
    digitalWrite(a,number[x][0]);          //a查询码值表
    digitalWrite(b,number[x][1]);
    digitalWrite(c,number[x][2]);
    digitalWrite(d,number[x][3]);
    digitalWrite(e,number[x][4]);
    digitalWrite(f,number[x][5]);
    digitalWrite(g,number[x][6]);
    digitalWrite(dp,number[x][7]);
void display(unsigned char y,unsigned char Number)
  WX(y);
  DX(Number);
  Clear();
void jiaotongdeng()
   if(Serial.available()>0){
    signal=Serial.read();
    Serial.print(signal);
    if(signal=='A'){//修改红灯定时时间0~99s
        redDS=Serial.read()-48;
        int zifu=Serial.read()-48;
        redDS=redDS*10+zifu;
        Serial.print("-->");
        Serial.println(redDS);
    if(signal=='B'){//修改绿灯定时时间0~99s
        greenDS=Serial.read()-48;
        Serial.println(greenDS);
        greenDS=greenDS*10+zifu;
    if(signal=='C'){//修改黄灯定时时间0~99s
        yellowDS=Serial.read()-48;
        Serial.println(yellowDS);
        yellowDS=yellowDS*10+zifu;
  digitalWrite(redLed,HIGH);
  for(int i=redDS;i>=0;i--){
    for(int k=5000;k>0;k--){
    display(1,i/10);
    display(2, i%10);
  digitalWrite(redLed,LOW);
  digitalWrite(yelloLed,HIGH);
  for(int i=yellowDS;i>=0;i--){
    display(2,i/10);
    display(3, i%10);
  digitalWrite(yelloLed,LOW);
  digitalWrite(greeLed,HIGH);
  for(int i=greenDS;i>=0;i--){
    display(3,i/10);
    display(4, i%10);
  digitalWrite(greeLed,LOW);
}最后有个不情之请,如果您会使用0x..十六进制写法改进我的代码,请发到评论区
收藏收藏1 分享淘帖 顶 踩
ID:138707 发表于 2023-7-30 12:24 | 只看该作者
很有创意,我喜欢
