查看: 660|回复: 0
单片机波形发生器程序
ID:868776 发表于 2020-12-27 14:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include<reg51.h>
  2. sbit wr=P3^6;
  3. sbit rd=P3^2;
  4. sbit key0=P1^0;
  5. sbit key1=P1^1;
  6. sbit key2=P1^2;
  7. sbit key3=P1^3;
  8. sbit key4=P1^4;
  9. unsigned char flag;
  10. unsigned char const code
  11. SIN_code[256]={0x80, 0x83, 0x86, 0x89, 0x8c, 0x8f, 0x92, 0x95,
  12. 0x98, 0x9c, 0x9f, 0xa2, 0xa5, 0xa8, 0xab, 0xae,
  13. 0xb0, 0xb3, 0xb6, 0xb9, 0xbc, 0xbf, 0xc1, 0xc4,
  14. 0xc7, 0xc9, 0xcc, 0xce, 0xd1, 0xd3, 0xd5, 0xd8,
  15. 0xda, 0xdc, 0xde, 0xe0, 0xe2, 0xe4, 0xe6, 0xe8,
  16. 0xea, 0xec, 0xed, 0xef, 0xf0, 0xf2, 0xf3, 0xf4,
  17. 0xf6, 0xf7, 0xf8, 0xf9, 0xfa, 0xfb, 0xfc, 0xfc,
  18. 0xfd, 0xfe, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
  19. 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xfe,
  20. 0xfd, 0xfc, 0xfc, 0xfb, 0xfa, 0xf9, 0xf8, 0xf7,
  21. 0xf6, 0xf5, 0xf3, 0xf2, 0xf0, 0xef, 0xed, 0xec,
  22. 0xea, 0xe8, 0xe6, 0xe4, 0xe3, 0xe1, 0xde, 0xdc,
  23. 0xda, 0xd8, 0xd6, 0xd3, 0xd1, 0xce, 0xcc, 0xc9,
  24. 0xc7, 0xc4, 0xc1, 0xbf, 0xbc, 0xb9, 0xb6, 0xb4,
  25. 0xb1, 0xae, 0xab, 0xa8, 0xa5, 0xa2, 0x9f, 0x9c,
  26. 0x99, 0x96, 0x92, 0x8f, 0x8c, 0x89, 0x86, 0x83,
  27. 0x80, 0x7d, 0x79, 0x76, 0x73, 0x70, 0x6d, 0x6a,
  28. 0x67, 0x64, 0x61, 0x5e, 0x5b, 0x58, 0x55, 0x52,
  29. 0x4f, 0x4c, 0x49, 0x46, 0x43, 0x41, 0x3e, 0x3b,
  30. 0x39, 0x36, 0x33, 0x31, 0x2e, 0x2c, 0x2a, 0x27,
  31. 0x25, 0x23, 0x21, 0x1f, 0x1d, 0x1b, 0x19, 0x17,
  32. 0x15, 0x14, 0x12, 0x10, 0x0f, 0x0d, 0x0c, 0x0b,
  33. 0x09, 0x08, 0x07, 0x06, 0x05, 0x04, 0x03, 0x03,
  34. 0x02, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
  35. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01,
  36. 0x02, 0x03, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
  37. 0x09, 0x0a, 0x0c, 0x0d, 0x0e, 0x10, 0x12, 0x13,
  38. 0x15, 0x17, 0x18, 0x1a, 0x1c, 0x1e, 0x20, 0x23,
  39. 0x25, 0x27, 0x29, 0x2c, 0x2e, 0x30, 0x33, 0x35,
  40. 0x38, 0x3b, 0x3d, 0x40, 0x43, 0x46, 0x48, 0x4b,
  41. 0x4e, 0x51, 0x54, 0x57, 0x5a, 0x5d, 0x60, 0x63,
  42. 0x66, 0x69, 0x6c, 0x6f, 0x73, 0x76, 0x79, 0x7c };
  43. unsigned char keyscan()
  44. {
  45.   unsigned char keyscan_num,temp;
  46.   P1=0xff;
  47.   temp=P1;
  48.   if(~(temp&0xff))
  49.   {
  50.     if(key0==0)
  51.     {
  52.            keyscan_num=1;
  53.         }
  54.         else if(key1==0)
  55.         {
  56.             keyscan_num=2;
  57.         }
  58.         else if(key3==0)
  59.         {
  60.             keyscan_num=2;
  61.         }
  62.         else if(key3==0)
  63.         {
  64.             keyscan_num=4;
  65.         }
  66.         else if(key4==0)
  67.         {
  68.             keyscan_num=5;
  69.         }
  70.         else
  71.         {
  72.             keyscan_num=0;
  73.         }
  74.         return keyscan_num;
  75.   }
  76. }
  77. void init_DA0832()
  78. {
  79.   rd=0;
  80.   wr=0;
  81. }
  82. void SIN()
  83. {
  84.   unsigned int i;
  85.   do{
  86.       P2=SIN_code[i];
  87.           i=i+1;
  88.           }while(i<256);
  89. }
  90. void Square()
  91. {
  92.   EA=1;
  93.   ET0=1;
  94.   TMOD=1;
  95.   TH0=0xff;
  96.   TL0=0x83;
  97.   TR0=1;
  98. }
  99. void Triangle()
  100. {
  101.   P2=0x00;
  102.   do{
  103.      P2=P2+1;
  104.         }while(P2<0xff);
  105.   P2=0xff;
  106.   do{
  107.      P2=P2-1;
  108.          }while(P2>0x00);
  109.   P2=0x00;
  110. }
  111. void Sawtooth()
  112. {
  113.   P2=0x00;
  114.   do{
  115.      P2=P2+1;
  116.         }while(P2<0xff);
  117. }
  118. void Trapezoidal()
  119. {
  120.   unsigned char i;
  121.   P2=0x00;
  122.   do{
  123.      P2=P2+1;
  124.         }while(P2<0xff);
  125.   P2=0xff;
  126.   for(i=255;i>0;i--)
  127.   {
  128.         P2=0xff;
  129.   }
  130.   do{
  131.      P2=P2-1;
  132.          }while(P2>0x00);
  133.   P2=0x00;
  134. }
  135. void main()
  136. {
  137.   init_DA0832();
  138.   do
  139.   {
  140.     flag=keyscan();
  141.   }while(!flag);
  142.   while(1)
  143.   {
  144.     switch(flag)
  145.         {
  146.         case 1:
  147.         do{
  148.            flag=keyscan();
  149.            SIN();
  150.           }while(flag==1);
  151.           break;
  152.         case 2:
  153.           Square();
  154.         do{
  155.            flag=keyscan();
  156.           }while(flag==2);
  157.            TR0=0;
  158.            break;
  159.         case 3:
  160.         do{
  161.            flag=keyscan();
  162.            Triangle();
  163.           }while(flag==3);
  164.            break;
  165.         case 4:
  166.         do{
  167.            flag=keyscan();
  168.            Trapezoidal();
  169.           }while(flag==4);
  170.            break;
  171.         case 5:
  172.         do{
  173.            flag=keyscan();
  174.            Sawtooth();
  175.           }while(flag==5);
  176.            break;
  177.         default:
  178.          flag=keyscan();
  179.          break;
  180.          }
  181.         }
  182. }
  183. void timer0(void) interrupt 1
  184. {
  185.   P2=~P2;
  186.   TH0=0xff;
  187.   TL0=0x83;
  188.   TR0=1;
  189. }
