查看: 4238|回复: 2
51单片机驱动74HC595控制数码管上显示数字
ID:51773 发表于 2013-7-19 02:21 | 显示全部楼层 |阅读模式
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #define  NOP() _nop_()  /* 定义空指令 */
  4. //SPI IO
  5. sbit MOSIO =P3^4;
  6. sbit R_CLK =P3^5;
  7. sbit S_CLK =P3^6;
  8. void delay(unsigned int i);      //函数声名
  9. void HC595SendData(unsigned char SendVal);
  10.
  11. // 此表为 LED 的字模            // 0    1    2    3    4    5    6   7    8    9    A    b    c    d    E    -    L   P    U    Hidden  _ (20)
  12. unsigned char code Disp_Tab[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0xbf,0xc7,0x8c,0xc1, 0xff,  0xf7 };
  13. unsigned char code LED7Code[] = {~0x3F,~0x06,~0x5B,~0x4F,~0x66,~0x6D,~0x7D,~0x07,~0x7F,~0x6F,~0x77,~0x7C,~0x39,~0x5E,~0x79,~0x71};
  14.
  15. main()
  16. {  unsigned char  HC595SendVal;
  17.    unsigned int LedNumVal=1;
  18.
  19.   while(1)
  20.   {
  21.         LedNumVal++;
  22.         HC595SendVal = LED7Code[LedNumVal%16];     //LED7;  显示0-F  LedNumVal%10 显示0-9
  23.         HC595SendData(HC595SendVal);
  24.
  25.         delay(200);
  26.
  27.   }
  28. }
  29. void delay(unsigned int i)
  30. {
  31.     unsigned int j;
  32.     for(i; i > 0; i--)
  33.         for(j = 300; j > 0; j--);
  34. }
  35. /*********************************************************************************************************
  36. ** 函数名称: HC595SendData
  37. ** 功能描述: 向SPI总线发送数据
  38. *********************************************************************************************************/
  39. void HC595SendData(unsigned char SendVal)
  40. {
  41.   unsigned char i;
  42.
  43.   for(i=0;i<8;i++)
  44.    {
  45.     if((SendVal<<i)&0x80) MOSIO=1; //set dataline high  0X80  最高位与SendVal左移的最高位 进行逻辑运算
  46.     else MOSIO=0;                  // 如果为真 MOSIO = 1
  47.
  48.     S_CLK=0;
  49.     NOP();
  50.     NOP();
  51.     S_CLK=1;
  52.    }
  53.
  54.
  55.   R_CLK=0; //set dataline low
  56.   NOP();
  57.   NOP();
  58.   R_CLK=1; //片选
  59. }
ID:37147 发表于 2013-11-23 22:16 | 显示全部楼层
学习学习  真好!
ID:358284 发表于 2018-6-25 17:19 | 显示全部楼层
能附上电路图就更好了,感谢
