查看: 2192|回复: 0
4X4矩阵键盘,数码管显示
ID:872234 发表于 2021-1-9 01:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用单片机C语言编程实现单个数码管显示按下按键编号(S1按下显示0,S2按下显示1…S16按下显示F)#include<reg52.h>
unsigned char const
ceshi[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar keyscan(void);
void delay(uint i);
void main ()
  uchar key;
  P2=0x00;
    key=keyscan();
        switch(key)
          case 0x7e:P0=ceshi[0];break;
          case 0x7d:P0=ceshi[1];break;
          case 0x7b:P0=ceshi[2];break;
          case 0x77:P0=ceshi[3];break;
          case 0xbe:P0=ceshi[4];break;
          case 0xbd:P0=ceshi[5];break;
          case 0xbb:P0=ceshi[6];break;
          case 0xb7:P0=ceshi[7];break;
          case 0xde:P0=ceshi[8];break;
          case 0xdd:P0=ceshi[9];break;
          case 0xdb:P0=ceshi[10];break;
          case 0xd7:P0=ceshi[11];break;
          case 0xee:P0=ceshi[12];break;
          case 0xed:P0=ceshi[13];break;
          case 0xeb:P0=ceshi[14];break;
          case 0xe7:P0=ceshi[15];break;
          uchar keyscan(void)
            uchar cord_h,cord_1;
                P3=0x0f;
                cord_h=P3&0x0f;
                if(cord_h!=0x0f)
            delay(100);
                if(cord_h=P3&0x0f)
                  cord_h=P3&0x0f;
                  P3=cord_h|0xf0;
                  cord_1=P3&0xf0;
                  return(cord_h+cord_1);
                  return(0xff);
                  void delay(uint i)
                  while(i--);
矩阵键盘.rar (39.39 KB, 下载次数: 16)
