查看: 2017|回复: 0
两个独立按键单片机程序 控制静态数码管数字增加或减少
ID:860248 发表于 2021-1-14 01:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//静态数码管, 按下K1增加到F, 按下K2减少到0
#include "reg52.h"
typedef unsigned int u16;
typedef unsigned char u8;
sbit K1=P1^0;
sbit K2=P1^2;
unsigned int i=0;
signed int j=0;
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                     0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(u16 i)
while(i--);
void keypush1()
if (K1==0)
  delay(1000);
  if (K1==0)
   j++;
while(!K1);
void keypush2()
if (K2==0)
  delay(1000);
  if (K2==0)
   j--;
while(!K2);
void DigDisplay()
    P0=~smgduan[j];
  keypush1();
  if (j>15)
   j=15;
  keypush2();
  if (j<0)
   j=0;
     DigDisplay();
