查看: 2175|回复: 2
仿真LCD12864咋就点不亮呢?电路图应该没有问题吧
电路图应该没有问题吧,这个12864就是搞不亮?
在网上找个了程序该不该就是点不亮。
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add     0xb8//页地址
#define LCDCol_Add     0x40//列地址
#define Start_Line     0xC0//行地址
/*****液晶显示器的端口定义*****/
#define data_ora P0 /*液晶数据总线*/
sbit LCDMcs=P2^4 ;    /*片选1*/
sbit LCDScs=P2^3 ;    /*片选2*/
sbit LCDDi=P2^2 ;     /*数据/指令 选择*/
sbit LCDRW=P2^1 ;     /*读/写 选择*/
sbit LCDEnable=P2^0 ;     /*读/写 使能*/
unsigned char code Bmp1[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x20,0x24,0x24,0x24,0xE4,0x24,0x20,0x20,0xFE,0x20,0x24,0x28,0x20,
0x00,0x20,0xC2,0x0C,0x80,0x60,0x04,0x7C,0x84,0x04,0x04,0xC4,0x3E,0x04,0x00,0x00,
0x88,0x88,0xF8,0x88,0x88,0x00,0xFC,0x24,0x24,0xFC,0x24,0x24,0xFE,0x04,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x20,
0x20,0x20,0x20,0x20,0xFE,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x20,0x60,0x3F,0x20,0x20,0x1F,0x12,0x12,0x10,0x07,0x18,0x20,0x40,0x78,
0x00,0x04,0x04,0x7E,0x41,0x40,0x20,0x10,0x0B,0x04,0x0B,0x10,0x20,0x60,0x20,0x00,
0x10,0x30,0x1F,0x08,0x48,0x40,0x4B,0x49,0x49,0x7F,0x49,0x49,0x6B,0x40,0x08,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x40,0x40,
0x20,0x10,0x08,0x06,0x01,0x02,0x04,0x08,0x10,0x20,0x60,0x20,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp2[]=
0x00,0x80,0x40,0xF0,0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,
0x00,0x00,0x00,0xF8,0xA8,0xAC,0xAA,0xA8,0xA8,0xA8,0xFC,0x08,0x00,0x00,0x00,0x00,
0x08,0x08,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,
0xA4,0xFC,0x26,0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x40,0x30,0x10,
0x52,0x5C,0x50,0x52,0x5C,0x50,0xD8,0x56,0x10,0x50,0x30,0x00,0x00,0xFC,0x04,0x64,
0x9C,0x20,0x58,0x48,0x4A,0x4C,0x48,0x48,0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,
0x00,0x20,0x18,0x03,0x3A,0x42,0x46,0x5A,0x42,0x42,0x73,0x00,0x08,0x30,0x00,0x20,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,
0x01,0x7F,0x01,0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x04,0x04,0x04,
0x04,0x04,0x24,0x44,0x3F,0x05,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x7F,0x04,0x08,
0x47,0x41,0x21,0x1F,0x01,0x01,0x3F,0x41,0x41,0x79,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp3[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x42,
0xCC,0x00,0x00,0xF4,0x54,0x5C,0xF4,0x5C,0x56,0xF4,0x00,0x00,0x00,0x80,0x40,0xF0,
0x0E,0x00,0x28,0x28,0x28,0x2A,0x2C,0x28,0x28,0x28,0x08,0x00,0x00,0x08,0x08,0x08,
0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0x0C,0x08,0x00,0x00,0x20,0x24,0xA4,0xFC,0x26,
0x24,0x00,0x7C,0x24,0x24,0x24,0x24,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x10,
0x0F,0x10,0x20,0x5F,0x42,0x42,0x5F,0x42,0x52,0x5F,0x40,0x40,0x00,0x00,0x00,0x7F,
0x00,0x00,0x01,0x7D,0x25,0x25,0x25,0x25,0x7D,0x01,0x00,0x00,0x20,0x20,0x20,0x20,
0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x08,0x06,0x01,0x7F,0x01,
0x42,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp4[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,
0x20,0x10,0x10,0x30,0x00,0x00,0x44,0x44,0xFC,0x44,0x04,0xC0,0x00,0xFE,0x84,0x84,
0xFC,0x84,0x84,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x1F,
0x22,0x21,0x21,0x21,0x1E,0x00,0x10,0x10,0x0F,0x48,0x28,0x11,0x08,0x27,0x20,0x20,
0x3F,0x20,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
函数功能:LCD延时程序
入口参数:t
出口参数:
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
状态检查,LCD是否忙
void CheckState()
   unsigned char dat,DATA;//状态信息(判断是否忙)
   LCDDi=0; // 数据\指令选择,D/I(RS)="L" ,表示 DB7∽DB0 为显示指令数据
   LCDRW=1; //R/W="H" ,E="H"数据被读到DB7∽DB0
   do
      DATA=0x00;
      LCDEnable=1;        //EN下降源
          LCDdelay(2);//延时
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat; //仅当第7位为0时才可操作(判别busy信号)
    while(!(dat==0x00));
函数功能:写命令到LCD程序,RS(DI)=L,RW=L,EN=H,即来一个脉冲写一次
入口参数:cmdcode
出口参数:
void write_com(unsigned char cmdcode)
    CheckState();//检测LCD是否忙
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函数功能:LCD初始化程序
入口参数:
出口参数:
void init_lcd()
        LCDdelay(100);
        LCDMcs=1;//刚开始关闭两屏
        LCDScs=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);         //写初始化命令
        write_com(Page_Add+0);
        write_com(Start_Line+0);
        write_com(LCDCol_Add+0);
        write_com(LCDLCDDisp_On);
函数功能:写数据到LCD程序,RS(DI)=H,RW=L,EN=H,即来一个脉冲写一次
入口参数:LCDDispdata
出口参数:
void write_data(unsigned char LCDDispdata)
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
函数功能:清除LCD内存程序
入口参数:pag,col,hzk
出口参数:
void Clr_Scr()
        unsigned char j,k;
        LCDMcs=0; //左、右屏均开显示
        LCDScs=0;
         for(k=0;k<8;k++)//控制页数0-7,共8页
                write_com(Page_Add+k); //每页每页进行写
                  for(j=0;j<64;j++)  //每页最多可写32个中文文字或64个ASCII字符
                      write_com(LCDCol_Add+j);
                        write_data(0x00);//控制列数0-63,共64列,写点内容,列地址自动加1
函数功能:左屏位置显示
入口参数:page,column,hzk
出口参数:
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<64;i++)
                        write_data(Bmp[128*j+i]);
函数功能:右屏位置显示
出口参数:
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0; //左屏开显示
        LCDScs=1;
        Bmp_Left_Disp(0,0,Bmp1);// Bmp1为某个汉字的首地址
    Bmp_Left_Disp(2,0,Bmp2);
    Bmp_Left_Disp(4,0,Bmp3);
    Bmp_Left_Disp(6,0,Bmp4);
    LCDMcs=1; //右屏开显示
        LCDScs=0;
    Bmp_Right_Disp(0,0,Bmp1);
    Bmp_Right_Disp(2,0,Bmp2);
    Bmp_Right_Disp(4,0,Bmp3);
    Bmp_Right_Disp(6,0,Bmp4);
ID:706567 发表于 2021-1-16 15:52 | 只看该作者
那位大神帮我写个简单的测试程序。
ID:390416 发表于 2021-1-17 08:22 | 只看该作者
你好,你可以看看我分享的贴子 先把手册看懂http://www.51hei.com/bbs/dpj-200462-1.html
