查看: 2427|回复: 0
51单片机外部中断测马达转速,数码管显示
ID:803227 发表于 2021-1-21 14:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit COM1 = P2^0;
sbit COM2 = P1^6;
sbit COM3 = P1^5;
sbit COM4 = P1^3;
sbit COM5 = P1^4;
sbit COM6 = P1^7;
bit flag200ms;
unsigned char T0RH;
unsigned char T0RL;
unsigned int Cnt;
unsigned char LedBuff[6] = {0x28,0x28,0x28,0x28,0x28,0x28};
unsigned char code LedChar[10] =
        0x28, 0xEE, 0x58, 0x4A, 0x8E,
        0x0B, 0x09, 0x6E, 0x08, 0x0A
void ConfigTimer0(unsigned int ms);
void LedScan();
void InitCPU();
void SpeedCount();
        InitCPU();
        ConfigTimer0(1);
        while (1)
          if (flag200ms)         //200ms更新一次转速
             flag200ms = 0;
             SpeedCount();
void InitCPU()
        P1 = 0x03;          //COM输出低电平,数码管不亮
        COM1 = 0;
        PEDGE = 0x03;   // Both edge trigger
        EX0 = 1;            // Enable INT0 interrupt
        EAL = 1;            // Enable all interrupt
void SpeedCount()
        float rmp;
        unsigned int RMP;
        unsigned int Temp;
        EX0 = 0;                       //关闭外部中断0
        Temp = Cnt;                    //读取200ms外部中断信号数量
        rmp = (float)Temp;             //转为浮点运算
        rmp = rmp / 12;                //马达转一圈有12个外部中断信号(6对磁环)
        rmp = (rmp + 0.05) * 100;      //四舍五入保留2位小数
        RMP = (unsigned int)rmp;       //转回整型数
        RMP = RMP * 3;                 //200ms * (5 * 60) = 每分钟转速,再除以100以抵消前面保留的2位小数
        if (RMP <= 15)                 //无转速时清零
                RMP = 0;
        LedBuff[0] = LedChar[RMP%10];     //数码管第6位
        LedBuff[1] = LedChar[RMP/10%10];    //数码管第5位
        LedBuff[2] = LedChar[RMP/100%10];    //数码管第4位
        LedBuff[3] = LedChar[RMP/1000%10];    //数码管第3位
        LedBuff[4] = LedChar[RMP/10000%10];    //数码管第2位
        LedBuff[5] = LedChar[RMP/100000%10];    //数码管第1位
        Cnt = 0;                       //中断信号数量清零
        EX0 = 1;                       //重新打开外部中断0
void LedScan()                   //数码管扫描
        static unsigned char i;
        P0 = 0xFF;                   //清SEG
        switch (i)                     //6位数码管扫描
                case 0:COM6=0; COM1=1; P0 = LedBuff[5]; i++;break;
                case 1:COM1=0; COM2=1; P0 = LedBuff[4]; i++;break;
                case 2:COM2=0; COM3=1; P0 = LedBuff[3]; i++;break;
                case 3:COM3=0; COM4=1; P0 = LedBuff[2]; i++;break;
                case 4:COM4=0; COM5=1; P0 = LedBuff[1]; i++;break;
                case 5:COM5=0; COM6=1; P0 = LedBuff[0]; i=0;break;
                default: break;
void ConfigTimer0(unsigned int ms)                     //配置定时器0
        unsigned long tmp;
        tmp = 12000000/12;
        tmp = (tmp * ms)/1000;
        tmp = 65536 - tmp;
        tmp = tmp + 12;
        T0RH = (unsigned char)(tmp >> 8);
        T0RL = (unsigned char)tmp;
        TMOD &= 0xF0;
        TMOD |= 0x01;                                        //工作方式1
        TH0 = T0RH;
        TL0 = T0RL;
        ET0 = 1;
        TR0 = 1;
void InterruptTimer0() interrupt ISRTimer0         //定时器0中断
        static unsigned char j;
        TH0 = T0RH;
        TL0 = T0RL;
        i++;
        if (i >= 200)
                i = 0;
                flag200ms = 1;
        LedScan();                                //数码管扫描
void InterruptInt0() interrupt ISRInt0                         //外部中断2
        Cnt++;                                    //中断信号数量累加
