查看: 2055|回复: 0
lcd12864测试程序 适合stc89c52rc
ID:812531 发表于 2021-1-25 23:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define LCD_data P0
sbit LCD_RS=P1^0;
sbit LCD_RW=P1^1;
sbit LCD_EN=P2^5;
sbit LCD_PSB=P1^3;
sbit dula=P2^0;
sbit wela=P2^1;
sbit cs88=P2^2;
sbit key=P3^4;
void delayms(unsigned int xms)
  unsigned i,j;
         for(i=xms;i>0;i--)
            for(j=110;j>0;j--);
void cmg88()
dula=0;
        P0=0x00;
        dula=0;
        cs88=0x00;
        P0=0x00;
#define delayNOP();{_nop_();_nop_();_nop_();_nop_();};
uchar IRDIS[2] ;
uchar IRCOM[4] ;
void delay0 (uchar x); //x*0.14MS
void beep();
void dataconv() ;
void lcd_pos(uchar X,uchar Y);
void delay(int ms)
while (ms--)
uchar i;
for (i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
bit lcd_busy()
bit result ;
LCD_RS=0;
LCD_RW=1;
LCD_EN=1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN=0;
return (result) ;
void lcd_wcmd(uchar cmd)
while(lcd_busy()) ;
LCD_RS=0;
LCD_RW=0;
LCD_EN=0;
_nop_();
_nop_();
P0=cmd;
delayNOP ()
LCD_EN=1;
delayNOP ()
LCD_EN=0;
void lcd_wdat(uchar dat)
while(lcd_busy()) ;
LCD_RS=1;
LCD_RW = 0;
LCD_EN=0;
P0=dat;
delayNOP () ;
LCD_EN=1;
delayNOP ();
LCD_EN=0;
void gotoxy(unsigned char y, unsigned char x,uchar *str)
        if(y==1)
                lcd_wcmd(0x80|x);
        if(y==2)
        lcd_wcmd(0x90|x);
        if(y==3)
                lcd_wcmd((0x80|x)+8);
        if(y==4)
      lcd_wcmd((0x90|x)+8);
                                  while(*str!='\0')
                lcd_wdat(*str);
                str++;
void print(uchar *str)
        while(*str!='\0')
                lcd_wdat(*str);
                str++;
void lcd_init()
LCD_PSB=1;
lcd_wcmd(0x34) ;
delay(5) ;
lcd_wcmd(0x30) ;
delay(5) ;
lcd_wcmd(0x0c) ;
delay(5) ;
lcd_wcmd(0x01) ;
delay(5) ;
main()
        unsigned char i;
lcd_init();
        //lcd_wcmd(0x80+7);
        //lcd_wdat('0'+i);
        //delayms(5);
        //if(key==0)
                //delayms(5);
        //        if(key==0)
//        i=3;
        //        while(!key);
        gotoxy(3,0,"考研路上不孤单");
