查看: 3074|回复: 0
LCD1602显示字符“A”.压缩包里面有源代码和仿真原理图
#include<reg51.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit BF=P0^7;
void delay_us(uint i)
  while(--i);
void delay1ms()
   unsigned char i,j;
         for(i=0;i<10;i++)
          for(j=0;j<33;j++)
void delay_ms(uchar n)
   uchar i;
        for(i=0;i<n;i++)
           delay1ms();
unsigned char BusyTest(void)
    bit result;
        RS=0;
    RW=1;
    E=1;
        delay_us(4)
    result=BF;
        E=0;
    return result;
void Write_order_add (unsigned char dictate)
    while(BusyTest()==1)
         RS=0;
         RW=0;
         E=0;
     delay_us(2);
         P0=dictate;
         delay_us(4)
         E=1;
         delay_us(4);
          E=0;
void WriteData(unsigned char y)
    while(BusyTest()==1);
          RS=1;
          RW=0;
          E=0;
          P0=y;
                delay_us(4);
        delay_us(4);
         E=0;
void LcdInit(void)
   delay_ms(15);
    Write_order_add(0x38);
   delay_ms(5);
   delay_ms(5);
   delay_ms(5);
   Write_order_add(0x0E);
   delay_ms(5);
   Write_order_add(0x06);
   delay_ms(5);
   Write_order_add(0x01)
   delay_ms(5);
void main(void)
{        uchar i;
  LcdInit();
  Write_order_add(0xC7);
  WriteData('A');
仿真原理图
仿真原理图
LCD1602A(单个字符“A“显示).rar
60.62 KB, 下载次数: 15, 下载积分: 黑币 -5
源代码+仿真原理图
