查看: 1610|回复: 0
求助单片机蓝牙触控灯的程序问题
我接了一个灯试了,蓝牙没用,是不是程序哪里出了问题?
#include <reg52.h>
#include <stdio.h>
#include "lcd1602.h"
//ADC0809
sbit CLK=P3^4;
sbit ST=P3^5;
sbit EOC=P3^6;
sbit OE=P3^7;
sbit RELAY = P3^3;
unsigned int pass = 0;
unsigned int ADCshow;
unsigned char pressure = 50;
unsigned char mode=0;
unsigned char status = 0;
void delay(unsigned int s)
        while(s--);
void DelayMS(unsigned int ms)
         unsigned char i;
        while(ms--)
                 for(i=0;i<120;i++);
void Timer0_INT() interrupt 1
        TH0=(65536-200)/256;
        TL0=(65536-200)%256;
        CLK=~CLK;
void UART_init()    //设置串行通信 本晶振为11.0592MHZ,其他的就自己算一下应该设置多少
      TMOD = 0x20;
      TH1 = 0xfd;
      TL1 = 0xfd;  //波特率9600
      SM0 = 0;
      SM1 = 1;   // 串口工作方式1 10位异步
      REN = 1;  //串口允许接收
      TR1 = 1;
      EA = 1;
      ES =1 ;  //串口中断
void main(void)
          RELAY=1;  //关灯
          UART_init();
      lcd_init(); //初始化1602
                TMOD=0x01; //设置定时器0
                TH0=(65536-200)/256; //初值重装
        EA=1;  //开总中断
                ET0=1;  //开定时器中断
                TR0=1;   //开定时器0
                        //adc0809读取数据
                                                ST=0;
                                                OE=0;
                                                ST=1;
                                                ST=0;
                                                while(EOC==0);
                                                OE=1;
                                                ADCshow=P1;
                                                OE=0;
     //lcd1602显示压力传感器值
                                        LCD_ShowStr(0,0,"Real:");
                                        LCD_ShowChar(5,0,ADCshow/100+'0');
                                        LCD_ShowChar(6,0,ADCshow%100/10 +'0');
                                  LCD_ShowChar(7,0,ADCshow%10 +'0');
                                if(ADCshow<pressure||pass==0x11)
                                   RELAY=0;  //亮灯
                                {  //否则
                                         RELAY=1; //灭灯
void UART_INTERRUPT() interrupt 4
              pass = SBUF;
              RI = 0;
              SBUF = pass;  )
              while(!TI);
              TI = 0;
