查看: 1517|回复: 0
PIC18F25K83单片机引用MCC的EEPROM例程无法实现功能。
ID:558923 发表于 2021-3-2 08:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序如下。写入后读取结果为0xff
// CONFIG1L
#pragma config FEXTOSC = HS     // External Oscillator Selection (HS (crystal oscillator) above 8 MHz; PFM set to high power)
#pragma config RSTOSC = EXTOSC_4PLL// Reset Oscillator Selection (EXTOSC with 4x PLL, with EXTOSC operating per FEXTOSC bits)
// CONFIG1H
#pragma config CLKOUTEN = OFF   // Clock out Enable bit (CLKOUT function is disabled)
#pragma config PR1WAY = ON      // PRLOCKED One-Way Set Enable bit (PRLOCK bit can be cleared and set only once)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
// CONFIG2L
#pragma config MCLRE = EXTMCLR  // MCLR Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR )
#pragma config PWRTS = PWRT_OFF // Power-up timer selection bits (PWRT is disabled)
#pragma config MVECEN =OFF     // Multi-vector enable bit (Multi-vector enabled, Vector table used for interrupts)
#pragma config IVT1WAY = ON     // IVTLOCK bit One-way set enable bit (IVTLOCK bit can be cleared and set only once)
#pragma config LPBOREN = OFF    // Low Power BOR Enable bit (ULPBOR disabled)
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled , SBOREN bit is ignored)
// CONFIG2H
#pragma config BORV = VBOR_2P45 // Brown-out Reset Voltage Selection bits (Brown-out Reset Voltage (VBOR) set to 2.45V)
#pragma config ZCD = OFF        // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON     // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config DEBUG = OFF       // Debugger Enable bit (Background debugger enabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled)
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31// WDT Period selection bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled; SWDTEN is ignored)
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4L
#pragma config BBSIZE = BBSIZE_512// Boot Block Size selection bits (Boot Block size is 512 words)
#pragma config BBEN = OFF       // Boot Block enable bit (Boot block disabled)
#pragma config SAFEN = OFF      // Storage Area Flash enable bit (SAF disabled)
#pragma config WRTAPP = OFF     // Application Block write protection bit (Application Block not write protected)
// CONFIG4H
#pragma config WRTB = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected)
#pragma config WRTC = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF      // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
#pragma config WRTSAF = OFF     // SAF Write protection bit (SAF not Write Protected)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored)
// CONFIG5L
#pragma config CP = OFF        // PFM and Data EEPROM Code Protection bit (PFM and Data EEPROM code protection disabled)
// CONFIG5H
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdbool.h>
#include <stdint.h>
//#define  uint8 unsigned char
//#define uint8_t unsigned char
//#define uint16_t unsigned short
void DATAEE_WriteByte(uint16_t bAdd, uint8_t bData);//EEPROM???
uint8_t DATAEE_ReadByte(uint16_t bAdd);   //EEPROM???
    uint8_t GIEBitValue = INTCON0bits.GIE;
    NVMADRH = (uint8_t)((bAdd >> 8) & 0x03);
    NVMADRL = (uint8_t)(bAdd & 0xFF);
    NVMDAT = bData;
    NVMCON1bits.NVMREG = 0;
    NVMCON1bits.WREN = 1;
    INTCON0bits.GIE = 0;     // Disable interrupts
    NVMCON2 = 0x55;
    NVMCON2 = 0xAA;
    NVMCON1bits.WR = 1;
  //   Wait for write to complete
    while (NVMCON1bits.WR)
    NVMCON1bits.WREN = 0;
    INTCON0bits.GIE = GIEBitValue;   // restore interrupt enable
    NVMCON1bits.RD = 1;
    NOP();  // NOPs may be required for latency at high frequencies
    NOP();
    return (NVMDAT);
void main(void) //???
  //  TRISC3 = 0;//PORTD???
//   LATC3=0;
    TRISB7 = 0;//PORTD???
    LATB7=0;
//   unsigned int hh=12000;
    uint8_t qq=0x00;
  //  while(hh--);LATB7=1;
    uint16_t dataeeAddr = 0x30;
    uint8_t dataeeData = 0x50;
    DATAEE_WriteByte(dataeeAddr, dataeeData);
  qq = DATAEE_ReadByte(dataeeAddr);
    if(qq==0xff)
  { //LATC3=1;
   LATB7=1;
  }else//if(qq==0x50)
  { // LATC3=0;
   LATB7=0;
    while(1){
