查看: 1989|回复: 0
单片机红外遥控模拟程序
ID:887750 发表于 2021-3-2 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <AT89X51.h>
static bit OP;        //红外发射管的亮灭
static unsigned int count;       //延时计数器
static unsigned int endcount; //终止延时计数
static unsigned char Flag;      //红外发送标志
char iraddr1;  //十六位地址的第一个字节
char iraddr2;  //十六位地址的第二个字节
void SendIRdata(char p_irdata);
void delay();
char getkey()
          P1=0xfe;P3_6=P3_7=1;P3_3=1;
          if(!P1_4)return 1;   //ON
          if(!P1_5)return 2;   //7
          if(!P1_6)return 3;   //8
          if(!P1_7)return 4;   //9
          if(!P3_6)return 5;   //X
          if(!P3_7)return 6;   //÷
          P1=0xfd;
          if(!P1_4)return 11; //+-
          if(!P1_5)return 12; //4
          if(!P1_6)return 13; //5
          if(!P1_7)return 14; //6
          if(!P3_6)return 15; //-
          if(!P3_7)return 16; //MRC
          P1=0xfb;
          if(!P1_4)return 21; //%
          if(!P1_5)return 22; //1
          if(!P1_6)return 23; //2
          if(!P1_7)return 24; //3
          if(!P3_6)return 25; //+
          if(!P3_7)return 26; //M-
          P1=0xf7;
          if(!P1_4)return 31; //□
          if(!P1_5)return 32; //0
          if(!P1_6)return 33; //.
          if(!P1_7)return 34; //=
          if(!P3_6)return 35; //+
          if(!P3_7)return 36; //M+
          P1=0xfF;P3_3=0;
          if(!P1_4)return 41; //
          if(!P1_5)return 42; //
          if(!P1_6)return 43; //
          if(!P1_7)return 44; //
          if(!P3_6)return 45; //
          if(!P3_7)return 46; //
          return 0;
void main(void)
  char key;
  count = 0;
  Flag = 0;
  OP = 0;
  P3_4 = 1;
  EA = 1; //允许CPU中断
  TMOD = 0x11; //设定时器0和1为16位模式1
  ET0 = 1; //定时器0中断允许
  P1=0xff;
  TH0 = 0xFF;
  TL0 = 0xE6; //设定时值0为38K 也就是每隔26us中断一次
  TR0 = 1;//开始计数
  iraddr1=0xff;
  iraddr2=0xff;
  do{
          key=getkey();
      if(key==1)SendIRdata(0x12);//set
      if(key==11)SendIRdata(0x0b);//exit
      if(key==25||key==35)SendIRdata(0x1a);//+
      if(key==15)SendIRdata(0x1e);//-
      if(key==6)SendIRdata(0x0e);//↑ ÷
      if(key==16)SendIRdata(0x1d);//↓ MRC
      if(key==26)SendIRdata(0x1f);//← M-
      if(key==36)SendIRdata(0x1b);//→ M+
      if(key==32)SendIRdata(0x00);//0
      if(key==22)SendIRdata(0x01);//1
      if(key==23)SendIRdata(0x02);//2
      if(key==24)SendIRdata(0x03);//3
      if(key==12)SendIRdata(0x04);//4
      if(key==13)SendIRdata(0x05);//5
      if(key==14)SendIRdata(0x06);//6
      if(key==2)SendIRdata(0x07);//7
      if(key==3)SendIRdata(0x08);//8
      if(key==4)SendIRdata(0x09);//9
      if(key==21)SendIRdata(0x2A);//%
      if(key==5)SendIRdata(0x2B);//X
      if(key==33)SendIRdata(0x2C);//.
      if(key==34)SendIRdata(0x2D);//=
      if(key==31)SendIRdata(0x2E);//□
      if(key==41)SendIRdata(0x2F);//
      if(key==42)SendIRdata(0x30);//
      if(key==43)SendIRdata(0x31);//
      if(key==44)SendIRdata(0x32);//
      if(key==45)SendIRdata(0x33);//
      if(key==46)SendIRdata(0x34);//
  }while(1);
//定时器0中断处理
void timeint(void) interrupt 1
  TH0=0xFF;
  TL0=0xE6; //设定时值为38K 也就是每隔26us中断一次
  count++;
  int i;
  char irdata=p_irdata;
  //发送9ms的起始码
  endcount=223;
  Flag=1;
  count=0;
  P3_4=0;
  do{}while(count<endcount);
  //发送4.5ms的结果码
  endcount=117;
  Flag=0;
  count=0;
  P3_4=1;
  //发送十六位地址的前八位
  irdata=iraddr1;
  for(i=0;i<8;i++)
     //先发送0.56ms的38KHZ红外波(即编码中0.56ms的低电平)
     endcount=10;
     Flag=1;
     count=0;
         P3_4=0;
    //停止发送红外信号(即编码中的高电平)
     if(irdata-(irdata/2)*2)  //判断二进制数个位为1还是0
       endcount=15;  //1为宽的高电平
     endcount=41;   //0为窄的高电平
    Flag=0;
    count=0;
        P3_4=1;
    irdata=irdata>>1;
  //发送十六位地址的后八位
  irdata=iraddr2;
  for(i=0;i<8;i++)
     endcount=10;
     Flag=1;
     count=0;
         P3_4=0;
        endcount=15;
       endcount=41;
     Flag=0;
     count=0;
         P3_4=1;
     irdata=irdata>>1;
  //发送八位数据
  irdata=~p_irdata;
  for(i=0;i<8;i++)
     endcount=10;
     Flag=1;
     count=0;
         P3_4=0;
         endcount=15;
       endcount=41;
     Flag=0;
     count=0;
         P3_4=1;
     irdata=irdata>>1;
  //发送八位数据的反码
  irdata=p_irdata;
  for(i=0;i<8;i++)
     endcount=10;
     Flag=1;
     count=0;
         P3_4=0;
         endcount=15;
       endcount=41;
     Flag=0;
     count=0;
         P3_4=1;
     irdata=irdata>>1;
  endcount=10;
  Flag=1;
  count=0;
  P3_4=0;
  P3_4=1;
  Flag=0;
void delay()
  int i,j;
  for(i=0;i<400;i++)
    for(j=0;j<100;j++)
