查看: 5772|回复: 1
STM32超声波测距程序原理图PCB资料
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "timer.h"
  5. #include "HCSR04.h"
  6. #include "led.h"
  7. #include "beep.h"
  8. #include "key.h"
  9. #include "lcd1602.h"
  10. #include "stmflash.h"  //包含头文件
  11. unsigned long S=0; //定义超声数据
  12. #define FLASH_SAVE_ADDR  0X0800FF00                //设置FLASH 保存地址(必须为偶数,且其值要大于本代码所占用FLASH的大小+0X08000000)
  13. extern unsigned long Clock_time;
  14. unsigned char Send_flag=0;
  15. extern u8  TIM3CH1_CAPTURE_STA;                //输入捕获状态
  16. extern u16        TIM3CH1_CAPTURE_VAL;        //输入捕获值
  17. u16 fls[4];
  18. u8 k=0;
  19. u32 TL=50;
  20. u8 beep1;
  21. u8 t=0;
  22. void key() //按键函数
  23. {
  24.         k=KEY_Scan(1); //按键扫描的值给K
  25.         if(k == KEY0_PRES) //如果K等于  KEY0_PRES,就说明是按下加按键
  26.         {
  27.                 TL++;     //数据加一,如果大于400,则减一,保持最大400
  28.                 if(TL>400)
  29.                         TL--;
  30.                 fls[0]=TL;
  31.                 STMFLASH_Write(FLASH_SAVE_ADDR,(u16*)fls,1); //存储
  32.         }
  33.
  34.         if(k == KEY1_PRES)//同上,不过是减
  35.         {
  36.                 TL--;
  37.                 if(TL<5)
  38.                         TL++;
  39.                 fls[0]=TL;
  40.                 STMFLASH_Write(FLASH_SAVE_ADDR,(u16*)fls,1);
  41.         }
  42.
  43. }
  44. void ceju()
  45. {
  46.         Trig=1;
  47.         delay_us(20);
  48.         Trig=0;              //启动信号
  49.         S=0;                     //清零距离数据
  50.         Clock_time=0;
  51.         TIM_Cmd(TIM3, DISABLE);  //关定时器,清零计时变量
  52.         while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)); //等待检测到高电平
  53.         Clock_time=0;
  54.         TIM_Cmd(TIM3, ENABLE);  //开定时器
  55.         while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)==1&&Clock_time<47058);  //只要是高,一直算时间,如果时间计数超过 47058,所说有问题,直接跳过,47058不一定精确,是一个大概值,
  56.         S=((Clock_time*2)*340/10000)/2;   //时间变量是2us加一,乘以速度,因为时间是us,换成秒是除以1000000,保留两位小数,所以除以 10000,然后除以二得到单方面距离
  57.         TIM_Cmd(TIM3, DISABLE);  //关定时器
  58.         Clock_time=0;            //清零数据
  59.         printf("Distance:%d cm\r\n",S);//打印总的高点平时间
  60. }
  61. void show()
  62. {
  63.         LCD1602_Show_Str(0,0,"Distance:");    //显示
  64.         if(S>=100&&S<=400) LCD1602_Write_Dat(S/100%10+0x30); //这里是测速数据
  65.         else LCD1602_Show_Str(9,0," ");
  66.         if(S>=10) LCD1602_Write_Dat(S/10%10+0x30);
  67.         else LCD1602_Show_Str(10,0," ");
  68.         LCD1602_Write_Dat(S%10+0x30);
  69.         LCD1602_Show_Str(12,0,"cm      ");
  70.
  71.         LCD1602_Show_Str(0,1,"alarm  :"); //这里开始显示报警数据,下面这三段,其实就是判断阈值数据是百位数还是十位数还是个位数,如果是个位数,显示个位数据,百位十位显示空
  72.         if(TL>=100&&TL<=400)
  73.         {
  74.                 LCD1602_Write_Dat(TL/100%10+0x30);
  75.                 LCD1602_Write_Dat(TL/10%10+0x30);
  76.                 LCD1602_Write_Dat(TL%10+0x30);
  77.                 LCD1602_Show_Str(12,1,"cm      ");
  78.         }
  79.
  80.    if(TL>=10&&TL<100)
  81.         {
  82.                 LCD1602_Show_Str(9,1," ");
  83.                 LCD1602_Write_Dat(TL/10%10+0x30);
  84.                 LCD1602_Write_Dat(TL%10+0x30);
  85.                 LCD1602_Show_Str(12,1,"cm      ");
  86.         }
  87.         if(TL>0&&TL<10)
  88.         {
  89.                 LCD1602_Show_Str(9,1," ");
  90.                 LCD1602_Show_Str(10,1," ");
  91.                 LCD1602_Write_Dat(TL%10+0x30);
  92.                 LCD1602_Show_Str(12,1,"cm      ");
  93.         }
  94. }
  95. void problem()  //报警函数
  96. {
  97.         if(S<TL)     //小于阈值,蜂鸣器开始响,对应指示灯亮,否则蜂鸣器不响
  98.         {
  99.                 beep1=1;
  100.                 LED1=1;
  101.         }
  102.         else
  103.         {
  104.                 beep1=0;
  105.                 LED1=0;
  106.                 LED0=1;
  107.         }
  108. }
  109. int main(void)
  110. {
  111.         u16 datatemp[1];
  112.         BEEP_Init();
  113.         KEY_Init();
  114.         delay_init();                     //延时函数初始化
  115.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  116.         uart_init(115200);         //串口初始化为115200
  117.         LED_Init();                             //LED端口初始化
  118.         UltrasonicWave_Configuration();  //初始化超声IO
  119.         TIM3_Cap_Init(1,72-1);        //以1Mhz的频率计数,第一个选项,最小只能是1
  120.         LCD1602_Init();
  121.         STMFLASH_Read(FLASH_SAVE_ADDR,(u16*)datatemp,1);
  122.         TL=datatemp[0];
  123.         if(TL<5||TL>400)
  124.         TL=50;
  125.         ceju();
  126.         printf("Distance"); //串口打印一下,调试用
  127.   while(1)
  128.         {
  129.                 if(beep1==1) //如果蜂鸣器标志等于1,则开始滴滴叫,指示灯也是闪烁
  130.                 {
  131.                         BEEP=!BEEP;
  132.                         LED0=!LED0;
  133.
  134.                 }
  135.                         else
  136.                                 BEEP=0;
  137.                 show();   //调用显示函数
  138.                 key();    //调用按键函数
  139.                 problem();//调用报警处理函数
  140.                 t++;      //变量自加,加到5的时候,对5取余会等于0,则启动一次测距函数
  141.                 if(t%5==0)
  142.                 {
  143.                         t=0;
  144.                         ceju();
  145.                 }
  146.         }
  147. }
全部资料51hei下载地址:
STM32 超声波测距完整资料.7z (343.7 KB, 下载次数: 116)
收藏收藏7 分享淘帖 顶顶1 踩踩
ID:1083442 发表于 2023-6-28 20:41 | 只看该作者
只有初始距离0和闹钟5cm,超声波无作用
