查看: 2497|回复: 0
单片机RC522测试程序资料
ID:873415 发表于 2021-3-11 20:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. /**********************RC522实验开发板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ******************************************************************/
  5. //实验目的:
  6. /*-----------------------------------------------
  7.   名称:MF RC522
  8.   内容:通过标准程序静态显示字符
  9.   引脚定义如下:
  10. sbit     MF522_NSS  = P1^7;                        //SDA
  11. sbit     MF522_SCK  = P1^6;
  12. sbit     MF522_SI   = P1^5;
  13. sbit     MF522_SO   = P1^4;
  14. sbit     MF522_RST  = P1^3;
  15. //蜂鸣器OR指示灯
  16. sbit     LED_GREEN  =    P2^3;
  17. ------------------------------------------------*/
  18. #include "lpcreg.h"
  19. #include "main.h"
  20. #include "mfrc522.h"
  21. #include   <STDIO.H>
  22. #include <string.h>
  23. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  24. //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
  25. //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  26. unsigned char code data2[4]  = {0,0,0,0x01};
  27. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  28. unsigned char g_ucTempbuf[20];
  29. void delay1(unsigned int z)
  30. {
  31.         unsigned int x,y;
  32.         for(x=z;x>0;x--)
  33.         for(y=110;y>0;y--);
  34. }
  35. void main( )
  36. {
  37.      unsigned char status,i;
  38.           unsigned int temp;
  39.      InitializeSystem( );
  40.      PcdReset();
  41.      PcdAntennaOff();
  42.      PcdAntennaOn();
  43.      while ( 1 )
  44.      {
  45.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  46.          if (status != MI_OK)
  47.          {
  48.               InitializeSystem( );
  49.      PcdReset();
  50.      PcdAntennaOff();
  51.      PcdAntennaOn();
  52.                           continue;
  53.          }
  54.
  55.                         printf("卡的类型:");
  56.             for(i=0;i<2;i++)
  57.                                         {
  58.                                                 temp=g_ucTempbuf[i];
  59.                                                 printf("%X",temp);
  60.
  61.                                         }
  62.
  63.          status = PcdAnticoll(g_ucTempbuf);//防冲撞
  64.          if (status != MI_OK)
  65.          {    continue;    }
  66.                                         ////////以下为超级终端打印出的内容////////////////////////
  67.
  68.                                         printf("卡序列号:");        //超级终端显示,
  69.                                         for(i=0;i<4;i++)
  70.                                         {
  71.                                                 temp=g_ucTempbuf[i];
  72.                                                 printf("%X",temp);
  73.
  74.                                         }
  75.                                         ///////////////////////////////////////////////////////////
  76.          status = PcdSelect(g_ucTempbuf);//选定卡片
  77.          if (status != MI_OK)
  78.          {    continue;    }
  79.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  80.          if (status != MI_OK)
  81.          {    continue;    }
  82.          status = PcdWrite(1, data1);//写块
  83.          if (status != MI_OK)
  84.          {    continue;    }
  85. while(1)
  86.                 {
  87.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  88.          if (status != MI_OK)
  89.          {
  90.                   InitializeSystem( );
  91.      PcdReset();
  92.      PcdAntennaOff();
  93.      PcdAntennaOn();
  94.                           continue;
  95.          }
  96.                  status = PcdAnticoll(g_ucTempbuf);//防冲撞
  97.          if (status != MI_OK)
  98.          {    continue;    }
  99.                 status = PcdSelect(g_ucTempbuf);//选定卡片
  100.          if (status != MI_OK)
  101.          {    continue;    }
  102.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  103.          if (status != MI_OK)
  104.          {    continue;    }
  105.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  106.          if (status != MI_OK)
  107.          {    continue;    }
  108.
  109.          status = PcdBakValue(1, 2);//块备份
  110.          if (status != MI_OK)
  111.          {    continue;    }
  112.          status = PcdRead(2, g_ucTempbuf);//读块
  113.          if (status != MI_OK)
  114.          {    continue;    }
  115.                 printf("卡读块:");        //超级终端显示,
  116.          for(i=0;i<16;i++)
  117.                                         {
  118.                                                 temp=g_ucTempbuf[i];
  119.                                                 printf("%X",temp);
  120.
  121.                                         }
  122.                  printf("\n");
  123.                 LED_GREEN = 0;
  124.                 delay1(100);
  125.                 LED_GREEN = 1;
  126.                 delay1(100);
  127.                 LED_GREEN = 0;
  128.                 delay1(200);
  129.                 LED_GREEN = 1;
  130.                  PcdHalt();
  131.                 }
  132.     }
  133. }
  134. /////////////////////////////////////////////////////////////////////
  135. //系统初始化
  136. /////////////////////////////////////////////////////////////////////
  137. void InitializeSystem()
  138. {
  139.         P0M1 = 0x0; P0M2 = 0x0;
  140.         P1M1 = 0x0;        P1M2 = 0x0;
  141.         P3M1 = 0x0; P3M2 = 0xFF;
  142.         P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  143.          TMOD=0x21;                   //设T0为方式1,GATE=1;
  144.         SCON=0x50;
  145.         TH1=0xFa;          //波特率为4800bps
  146.         TL1=0xFa;
  147.         TH0=0;
  148.         TL0=0;
  149.         TR0=1;
  150.         ET0=1;             //允许T0中断
  151.         TR1=1;                           //开启定时器
  152.         TI=1;
  153.         EA=1;                                   //开启总中断
  154.
  155.         ES = 1;
  156.         RI = 1;
  157. }
MSP430F149读卡号参考例程.rar
76.79 KB, 下载次数: 8, 下载积分: 黑币 -5
TIDZ-RC522读卡模块使用说明.pdf
306.33 KB, 下载次数: 6, 下载积分: 黑币 -5
51读写卡参考例程及上位机调试软件.rar
764.06 KB, 下载次数: 14, 下载积分: 黑币 -5
SG-RC522射频模块原理图.pdf
37.43 KB, 下载次数: 13, 下载积分: 黑币 -5
RC522测试程序_20140411173219.rar
104.75 KB, 下载次数: 14, 下载积分: 黑币 -5
收藏收藏 分享淘帖 顶顶 踩踩1
