查看: 2638|回复: 0
基于C51单片机计算器
ID:893195 发表于 2021-3-17 19:36 | 显示全部楼层 |阅读模式
功能:
可以对两个整数进行加减乘除运算。
proteus图
proteus图
程序:
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar dis[]="0123456789+-*/=",K;
  5. uint AA,BB;
  6. long int CC;
  7. uchar FH=0;
  8. bit end=0;
  9. sbit EN=P1^2;
  10. sbit RS=P1^0;
  11. sbit RW=P1^1;
  12. void  delay(uchar t)
  13. {
  14.     uchar  i;
  15.     while(t--)
  16.     for(i=0;i<123;i++);
  17. }
  18. void  wcmd(uchar  cmd)
  19. {
  20.     RS=0;
  21.     RW=0;
  22.     P0=cmd;
  23.     delay(5);
  24.     EN=1;
  25.     delay(5);
  26.     EN=0;
  27.     delay(5);
  28. }
  29. void  wdat(uchar  dat)
  30. {
  31.     RS=1;
  32.     RW=0;
  33.     P0=dat;
  34.     delay(5);
  35.     EN=1;
  36.     delay(5);
  37.     EN=0;
  38.     delay(5);
  39. }
  40. void  init()
  41. {
  42.     EN=0;
  43.     wcmd(0x06);
  44.     delay(5);
  45.     wcmd(0x38);
  46.     delay(5);
  47.     wcmd(0x0e);
  48.     delay(5);
  49.     wcmd(0x01);
  50.     delay(5);
  51. }
  52. void cal() //计算
  53. {   long int temp;char a[12],i,j;
  54.     switch(FH)
  55.     {
  56.      case 1:CC=AA+BB;break;
  57.      case 2:if(AA>=BB)CC=AA-BB;else {wdat('-');CC=BB-AA;}break;
  58.      case 3:CC=AA*BB;break;
  59.      case 4:CC=AA/BB;break;
  60.     }
  61.   temp=CC;
  62.   for(j=0;temp!=0;j++)
  63.   {
  64.      a[j]=temp%10;
  65.      temp=temp/10;
  66.   }
  67.      for(i=j-1;i>=0;i--)
  68.      wdat(a[i]+'0');
  69.      AA=BB=CC=FH=0;
  70.      end=1;
  71. }
  72. uchar select()
  73. {
  74.     uchar ccode,rcode;
  75.     P3=0xf0;
  76.     if((P3&0xf0)!=0xf0)
  77.     {
  78.         delay(10);
  79.         if((P3&0xf0)!=0xf0) //去抖动误触后再次检测
  80.         {
  81.
  82.            rcode=0xfe;     //逐行扫描,从1.0开始
  83.            while((rcode&0x10)!=0)
  84.            {
  85.                P3=rcode;
  86.                if((P3&0xf0)!=0xf0)
  87.                {
  88.                    ccode=(P3&0xf0|0x0f);
  89.                    while((P3&0xf0)!=0xf0);//等待按键放开
  90.                    return ((~rcode)+(~ccode)); //返回键
  91.                }
  92.                else
  93.                rcode=(rcode<<1)|0x01;
  94.            }
  95.         }
  96.     }
  97.     return 0;
  98. }
  99. void  key_deal(unsigned  char  key)
  100. {
  101.     if(key!=0)
  102.     {   if(end==1)
  103.         {wcmd(0x01);end=0;}
  104.     switch(key)
  105.         {
  106.             case  0x11:  K=7;  break;
  107.            case  0x21:  K=8;  break;
  108.            case  0x41:  K=9;  break;
  109.            case  0x81:  K=15;FH=0;AA=BB=CC=0;wcmd(0x01);break;//
  110.            case  0x12:  K=4;  break;
  111.            case  0x22:  K=5;  break;
  112.            case  0x42:  K=6;  break;
  113.            case  0x82:  K=12;FH=3;  break;// *
  114.            case  0x14:  K=1;  break;
  115.            case  0x24:  K=2;  break;
  116.            case  0x44:  K=3;  break;
  117.            case  0x84:  K=13;FH=4;  break;// /
  118.            case  0x18:  K=10;FH=1; break;// +
  119.            case  0x28:  K=0;  break;
  120.            case  0x48:  K=11;FH=2;break;// -
  121.            case  0x88:  K=14;wdat(dis[K]);cal();break;//=
  122.            default:  break;      //不是以上数据时,跳出
  123.         }
  124.         if(K<14)
  125.         {
  126.            wdat(dis[K]);
  127.         }
  128.         if(K<10)
  129.         {
  130.            if(FH==0)
  131.            {
  132.                AA=AA*10+K;
  133.            }
  134.            else
  135.            {
  136.            BB=BB*10+K;
  137.            }
  138.         }
  139.     }
  140. }
  141. void  main()
  142. {
  143.     uchar  key;
  144.     init();
  145.     wcmd(0x80);
  146.     while(1)
  147.     {
  148.         key=select();
  149.         key_deal(key);
  150.     }
  151. }
