查看: 4366|回复: 1
tq2440 camera接口使用ov2640摄像头配置
ID:261837 发表于 2021-3-30 15:09 | 显示全部楼层 |阅读模式
ov2640寄存器是原子例程基础上修改的,程序是tq2440 ov9650裸跑程序改的。
主要是把摄像头设置为ycbcr422输出(因为2440只支持ITU601-656标准的8位ycbcr)。
刚开始傻傻的设置为rgb发现怎么调都无法出图像,仔细看了2440的camera接口时序才发现不支持rgb。
其实rgb也可以显示只是camera接口不支持,需要io口模拟时序。但是这样输出帧率较低而且图像不完整,想快只能使用硬件camera接口。
以下是主要配置 :
        0xff, 0x00,
        0x2c, 0xff,
        0x2e, 0xdf,
        0xff, 0x01,
        0x3c, 0x32,
        0x11, 0x00,
        0x09, 0x02,
        0x04, 0xD8,
        0x13, 0xe5,
        0x14, 0x48,
        0x2c, 0x0c,
        0x33, 0x78,
        0x3a, 0x33,
        0x3b, 0xfB,
        0x3e, 0x00,
        0x43, 0x11,
        0x16, 0x10,
        0x39, 0x92,
        0x35, 0xda,
        0x22, 0x1a,
        0x37, 0xc3,
        0x23, 0x00,
        0x34, 0xc0,
        0x36, 0x1a,
        0x06, 0x88,
        0x07, 0xc0,
        0x0d, 0x87,
        0x0e, 0x41,
        0x4c, 0x00,
        0x48, 0x00,
        0x5B, 0x00,
        0x42, 0x03,
        0x4a, 0x81,
        0x21, 0x99,
        0x24, 0x40,
        0x25, 0x38,
        0x26, 0x82,
        0x5c, 0x00,
        0x63, 0x00,
        0x46, 0x00,
        0x0c, 0x3c,
        0x61, 0x70,
        0x62, 0x80,
        0x7c, 0x05,
        0x20, 0x80,
        0x28, 0x30,
        0x6c, 0x00,
        0x6d, 0x80,
        0x6e, 0x00,
        0x70, 0x02,
        0x71, 0x94,
        0x73, 0xc1,
        0x3d, 0x34,
        0x5a, 0x57,
        0x12, 0x00,//UXGA 1600*1200
        0x17, 0x11,
        0x18, 0x75,
        0x19, 0x01,
        0x1a, 0x97,
        0x32, 0x36,
        0x03, 0x0f,
        0x37, 0x40,
        0x4f, 0xca,
        0x50, 0xa8,
        0x5a, 0x23,
        0x6d, 0x00,
        0x6d, 0x38,
        0xff, 0x00,
        0xe5, 0x7f,
        0xf9, 0xc0,
        0x41, 0x24,
        0xe0, 0x14,
        0x76, 0xff,
        0x33, 0xa0,
        0x42, 0x20,
        0x43, 0x18,
        0x4c, 0x00,
        0x87, 0xd5,
        0x88, 0x3f,
        0xd7, 0x03,
        0xd9, 0x10,
        0xd3, 0x82,
        0xc8, 0x08,
        0xc9, 0x80,
        0x7c, 0x00,
        0x7d, 0x00,
        0x7c, 0x03,
        0x7d, 0x48,
        0x7d, 0x48,
        0x7c, 0x08,
        0x7d, 0x20,
        0x7d, 0x10,
        0x7d, 0x0e,
        0x90, 0x00,
        0x91, 0x0e,
        0x91, 0x1a,
        0x91, 0x31,
        0x91, 0x5a,
        0x91, 0x69,
        0x91, 0x75,
        0x91, 0x7e,
        0x91, 0x88,
        0x91, 0x8f,
        0x91, 0x96,
        0x91, 0xa3,
        0x91, 0xaf,
        0x91, 0xc4,
        0x91, 0xd7,
        0x91, 0xe8,
        0x91, 0x20,
        0x92, 0x00,
        0x93, 0x06,
        0x93, 0xe3,
        0x93, 0x05,
        0x93, 0x05,
        0x93, 0x00,
        0x93, 0x04,
        0x93, 0x00,
        0x93, 0x00,
        0x93, 0x00,
        0x93, 0x00,
        0x93, 0x00,
        0x93, 0x00,
        0x93, 0x00,
        0x96, 0x00,
        0x97, 0x08,
        0x97, 0x19,
        0x97, 0x02,
        0x97, 0x0c,
        0x97, 0x24,
        0x97, 0x30,
        0x97, 0x28,
        0x97, 0x26,
        0x97, 0x02,
        0x97, 0x98,
        0x97, 0x80,
        0x97, 0x00,
        0x97, 0x00,
        0xc3, 0xef,
        0xa4, 0x00,
        0xa8, 0x00,
        0xc5, 0x11,
        0xc6, 0x51,
        0xbf, 0x80,
        0xc7, 0x10,
        0xb6, 0x66,
        0xb8, 0xA5,
        0xb7, 0x64,
        0xb9, 0x7C,
        0xb3, 0xaf,
        0xb4, 0x97,
        0xb5, 0xFF,
        0xb0, 0xC5,
        0xb1, 0x94,
        0xb2, 0x0f,
        0xc4, 0x5c,
        0xc0, 0xc8,
        0xc1, 0x96,
        0x8c, 0x00,
        0x86, 0x3d,
        0x50, 0x00,
        0x51, 0x90,
        0x52, 0x2c,
        0x53, 0x00,
        0x54, 0x00,
        0x55, 0x88,
        0x5a, 0x90,
        0x5b, 0x2C,
        0x5c, 0x05,
        0xd3, 0x02,
        0xc3, 0xed,
        0x7f, 0x00,
        0xda, 0x09,
        0xe5, 0x1f,
        0xe1, 0x67,
        0xe0, 0x00,
        0xdd, 0x7f,
        0x05, 0x00,
   //yuv422
         0xc2,0x0c,
        0xFF, 0x00,
        0xD7, 0x03,
        0xDF, 0x00,
        0x33, 0x80,
        0x3C, 0x40,
        0xe1, 0x77,
        0xda, 0x00,
        0x00, 0x00,
        rCIGCTRL |=(1<<25)|(0<<27); // inverse PCLK, test pattern
        rCIWDOFST = (1<<30)|(0xf<<12); // clear overflow
        rCIWDOFST = 0;
        rCIWDOFST=(WinOfsEn<<31)|(WinHorOffset<<16)|(WinVerOffset);
        rCISRCFMT=(CAM_ITU601<<31)|(0<<30)|(0<<29)|(CAM_SRC_HSIZE<<16)|(CAM_ORDER_YCBYCR<<14)|(CAM_SRC_VSIZE);
ID:261837 发表于 2021-3-30 15:11 | 显示全部楼层
注意CAM_SRC_HSIZE和CAM_SRC_VSIZE要和摄像头和lcd大小匹配
//以下是完整的寄存器初始化
         sccb_sendbyte(0xff, 0x01);        //操作sensor寄存器
          sccb_sendbyte(0x12, 0x80);        //software resetOV2640
        for(i = 0;i < sizeof(ov2640_svga_init_reg_tbl)/2;i++)
                 sccb_sendbyte(ov2640_svga_init_reg_tbl[ i][0],ov2640_svga_init_reg_tbl[ i][1]);//帖子上的寄存器
mdelay(50);
        outw=320/4;
        outh=240/4;
         sccb_sendbyte(0XFF,0X00);
         sccb_sendbyte(0XE0,0X04);
         sccb_sendbyte(0X5A,outw&0XFF);
         sccb_sendbyte(0X5B,outh&0XFF);
        temp=(outw>>8)&0X03;
        temp|=(outh>>6)&0X04;
         sccb_sendbyte(0X5C,temp);
         sccb_sendbyte(0XE0,0X00);
         sccb_sendbyte(0XD3,15);
         sccb_sendbyte(0XFF,0X01);
         sccb_sendbyte(0X11,3);
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
