查看: 2108|回复: 1
单片机+DHT11在LCD1602上显示为零,求错误原因
ID:899490 发表于 2021-4-1 14:14 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include <absacc.h>
#include <math.h>
//定义四个输出端口
sbit Led_jiashi=P3^4;                //加湿
sbit Led_qushi=P3^3;                //去湿
sbit Led_jiangwen=P3^1;                //降温
sbit Led_shengwen=P3^2;                //升温
//定义三个设置按键
sbit Key_SET = P2^0;
sbit Key_ADD = P2^1;
sbit Key_SUB = P2^2;
sbit Key_OK  = P2^3;
//定义24C02数据口
sbit SCL = P1^0;
sbit SDA = P1^1;
//定义DHT11数据口
sbit DATA = P1^7;
sbit buzz=P3^5;
//定义LCD1602端口
sbit E=P1^3;                //1602使能引脚
//sbit RW=P2^6;                //1602读写引脚
sbit RS=P1^2;                //1602数据/命令选择引脚
//定义全局变量
uchar U8FLAG,U8temp,U8comdata,U8RH_data_H_temp,U8RH_data_L_temp,U8T_data_H_temp,U8T_data_L_temp,U8checkdata_temp;
uchar U8RH_data_H,U8RH_data_L,U8T_data_H,U8T_data_L,U8checkdata;
uchar Mode,humidity,temperature;
char TH,TL,HH,HL;
bit bdata FlagStartRH,hot,cold,humid,dry,BJ;
//定时器0初始化
void Timer0_Init()
        ET0 = 1;        //允许定时器0中断
        TMOD = 0x11;       //定时器工作方式选择
        TL0 = 0xFF;
        TH0 = 0x4B;     //定时器赋予初值
        TR0 = 1;        //启动定时器
//定时器0中断
void Timer0_ISR (void) interrupt 1 using 0
        uchar RHCounter;
        TL0 = 0xFF;
        RHCounter++;
        if(RHCounter%10==0&&BJ==1)
        buzz=!buzz;
        else if(BJ==0)
        buzz=1;
        //每2秒钟启动一次温湿度转换
    if (RHCounter >= 40)
       FlagStartRH = 1;
           RHCounter = 0;
      BASE  DRIVE
void DELAY(unsigned int t)
        while(t!=0)
        t--;
      IIC  DRIVE
void IICStart(void)
     SCL=0;
          DELAY(1);
     SDA=1; SCL=1; DELAY(1);
     SDA=0; DELAY(1);
     SCL=0;
void IICStop(void)
         SDA=0;SCL=1; DELAY(1);
     SDA=1; DELAY(1);
     SCL=0;
void SEND0(void)
        SDA=0;
        SCL=1;
        DELAY(1);
        SCL=0;
void SEND1(void)
        SDA=1;
        DELAY(1);
        SCL=1;
        DELAY(1);
        SCL=0;
bit Check_Ack(void)
        unsigned char errtime=250;
        DELAY(1);
        SCL=1;
        DELAY(1);
        CY=SDA;
        while(CY)
                errtime--;
                CY=SDA;
                if (!errtime)
                        IICStop();
                        return 1;
        DELAY(1);
        SCL=0;
        return 0;
void Write_byte(unsigned char dat)
    unsigned char i;
        for(i=0;i<8;i++)
                if((dat<<i)&0x80)
                SEND1();
                SEND0();
unsigned char Read_byte(void)
        unsigned char i,temp=0;
        for(i=0;i<8;i++)
        SDA=1;
            SCL=1;
            DELAY(1);
                if(SDA==1)
                        temp=temp<<1;
                        temp=temp|0x01;
                temp=temp<<1;
                 SCL=0;
          return temp;
      EEPROM  DRIVE
          Addr:from 0x00-->
unsigned char rdeeprom(unsigned char addr)
        unsigned char temp=0;
                bit flag=0;
                IICStart();
                Write_byte(0xa0);
        Check_Ack();
                Write_byte(addr);
                Check_Ack();
                IICStart();
                Write_byte(0xa1);
                Check_Ack();
                temp=Read_byte();
                SEND1();
                IICStop();
             return temp;
void wrteeprom(unsigned char addr,unsigned char dat)
               IICStart();
                Write_byte(0xa0);
                Check_Ack();
                Write_byte(addr);
                Check_Ack();
                Write_byte(dat);
                Check_Ack();
                IICStop();
void Delay1(uint j)
    uchar i;
    for(;j>0;j--)
                for(i=0;i<27;i++);
void  Delay_10us(void)
    uchar i;
    i--;
    i--;
    i--;
    i--;
    i--;
    i--;
void  COM(void)
    uchar i;
    for(i=0;i<8;i++)
              U8FLAG=2;
                   while((!DATA)&&U8FLAG++);
                Delay_10us();
                Delay_10us();
                Delay_10us();
                  U8temp=0;
        if(DATA)U8temp=1;
                    U8FLAG=2;
                while((DATA)&&U8FLAG++);
                   //超时则跳出for循环
                   if(U8FLAG==1)break;
                   //判断数据位是0还是1
                // 如果高电平高过预定0高电平值则数据位为 1
                U8comdata<<=1;
                   U8comdata|=U8temp;        //0
    }//rof
//-----温湿度读取子程序 ------------
//----以下变量均为全局变量--------
//----温度高8位== U8T_data_H------
//----温度低8位== U8T_data_L------
//----湿度高8位== U8RH_data_H-----
//----湿度低8位== U8RH_data_L-----
//----校验 8位 == U8checkdata-----
//----调用相关子程序如下----------
//---- Delay();, Delay_10us();,COM();
uchar RH(void)
    //主机拉低18ms
    DATA=0;
        Delay1(180);  //原来为5
        DATA=1;
        //总线由上拉电阻拉高 主机延时20us
        Delay_10us();
        Delay_10us();
        Delay_10us();
        Delay_10us();
        //主机设为输入 判断从机响应信号
        DATA=1;
        //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
        if(!DATA)                 //T !
            U8FLAG=2;
            //判断从机是否发出 80us 的低电平响应信号是否结束
            U8FLAG=2;
            //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
            //数据接收状态
            COM();
            U8RH_data_H_temp=U8comdata;
            COM();
            U8RH_data_L_temp=U8comdata;
            COM();
            U8T_data_H_temp=U8comdata;
            COM();
            U8T_data_L_temp=U8comdata;
            COM();
            U8checkdata_temp=U8comdata;
            DATA=1;
            //数据校验
            U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
            if(U8temp==U8checkdata_temp)
                      U8RH_data_H=U8RH_data_H_temp;
                      U8RH_data_L=U8RH_data_L_temp;
                      U8T_data_H=U8T_data_H_temp;
                      U8T_data_L=U8T_data_L_temp;
                      U8checkdata=U8checkdata_temp;
                return 1;
        else   //传感器不响应
           return 0;
* 文件名  : 液晶1602显示.c
* 描述    :  该程序实现了对液晶1602的控制。
* 名称 : delay()
* 功能 : 延时,延时时间大概为140US。
* 输入 : 无
* 输出 : 无
void delay()
        int i,j;
        for(i=0; i<=10; i++)
        for(j=0; j<=2; j++);
* 名称 : enable(uchar del)
* 功能 : 1602命令函数
* 输入 : 输入的命令值
* 输出 : 无
void enable(uchar del)
        P0 = del;
        RS = 0;
        E = 1;
        delay();
        E = 0;
        delay();
* 名称 : write(uchar del)
* 功能 : 1602写数据函数
* 输入 : 需要写入1602的数据
* 输出 : 无
void write(uchar del)
        P0 = del;
        RS = 1;
        E = 1;
        delay();
        E = 0;
        delay();
* 名称 : L1602_init()
* 功能 : 1602初始化,请参考1602的资料
* 输入 : 无
* 输出 : 无
void L1602_init(void)
        enable(0x38);
        enable(0x0c);
        enable(0x06);
        enable(0x01); //清屏要放在最后
* 名称 : L1602_char(uchar hang,uchar lie,char sign)
* 功能 : 改变液晶中某位的值,如果要让第一行,第五个字符显示"b" ,调用该函数如下
                 L1602_char(1,5,'b')
* 输入 : 行,列,需要输入1602的数据
* 输出 : 无
void L1602_char(uchar hang,uchar lie,char sign)
        uchar a;
        if(hang == 1) a = 0x80;
        if(hang == 2) a = 0xc0;
        a = a + lie - 1;
        enable(a);
        write(sign);
* 名称 : L1602_string(uchar hang,uchar lie,uchar *p)
* 功能 : 改变液晶中某位的值,如果要让第一行,第五个字符开始显示"ab cd ef" ,调用该函数如下
                  L1602_string(1,5,"ab cd ef;")
* 输出 : 无
void L1602_string(uchar hang,uchar lie,uchar *p)
        uchar a;
        a = a + lie - 1;
        enable(a);
                if(*p == '\0') break;
                write(*p);
                p++;
//显示整型的温湿度数据用,共占用4位,其中一位符号位
void L1602_int(uchar hang, uchar lie, int num)
   uint temp;
   uint gewei,shiwei,baiwei,sign;
   if (num >= 0)
   sign = 0;
   sign = 1;
   temp = abs(num);
   baiwei = temp / 100;
   temp = temp - baiwei*100;
   shiwei = temp / 10;
   gewei = temp - shiwei*10;
   num = abs(num);
   if (num>=100)
   //   L1602_char(hang, lie+1, baiwei+48);
          L1602_char(hang, lie+2, shiwei+48);
          L1602_char(hang, lie+3, gewei+48);
   else if (num>=10)
      if (sign == 1)
          L1602_char(hang, lie+1, '-');
      if (sign == 1)
          L1602_char(hang, lie+2, '-');
          L1602_char(hang, lie+2, ' ');
void display()
        if(Mode==0)
                L1602_int(1,3,temperature);
                L1602_char(1,7,0xdf);
                L1602_int(1,12,humidity);
                if(hot==1&&cold==0&&humid==0&&dry==0)
                {L1602_string(2,1," It's very hot! ");BJ=1;}
                else if(hot==1&&cold==0&&humid==1&&dry==0)
                {L1602_string(2,1," Hot and humid! ");BJ=1;}
                else if(hot==1&&cold==0&&humid==0&&dry==1)
                {L1602_string(2,1,"  Hot and dry!  ");BJ=1;}
                else if(hot==0&&cold==1&&humid==0&&dry==0)
                {L1602_string(2,1," It's very cold!");BJ=1;}
                else if(hot==0&&cold==1&&humid==1&&dry==0)
                {L1602_string(2,1," Cold and humid!");BJ=1;}
                else if(hot==0&&cold==1&&humid==0&&dry==1)
                {L1602_string(2,1,"  Cold and dry! ");BJ=1;}
                else if(hot==0&&cold==0&&humid==1&&dry==0)
                {L1602_string(2,1,"It's very humid!");BJ=1;}
                else if(hot==0&&cold==0&&humid==0&&dry==1)
                {L1602_string(2,1," It's very dry! ");BJ=1;}
                else if(hot==0&&cold==0&&humid==0&&dry==0)
                {L1602_string(2,1,"Good environment");BJ=0;}
/***按键函数***/
void KEY()
        if(Key_SET==0)
                Delay1(200);
                if(Key_SET==0)
                        Mode++;
                        if(Mode==1)
                                L1602_string(1,1," TH:    C HH:  %");
                                L1602_char(1,8,0xdf);
                                L1602_string(2,1," TL:    C HL:  %");
                                L1602_char(2,8,0xdf);
                                L1602_int(1,4,TH);
                                L1602_int(1,12,HH);
                                L1602_int(2,4,TL);
                                L1602_int(2,12,HL);
                                enable(0x80+6);
                                enable(0x0f);
                        else if(Mode==2)
                                enable(0x80+0x40+6);
                                enable(0x0f);
                        else if(Mode==3)
                                enable(0x80+14);
                                enable(0x0f);
                        else if(Mode==4)
                                enable(0x80+0x40+14);
                                enable(0x0f);
                        else if(Mode>=5)
                                Mode=1;
                                enable(0x80+6);
                                enable(0x0f);
                        while(!Key_SET);
        else if(Key_ADD==0)
                Delay1(200);
                if(Key_ADD==0)
                        if(Mode==1)
                                TH++;
                                if(TH>=100)
                                TH=99;
                                L1602_int(1,4,TH);
                                enable(0x80+6);
                        else if(Mode==2)
                                TL++;
                                if(TL>=TH)
                                TL=TH-1;
                                L1602_int(2,4,TL);
                        else if(Mode==3)
                                HH++;
                                if(HH>=100)
                                HH=99;
                                L1602_int(1,12,HH);
                                enable(0x80+14);
                        else if(Mode==4)
                                HL++;
                                if(HL>=HH)
                                HL=HH-1;
                                L1602_int(2,12,HL);
                        while(!Key_ADD);
        else if(Key_SUB==0)
                Delay1(200);
                if(Key_SUB==0)
                        if(Mode==1)
                                TH--;
                                if(TH<=TL)
                                TH=TL+1;
                                L1602_int(1,4,TH);
                                enable(0x80+6);
                        else if(Mode==2)
                                TL--;
                                if(TL<=0)
                                TL=0;
                                L1602_int(2,4,TL);
                        else if(Mode==3)
                                HH--;
                                if(HH<=HL)
                                HH=HL+1;
                                L1602_int(1,12,HH);
                                enable(0x80+14);
                        else if(Mode==4)
                                HL--;
                                if(HL<=0)
                                HL=0;
                                L1602_int(2,12,HL);
                        while(!Key_SUB);
        if(Key_OK==0&&Mode!=0)
                Delay1(200);
                if(Key_OK==0)
                        L1602_string(1,1,"Tem:   C Hum:  %");
                        Mode=0;
                        wrteeprom(0,TH);
                        Delay1(20);
                        wrteeprom(1,TL);
                        Delay1(20);
                        wrteeprom(2,HH);
                        Delay1(20);
                        wrteeprom(3,HL);
                        enable(0x0c);
                        while(Key_OK==0);
//数据初始化
void Data_Init()
   Led_qushi = 1;
   Led_jiashi=1;
   Led_jiangwen = 1;
   Led_shengwen = 1;
* 名称 : Main()
* 功能 : 主函数
    uint i, j, testnum;
    EA = 0;
        Timer0_Init();
    Data_Init();
        EA = 1;
        L1602_init();
        L1602_string(1,1," Welcome to T&H ");
        L1602_string(2,1," Control System!");
         for (i=0;i<1000;i++)
           for (j=0;j<1000;j++)
        L1602_string(1,1,"                ");
        L1602_string(2,1,"                ");
        TH=rdeeprom(0);
        Delay1(20);
        TL=rdeeprom(1);
        Delay1(20);
        HH=rdeeprom(2);
        Delay1(20);
        HL=rdeeprom(3);
                 if (FlagStartRH == 1)         //温湿度转换标志检查
                     TR0 = 0;
             testnum = RH();
                          FlagStartRH = 0;
                         TR0 = 1;
                         humidity = U8RH_data_H;         //读出温湿度,只取整数部分
                         temperature = U8T_data_H;
                         if(Mode==0)                //温湿度控制
                                 if (temperature > TH)
                                        Led_jiangwen = 0;
                                        hot=1;
                                        Led_shengwen = 1;
                                        cold=0;
                        //                BJ=1;
                                else if(temperature<TL)
                                        Led_shengwen = 0;
                                        cold=1;
                                        Led_jiangwen = 1;
                                        hot=0;
                                        buzz=0;
                        //                BJ=1;
                                        Led_jiangwen=1;
                                        Led_shengwen=1;
                                        hot=0;
                                        cold=0;
                                        buzz=1;
                                if (humidity > HH)
                                        Led_qushi = 0;
                                        humid=1;
                                        Led_jiashi = 1;
                                        dry=0;
                        //                BJ=1;
                                else if(humidity<HL)
                                        Led_jiashi = 0;
                                        dry=1;
                                        Led_qushi = 1;
                                        humid=0;
                        //                BJ=1;
                                        Led_qushi=1;
                                        Led_jiashi=1;
                                        humid=0;
                                        dry=0;
                                 Led_shengwen=1;
                                Led_jiangwen=1;
                                Led_jiashi=1;
                                Led_qushi=1;
                                hot=0;
                                cold=0;
                                humid=0;
                                dry=0;
                                BJ=0;
                display();
                KEY();
ID:584814 发表于 2021-4-4 11:06 | 显示全部楼层
抄来的程序一般逻辑没错但延时不同没有相同或相似的器件说了也是废话
