查看: 2240|回复: 2
单片机定时器方式二仿真(led不亮,请问哪出错了)
ID:839571 发表于 2021-4-18 12:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
typedef unsigned int u16;
sbit led0 = P1^0;
sbit led1 = P1^1;
u16 num;
void main(void)
         TMOD = 0x02;
         TH0 = 156;
         TL0 = 156;
         ET0 = 1;
         TR0 = 1;
         EA = 1;
     while (1)
                 if(num == 10000)
                         num = 0;
                         led0 = ~led0;
void T0_time(void) interrupt 2
        num++;
ID:275826 发表于 2021-4-18 19:56 | 只看该作者
把void T0_time(void) interrupt 2改成void T0_time(void) interrupt 1
ID:839571 发表于 2021-4-18 20:16 | 只看该作者
#include <reg51.h>
sbit led0 = P1^0;
sbit led1 = P1^1;
u16 num;
void main(void)
   // Write your code here
     TMOD = 0x52;
         TH0 = 0x9C;
         TL0 = 0x9C;
         TH1 = (65536-100)/256;
         TL1 = (65536-100)%256;
         EA = 1;
         ET0 = 1;
         TR0 = 1;
         ET1 = 1;
         TR1 = 1;
     while (1);
        num++;
        if(num==10000)
                num = 0;
                led0 = ~led0;
void T1_time(void) interrupt 3
        if(TF1==1)
                TF1 = 0;
                led1 = ~led1;
那请问这个T1为计数器时,给它记100个脉冲,led取反,为什么仿真时候不亮呢
