查看: 1562|回复: 0
Protel选择器件的时候,英文器件你们都认识吗?我来分享一个步进电机C程序
ID:870328 发表于 2021-4-21 17:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg52.h"
#include<lcd1602.h>
#include "delay.h"
#include "motor4B.h"
sbit K1 = P3^2;//加速
sbit K2 = P3^3;//减速
sbit K3 = P3^4;//正传
sbit K4 = P3^5;//反转
sbit K5 = P3^6;//启动
sbit K6 = P3^7;//停止
void main( )
        bit         fangxiang         =                 1;//0是逆时针
        bit         kaiqi                         =                 0;//0是停止
        int          sudu                                =                4;//每次步进间隔时间为 1ms * sudu,也就是最快每秒25转
        char str_buff[] = { "00.00" };
        int speed = 0;
        init_lcd();
        lcd( 0, 0, "LCD_INIT" );
        delay( 100 );
        lcd( 0, 0, "        " );
        Init_Motor();
        Set_Motor(kaiqi, fangxiang, sudu);
        lcd( 1, 0, "    reversal    " );
        lcd( 0, 0, "Speed: " );
        lcd( 0, 12, "r/s" );
        speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
        str_buff[0] = speed / 10000 % 10 + '0';
        str_buff[1] = speed / 1000 % 10 + '0';
        str_buff[3] = speed / 100 % 10 + '0';
        str_buff[4] = speed % 10 + '0';
        lcd( 0, 6, str_buff );
                //////////////////////////////////////////////////////////////////////加速
                if( K1 == 0 )
                        delay( 50 );
                        if( K1 == 0 )
                                sudu--;
                                if( sudu <= 3 )
                                        sudu = 4;
//                                while( K1 == 0 );
                //////////////////////////////////////////////////////////////////////减速
                if( K2 == 0 )
                        delay( 50 );
                        if( K2 == 0 )
                                sudu++;
                                if( sudu >= 60000 )
                                        sudu = 60000;
                //////////////////////////////////////////////////////////////////////正
                if( K3 == 0 )
                        delay( 50 );
                        if( K3 == 0 )
                                fangxiang = 1;
                                lcd( 1, 0, "Forward rotation" );
                                while( K3 == 0 );
                //////////////////////////////////////////////////////////////////////反
                if( K4 == 0 )
                        delay( 50 );
                        if( K4 == 0 )
                                fangxiang = 0;
                                while( K4 == 0 );
                //////////////////////////////////////////////////////////////////////启
                if( K5 == 0 )
                        delay( 50 );
                        if( K5 == 0 )
                                kaiqi = 1;
                                while( K6 == 0 );
                //////////////////////////////////////////////////////////////////////停
                if( K6 == 0 )
                        delay( 50 );
                        if( K6 == 0 )
                                kaiqi = 0;
                                while( K6 == 0 );
