查看: 4985|回复: 4
单片机+LCD12864全屏显示图片程序+仿真 看了包会
#include <REGX52.H>
#define duan P0
uchar code table1[][16] = {
0X00,0X00,0X00,0X00,0X00,0X00,0X80,0XC0,0XE0,0XF0,0XF8,0X7C,0X3E,0X3F,0X1F,0X1F,
0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X3F,0X1F,0XFF,0XFF,0XFF,0X3F,0X07,0XFF,0XFF,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X00,0X00,0X00,0X00,0XF8,0X3E,0X0F,0X07,0X03,0X01,0X00,0X00,0X00,0X00,0X00,0XFC,
0XFF,0XFF,0XFF,0XFF,0X3F,0XCF,0XFF,0XFF,0XFF,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7F,0X0F,0XF7,0X7F,0X03,0X00,
0X00,0X00,0XFF,0XFF,0X03,0X00,0X00,0X1F,0XFF,0XFE,0X81,0X07,0X1F,0X7F,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XEF,
0X9F,0X3F,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7F,
0X00,0X00,0X00,0X03,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XFF,
0XFF,0XFF,0XFF,0X01,0X00,0XFF,0XFF,0X1F,0X00,0X00,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XE7,0XF9,0XFF,0XFF,0XFF,0XFF,0X7F,0XFF,0XFF,0X0E,0X0E,0X0F,0X3E,0X0E,0X1E,
0X1C,0X1C,0X1F,0X3F,0X7C,0XFC,0X7C,0X7C,0X79,0XFF,0XFF,0XFE,0XF8,0XF0,0XE0,0XE1,
0XC7,0X0F,0X1F,0X3F,0X3F,0X6F,0XFF,0XDF,0XBF,0X7F,0X7F,0X7F,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFD,0XFB,0XF3,0XE7,0XE7,0XEF,0XEF,0XCF,0XDF,0XDF,
0XDF,0XDF,0XDE,0XDC,0XF9,0XF3,0XAF,0XBF,0XFF,0XFF,0XFF,0X03,0X0F,0X1F,0X67,0XCF,
0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3F,0X07,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X03,0X0F,0X3F,0X7F,0XF0,0X80,0X0F,0X38,0X00,0X00,0X00,0XFE,0XFF,0XFF,0XFF,0XFF,
0XFF,0X1F,0X3F,0XF0,0X03,0X1F,0XFF,0XC0,0X61,0X3F,0X1C,0X0C,0X06,0XC2,0XC3,0X01,
0X31,0XFD,0X0D,0X07,0X02,0X02,0X07,0X0C,0X18,0XE0,0X00,0X00,0X00,0X01,0X03,0X07,
0X0F,0X1F,0XF0,0XE0,0XC0,0XC0,0XC0,0XC0,0XC1,0X83,0X82,0X86,0X8C,0X08,0X19,0XF1,
0X3F,0X3F,0X0F,0X1F,0X3F,0XFF,0XFF,0XFF,0X03,0X03,0X67,0XA7,0XD7,0XD7,0X7F,0X2F,
0X2B,0X2B,0X2B,0X0B,0X59,0X19,0X11,0X31,0X21,0X7F,0XC3,0X87,0X07,0X0F,0X1F,0X7E,
0XF5,0XFA,0X97,0XBF,0XFF,0XFF,0XFF,0XFF,0X7F,0X1F,0X0F,0X03,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X01,0X02,0X00,0X00,0X00,0X00,0XC0,0X01,0X01,0X01,0X7F,
0XFF,0XE2,0X04,0X00,0X17,0X38,0XE3,0X81,0X00,0X00,0X00,0X00,0X0E,0X3B,0X7D,0X7C,
0X60,0X60,0XE0,0XF0,0XF0,0X70,0X70,0X30,0X38,0X0F,0X00,0X00,0X00,0X00,0X00,0X00,
0XC0,0X08,0X07,0X07,0X07,0X03,0X03,0X03,0X03,0X07,0X07,0X07,0X07,0X0F,0XFF,0XFF,
0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X07,0X00,0X00,0X3E,0XEC,0XF0,0XC3,0X80,0XA0,
0XC0,0XC0,0XC0,0XC0,0XC0,0X60,0X31,0X3C,0X00,0X00,0X00,0X01,0X03,0X0E,0X00,0X00,
0X01,0XFF,0XFF,0X3F,0XBF,0X1F,0X1F,0X14,0X00,0X08,0X60,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X06,0X10,0X20,0X00,
0X02,0X09,0X27,0X4C,0X90,0X22,0X44,0X41,0X88,0X80,0X00,0X00,0X04,0X04,0X00,0X00,
0X00,0X00,0X00,0X04,0X04,0X00,0X02,0X00,0X80,0X00,0X40,0X00,0X20,0X10,0X08,0X02,
0X00,0X00,0X00,0X00,0X40,0X40,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X03,
0X0C,0X10,0X40,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X10,0X00,0X01,0X21,
0X21,0X21,0X21,0X21,0X20,0X20,0X00,0X10,0X00,0X00,0X00,0X00,0X00,0XC0,0XE0,0XEC,
0X3D,0X2F,0X01,0X00,0X40,0XB1,0X46,0X10,0X84,0X20,0X0C,0X00,0X00,0X00,0X00,0X00,
0X01,0X02,0X04,0X08,0X10,0X00,0X01,0X40,0X00,0X87,0X18,0X21,0X81,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X03,0X04,0X00,0X04,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X01,0X02,0X00,0X04,0X04,0X00,0X08,0X08,0X00,0X10,0X10,
0X10,0X10,0X10,0X10,0X10,0X10,0X00,0X00,0X48,0X38,0X2C,0X06,0X03,0X11,0X01,0X28,
0X00,0X84,0X02,0X41,0X20,0X10,0X04,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X01,0X01,0X00,0X00,
0X00,0X10,0X20,0X40,0X80,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X20,0X10,0X00,0X00,0X00,0X00,0X20,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,
0X00,0X40,0X60,0XE0,0XF0,0XF8,0XF0,0XF1,0X00,0X00,0X0C,0X00,0X05,0X00,0X02,0X00,
0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X40,0X20,0X20,0X00,0X00,0X10,0X00,0X00,0X08,
0X08,0X08,0XF0,0X10,0X04,0X20,0X21,0X4A,0X00,0X84,0X00,0X08,0X10,0X30,0X20,0X60,
0X40,0X00,0X80,0X80,0X00,0X00,0X00,0X00,0X00,0X80,0X80,0X80,0X80,0X00,0X40,0X40,
0X40,0XA0,0XA0,0X10,0X10,0X20,0X08,0X10,0X04,0X0C,0X42,0X26,0X12,0X05,0X02,0X02,
0X08,0X28,0X90,0X40,0X01,0X03,0X03,0X07,0X0F,0X10,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0X20,
0X10,0X00,0X80,0X10,0X07,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X80,0X40,0X17,0XE0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X61,0XC0,0XC0,0X80,0X00,
0X20,0X30,0X04,0X28,0X30,0X00,0X84,0X84,0X40,0X00,0X22,0X22,0X00,0X10,0X11,0X11,
0X00,0X00,0X00,0X40,0X20,0X10,0X08,0X04,0X01,0X01,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0XC2,0X29,0X30,0X18,0X10,0X50,0X00,0XA0,0X40,0X40,0X80,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X02,0X00,0X00,
0X00,0X00,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X02,
0X01,0X00,0X02,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X03,0X00,0X00,
0X00,0X00,0X00,0X06,0X07,0X07,0X05,0X04,0X04,0X04,0X02,0X00,0X00,0X00,0X00,0X00,
0X04,0X02,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X04,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X00,0X02,0X01,
0X04,0X02,0X04,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
uchar code table[]={0x3f,0x40,0x80,0xb8,0xc0};
sbit e=P1^0;
sbit rw=P1^1;
sbit rs=P1^2;
sbit cs2=P1^3;
sbit cs1=P1^4;
sbit rst=P1^5;
void delay500us(uint xus)
        uint i;uchar j;
        for(i=xus;i>0;i--)
                for(j=55;j>0;j--);
void zllift(uchar zl)  //左lift
        cs1=0;cs2=1;
        rw=0;
        rs=0;
        duan=zl;
        delay500us(1);
        e=1;
        delay500us(2);
        e=0;
void zlright(uchar zl)
        cs1=1;cs2=0;
        rw=0;
        rs=0;
        duan=zl;
        delay500us(1);
        e=1;
        delay500us(2);
        e=0;
void sjlift(uchar sj)
        cs1=0;cs2=1;   /////////////////////
        rw=0;
        rs=1;
        duan=sj;
        delay500us(1);
        e=1;
        delay500us(2);
        e=0;
12864全屏显示图片.zip
83.29 KB, 下载次数: 78, 下载积分: 黑币 -5
收藏收藏7 分享淘帖 顶顶2 踩踩
ID:604918 发表于 2021-8-17 15:38 | 只看该作者
不讲武德,莫得注释
ID:961875 发表于 2021-8-25 14:10 | 只看该作者
我的屏怎么是20脚的
ID:907317 发表于 2021-9-5 17:00 来自触屏版 | 只看该作者
fade@zds 发表于 2021-8-17 15:38
不讲武德,莫得注释
注释 咳咳
ID:981792 发表于 2021-11-23 14:10 来自触屏版 | 只看该作者
emmm代码复制到proteus运行不了
