查看: 4713|回复: 3
STM32串口读取IM1253B_LCD1602显示程序
ID:832889 发表于 2021-4-25 21:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Stm32利用串口读取IM1253B的数据在并行传输到1602显示屏上
  1. #include "Im1252.h"
  2. #include "bsp_usart.h"
  3. #define reveive_number  37
  4. unsigned char  Rx_Buffer[UART_BUFF_SIZE];
  5. unsigned char receive_finished;
  6. unsigned char Tx_Buffer[15];
  7. ShowDataTypeDef ShowDataSTructure;
  8. unsigned int calccrc(unsigned char crcbuf,unsigned int crc)
  9. {
  10.         unsigned char i;
  11.         unsigned char chk;
  12.         crc=crc^crcbuf;
  13.         for(i=0;i<8;i++)
  14.         {
  15.                 chk=(unsigned char)(crc&1);
  16.                 crc=crc>>1;
  17.                 crc=crc&0x7fff;
  18.                 if (chk==1)
  19.                         crc=crc^0xa001;
  20.                 crc=crc&0xffff;
  21.         }
  22.         return crc;
  23. }
  24. //CRC数据校正生成
  25. unsigned int chkcrc(unsigned char *buf,unsigned char len)
  26. {
  27.         unsigned char hi,lo;
  28.         unsigned int i;
  29.         unsigned int crc;
  30.         crc=0xFFFF;
  31.         for(i=0;i<len;i++)
  32.         {
  33.                 crc=calccrc(*buf,crc);
  34.                 buf++;
  35.         }
  36.         hi=( unsigned char)(crc%256);
  37.         lo=( unsigned char)(crc/256);
  38.         crc=(((unsigned int)(hi))<<8)|lo;
  39.         return crc;
  40. }
  41. //读取数据
  42. void read_data(void)
  43. {
  44.                 union crcdata crcnow;
  45.         //定义一个地址区存放CRC校验
  46.         // 到时间抄读模块,抄读间隔 1 秒钟(或其他)
  47.                 Tx_Buffer[0]=Read_ID; //模块的 ID 号,默认 ID 为 0x01
  48.                 Tx_Buffer[1]=0x03;
  49.                 Tx_Buffer[2]=0x00;
  50.                 Tx_Buffer[3]=0x48;
  51.                 Tx_Buffer[4]=0x00;
  52.                 Tx_Buffer[5]=0x08;
  53.                 crcnow.word16=chkcrc(Tx_Buffer,6);
  54.                 Tx_Buffer[6]=crcnow.byte[1]; //CRC 效验低字节在前
  55.                 Tx_Buffer[7]=crcnow.byte[0];  //发送 8 个数据,请根据单片机类型自己编程
  56.                 Usart_SendArray(DEBUG_USARTx,Tx_Buffer,8);
  57. }
  58. //电能清零
  59. void Clear_EnergyData(void)
  60. {   //01 10 00 4B 00 02 04 00 00 00 00 B6 2C
  61.                 union crcdata crcnow;
  62.         //定义一个地址区存放CRC校验
  63.         // 到时间抄读模块,抄读间隔 1 秒钟(或其他)
  64.                 Tx_Buffer[0]=Read_ID; //模块的 ID 号,默认 ID 为 0x01
  65.                 Tx_Buffer[1]=0x10;
  66.                 Tx_Buffer[2]=0x00;
  67.                 Tx_Buffer[3]=0x4B;
  68.                 Tx_Buffer[4]=0x00;
  69.                 Tx_Buffer[5]=0x02;
  70.                 Tx_Buffer[6]=0x04;
  71.                 Tx_Buffer[7]=0x00;
  72.                 Tx_Buffer[8]=0x00;
  73.                 Tx_Buffer[9]=0x00;
  74.                 Tx_Buffer[10]=0x00;
  75.                 crcnow.word16=chkcrc(Tx_Buffer,11);
  76.                 Tx_Buffer[11]=crcnow.byte[1]; //CRC 效验低字节在前
  77.                 Tx_Buffer[12]=crcnow.byte[0];  //发送 8 个数据,请根据单片机类型自己编程
  78.                 Usart_SendArray(DEBUG_USARTx,Tx_Buffer,13);
  79. }
  80. //分析数据
  81. void Analysis_data(void)
  82. {
  83.         union crcdata crcnow;
  84.                 if(Rx_Buffer[0]==Read_ID) //确认 ID 正确
  85.                 {
  86.                         crcnow.word16=chkcrc(Rx_Buffer,reveive_number-2); //reveive_numbe 是接收数据总长度
  87.                         if((crcnow.byte[0]==Rx_Buffer[reveive_number-1])&&(crcnow.byte[1]==Rx_Buffer[reveive_number-2]))
  88.                         {
  89. //                                ShowDataStructure.Current_data1 = (uint8_t *)&Rx_Buffer[3];
  90.                                 //电压数据
  91.                                 ShowDataSTructure.Voltage_data = (((uint32_t)(Rx_Buffer[3] ))<<24) |(((uint32_t)(Rx_Buffer[4]))<<16)  |(((uint32_t)(Rx_Buffer[5]))<<8)  |Rx_Buffer[6];
  92.                                 //电流数据
  93.                                 ShowDataSTructure.Current_data = (((uint32_t)(Rx_Buffer[7]))<<24)  |(((uint32_t)(Rx_Buffer[8]))<<16)  |(((uint32_t)(Rx_Buffer[9]))<<8)  |Rx_Buffer[10];
  94.                                 //有功数据
  95.                                 ShowDataSTructure.Power_data   = (((uint32_t)(Rx_Buffer[11]))<<24) |(((uint32_t)(Rx_Buffer[12]))<<16) |(((uint32_t)(Rx_Buffer[13]))<<8) |Rx_Buffer[14];
  96.                                 //有功总电能数据
  97.                                 ShowDataSTructure.Energy_data  = (((uint32_t)(Rx_Buffer[15]))<<24) |(((uint32_t)(Rx_Buffer[16]))<<16) |(((uint32_t)(Rx_Buffer[17]))<<8) |Rx_Buffer[18];
  98.                                 //功率因数数据
  99.                                 ShowDataSTructure.Pf_data      = (((uint32_t)(Rx_Buffer[19]))<<24) |(((uint32_t)(Rx_Buffer[20]))<<16) |(((uint32_t)(Rx_Buffer[21]))<<8) |Rx_Buffer[22];
  100.                                 //二氧化碳数据
  101.                                 ShowDataSTructure.CO2_data     = (((uint32_t)(Rx_Buffer[23]))<<24) |(((uint32_t)(Rx_Buffer[24]))<<16) |(((uint32_t)(Rx_Buffer[25]))<<8) |Rx_Buffer[26];
  102.                                 //温度数据
  103.                                 ShowDataSTructure.Tem_data     = (((uint32_t)(Rx_Buffer[27]))<<24) |(((uint32_t)(Rx_Buffer[28]))<<16) |(((uint32_t)(Rx_Buffer[29]))<<8) |Rx_Buffer[30];
  104.                                 //频率数据
  105.                                 ShowDataSTructure.Fre_data     = (((uint32_t)(Rx_Buffer[31]))<<24) |(((uint32_t)(Rx_Buffer[32]))<<16) |(((uint32_t)(Rx_Buffer[33]))<<8) |Rx_Buffer[34];
  106.                         }
  107.         }
  108. }
单向电能.7z (201.72 KB, 下载次数: 87)
ID:974135 发表于 2021-10-22 13:53 | 只看该作者
非常感谢,不知道8266怎么连
ID:626553 发表于 2022-1-25 19:03 来自触屏版 | 只看该作者
blackboyz 发表于 2021-10-22 13:53
非常感谢,不知道8266怎么连
你好,esp8266咋接会了吗?
ID:1045269 发表于 2022-9-23 09:01 | 只看该作者
大佬,请问一下IM1253B的RX和TX口接STM32的那两个口,看不太懂程序
