查看: 5777|回复: 6
STM32F1与BQ4050的通讯源码分享
ID:524634 发表于 2021-4-28 16:08 | 显示全部楼层 |阅读模式
学习STM32的时候,应用STM32F1与BQ4050做通讯,经过各种调试,以及网上查找资料,IIC通讯等待应答的时间需要拉长,IIC通讯的调试,通过示波器查看波形真的很重要
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "myiic.h"
  6. #include "key.h"
  7. //#define BQ4050_REG_TEMP                  0x08                //Temperature   U2
  8. //#define BQ4050_REG_VOLT                  0x09                //Voltage   U2#define BQ4050_REG_CURRENT          0x0A                //CURRENT   I2
  9. //#define BQ4050_REG_RSOC                  0x0D                //RelativeStateOfCharge U1
  10. //#define BQ4050_REG_FCC                  0x10                //FullChargeCapacity    U2
  11. //#define BQ4050_REG_RTE                  0x11                //run time to empty
  12. //#define BQ4050_REG_TTE                  0x12                //TimeToEmpty   U2
  13. //#define BQ4050_REG_TTF                  0x13                //TimeToFull    U2
  14. //#define BQ4050_REG_RMC                  0x0F                ///* Remaining Capacity */
  15. u8 DLHR_DATA[2] = {0x00};
  16. u8 buff[4]  = {0x00};
  17. uint16_t Read_BQ4050(uint8_t Commond)
  18. {
  19.         uint16_t data=0,data1=0;
  20.         u8 I2c_Address = 0x16;
  21.         //u8 Read_Commond = 0x09;
  22.
  23.         IIC_Start();
  24.         IIC_Send_Byte(I2c_Address);//write
  25.
  26.         IIC_Wait_Ack();
  27.
  28.         IIC_Send_Byte(Commond);//
  29.
  30.         IIC_Wait_Ack();
  31.
  32.         IIC_Start();
  33.         IIC_Send_Byte((I2c_Address)+1);//read
  34.         IIC_Wait_Ack();
  35.
  36.   data = IIC_Read_Byte(1);//STATUS[7:0]
  37.         data1 = IIC_Read_Byte(0);//PRESSURE[23:16]
  38.
  39. IIC_Stop();
  40.         data=data|data1<<8;
  41.         return data;
  42.
  43. }
  44. int main(void)
  45. {
  46.         u8 t=0;
  47.          u8 d=0;
  48.          uint16_t data1=0,data2=0;
  49.         delay_init();                     //延时函数初始化
  50.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2
  51.         uart_init(9600);         //串口初始化为9600
  52.         LED_Init();                         //初始化与LED连接的硬件接口
  53.          KEY_Init();
  54.         IIC_Init();
  55.         while(1)
  56.         {
  57.         //data=Read_BQ4050(0x09)&0x7fff;
  58.                 data1=Read_BQ4050(0x09);
  59.                 data2=Read_BQ4050(0x0d);
  60.
  61.         delay_ms(300);
  62.                 printf("val= %d\r\n",data1);
  63.                         printf("Cap= %d\r\n",data2);
  64.
  65.
  66.                 GPIO_ResetBits(GPIOA,GPIO_Pin_8);
  67.
  68.
  69.
  70.         }
  71.
  72.
  73. }
BQ4050.7z (184.45 KB, 下载次数: 125)
ID:923581 发表于 2021-12-14 14:28 | 显示全部楼层
感谢,可用
ID:1104880 发表于 2023-12-19 13:05 | 显示全部楼层
是否可以分享代码呢? 另外BQ4050与BQ3060物理层是否一致?
ID:1104880 发表于 2023-12-19 13:06 | 显示全部楼层
BQ4050与BQ3060底层时序一致,命令地址不一致。
ID:1104880 发表于 2023-12-20 15:17 | 显示全部楼层
你好,我用您的示例代码,发现无法与BQ4050通讯。用逻辑分析仪发现是丢失了应答信号。
ID:370644 发表于 2025-1-22 12:13 | 显示全部楼层
确认可以用吗?
ID:370644 发表于 2025-1-22 13:48 | 显示全部楼层
确实可以用,非常感谢,我弄了一周也没有搞定。
