查看: 4715|回复: 4
arduino的修改过的可改pwm频率的库函数
  1. /*
  2. By default Arduino's analogWrite (and consequently pwmWrite() since it mimics analogWrite()) uses 8 bit
  3. pwm across all timers. 8 bit PWM allows for a total of 256 possible values. This library has some methods
  4. for fine tuning resolution if a higher resolution is needed:
  5. void pwmWriteHR(uint8_t pin, uint16_t duty)
  6.   Same a pwmWrite, except the range is 0 - 65535 (16 bit) instead
  7.   of 0 - 255 (8 bit)
  8. float TimerX_GetResolution() (replace X with a timer number)
  9.   Gets the timer's resolution in base 2. The value returned in other words
  10.   represents the number of bits required to represent the timer's range. ie
  11.   the value 7 means it takes 7 bits to represent all possible pin duties at
  12.   that frequency, or 7-bit resolution. Note that a float is returned, not
  13.   an int.
  14. float GetPinResolution(uint8_t pin)
  15.   Returns the same value as TimerX_GetResolution(), but takes a pin number
  16.   as a parameter so that the caller is timer agnostic.
  17. There are several things to keep in mind when trying to optimize resolution:
  18. -pwmWriteHR() is only useful for 16 bit timers, since 8 bit timers are inherently limited to 8 bit pwm
  19. -The higher the frequency, the lower the resolution. pwmWriteHR() will automatically map input to the
  20.   actual timer resolution
  21. -Resolution can be optimized in this way for 2 pins on the Uno (9 and 10), and 11 pins on the Mega (2,
  22. 3, 5, 6, 7, 8, 11, 12, 44, 45,  and 46)
  23.
  24. Use the serial moniter to see output from this program
  25. This example runs on mega and uno.
  26. */
  27. #include <PWM.h>
  28. //use pin 11 on the mega for this example to work
  29. int led = 9; // the pin that the LED is attached to
  30. void setup()
  31. {
  32.   InitTimersSafe(); //initialize all timers except for 0, to save time keeping functions
  33.   Serial.begin(115200);
  34.   Serial.println();
  35.
  36.   demonstrateFrequencysEffectOnResolution();
  37.   settingHighResolutionDuty();
  38. }
  39. void demonstrateFrequencysEffectOnResolution()
  40. {
  41.   Serial.println("As frequency increases, resolution will decrease...");
  42.   for(int i = 1; i < 10000; i+=10)
  43.     {
  44.       SetPinFrequency(led, i);  //setting the frequency
  45.
  46.       uint16_t frequency = Timer1_GetFrequency();
  47.       uint16_t decimalResolution = Timer1_GetTop() + 1;
  48.       uint16_t binaryResolution = GetPinResolution(led); //this number will be inaccurately low because the float is being truncated to a int
  49.
  50.       char strOut[75];
  51.       sprintf(strOut, "Frequency: %u Hz\r\n Number of Possible Duties: %u\r\n Resolution: %u bit\r\n", frequency, decimalResolution, binaryResolution );
  52.
  53.       Serial.println(strOut);
  54.     }
  55.
  56.     Serial.println("...Finished");
  57. }
  58. void settingHighResolutionDuty()
  59. {
  60. SetPinFrequency(led, 10); //setting the frequency to 10 Hz
  61. Serial.println("\r\npwmWrite() and pwmWriteHR() are identical except for the valid range of inputs.\r\nThe following loop calls both functions to produce the same result on the \r\nLED pin. The pin should to run 10Hz at 50% duty regardless of the function called.\r\n");
  62. //the led should flicker (10Hz 50% duty) for 1 second before calling
  63. //the other function. This demonstrates the use of pwmWriteHR() and how its
  64. //use is nearly identical to pwmWrite()
  65. while(true)
  66. {
  67.    //setting the duty to 50% with 8 bit pwm. 128 is 1/2 of 256
  68.    pwmWrite(led, 128);
  69.    Serial.println("8-Bit PWM");
  70.    delay(1000);
  71.
  72.    //setting the duty to 50% with the highest possible resolution that
  73.    //can be applied to the timer (up to 16 bit). 1/2 of 65536 is 32768.
  74.    pwmWriteHR(led, 32768);
  75.    Serial.println("High Resolution PWM");
  76.    delay(1000);
  77. }
  78. }
  79. void loop()
  80. {
  81. }
PWM.zip (14.53 KB, 下载次数: 36)
收藏收藏3 分享淘帖 顶顶 踩踩
ID:189412 发表于 2022-5-9 07:58 | 只看该作者
thank you so much.
ID:1026624 发表于 2022-5-15 00:38 | 只看该作者
thank you so much.
ID:830831 发表于 2022-5-15 09:03 | 只看该作者
楼主给力 我就改不成功
ID:138707 发表于 2023-7-29 18:28 | 只看该作者
楼主给力 我就改不成功,我在试一试
