查看: 2470|回复: 3
单片机LED点阵实现了垂直方向的滚动显示程序,如何修改为水平滚动?
ID:884109 发表于 2021-5-2 21:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用LED点阵滚动显示数字,实现了垂直方向的滚动(代码如下),但是怎么实现水平方向上的滚动呢?
我把行列扫描互换后,水平是水平了,可数字全躺平了 该怎么解决呢?请各位大神帮帮忙吧,先谢了.
#include <REG51.H>
#define uchar unsigned char //8 0-255
#define uint unsigned int   //16  0-65535
void delay(uint xms)
          uint i,j;
        for(i=xms; i>0; i--)
                for(j=111; j>0; j--);
uchar code table[] = {
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,  //0
0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x20,0x18,0x20,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x20,0x30,0x28,0x24,0x24,0x22,0x22,0x7E,0x20,0x20,0x78,0x00,0x00,
0x00,0x00,0x00,0x7E,0x02,0x02,0x02,0x1A,0x26,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x38,0x24,0x02,0x02,0x1A,0x26,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
0x00,0x00,0x00,0x7E,0x22,0x22,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x64,0x58,0x40,0x40,0x24,0x1C,0x00,0x00, //9
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
};  //0-9 8*16点阵数组
uchar code scan[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
void main(void)
        uchar i,j,k;
          while(1){
                 for( i = 0; i < 196; i=i+2){
                        for(k = 0; k<20; k++){
                                for(j = 0; j<8; j++){
                                        P1 = P3 = P2 = 0x00;
                                         P1 = table[i+j];
                                        P3 = scan[j];
                                        P2 = 0x00;
                                        delay(1);
                                        P1 = table[i+j+8];
                                        P3 = 0x00;
                                        P2 = scan[j];
                                        delay(1);
ID:390416 发表于 2021-5-3 13:12 | 只看该作者
算法比较复杂 我做过8*8点阵的 上下左右 四个斜角的移位
ID:275826 发表于 2021-5-3 14:45 | 只看该作者
要简单的话就重新取模
ID:358019 发表于 2021-6-9 21:35 | 只看该作者
最简单方法就是把点阵转90°
