查看: 2921|回复: 0
大佬帮我看看单片机程序问题出在了哪里?负氧离子浓度数据+esp8266上传
50黑币
想要实现将负氧离子浓度数据通过esp8266上传到网络调试助手,开始我调试了之后发现网络调试助手连接不上热点,也没有负氧离子浓度数
  1. #include "STC12C5A60S2.h"
  2. #define S2RI 0x01
  3. #define S2TI 0x02
  4. sbit ESP8266_RST_Pin=P2^4;
  5. sbit ESP8266_CH_PD_Pin=P2^3;
  6. typedef  unsigned char u8;
  7. typedef  unsigned int u16;
  8. bit flagFrame = 0;
  9. bit flagTxd = 0;
  10. u8 cntRxd = 0;
  11. u8 cntTxd;
  12. u8 pdata bufRxd[7];
  13. u8 *ptrTxd;
  14. u8 crch,crcl;
  15. u8 datas[14];
  16. unsigned char pdata buf[40];
  17. void delayms(u8 ms)
  18. {
  19.          u8 i;
  20.          while(ms--)
  21.          {
  22.           for(i = 0; i < 120; i++);
  23.          }
  24. }
  25. void InitUART  (void)
  26. {
  27.     SCON  = 0x50;
  28.     TMOD |= 0x20;
  29.     TH1   = 0xFD;
  30.     TR1   = 1;
  31.     EA    = 1;
  32.     ES    = 1;
  33.           S2CON = 0x50;
  34.     BRT = 0xFD;
  35.     AUXR = 0x10;
  36.     IE2 =0x01;
  37. }
  38. void UART_1SendOneByte(unsigned char c)
  39. {
  40.     SBUF = c;
  41.     while(!TI);
  42.     TI = 0;
  43. }
  44. void ESP8266_SendCmd(u8 *pbuf)
  45. {
  46.         while(*pbuf!='\0')
  47.         {
  48.                 UART_1SendOneByte(*pbuf);
  49.                 delayms(1);
  50.                 pbuf++;
  51.         }
  52.         delayms(1);
  53.         UART_1SendOneByte('\r');
  54.         delayms(1);
  55.         UART_1SendOneByte('\n');
  56.         delayms(1000);
  57. }
  58. void ESP8266_SendData(u8 *pbuf)
  59. {
  60.         ESP8266_SendCmd("AT+CIPSEND=0,9");
  61.         while(*pbuf!='\0')
  62.         {
  63.                 UART_1SendOneByte(*pbuf);
  64.                 delayms(1);
  65.                 pbuf++;
  66.         }
  67.         delayms(1);
  68.         UART_1SendOneByte('\n');
  69.         delayms(10);
  70. }
  71. void ESP8266_ModeInit(void)
  72. {
  73.         ESP8266_RST_Pin=1;
  74.         ESP8266_CH_PD_Pin=1;
  75.         ESP8266_SendCmd("AT+CWMODE=3");
  76.         ESP8266_SendCmd("AT+CWSAP=\"dms\",\"450228450228\",11,0");
  77.         ESP8266_SendCmd("AT+CIPAP=\"192.168.4.1\"");
  78.         ESP8266_SendCmd("AT+RST");
  79.         ESP8266_SendCmd("AT+CIPMUX=1");
  80.         ESP8266_SendCmd("AT+CIPSERVER=1,8080");
  81. }
  82. unsigned char GetCRC16(unsigned char *ptr,  unsigned char len)
  83. {
  84.         unsigned int index;
  85.         unsigned char crch = 0xFF;
  86.         unsigned char crcl = 0xFF;
  87.         unsigned char code TabH[] ={
  88.         0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  89.             0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  90.             0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  91.             0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  92.             0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
  93.                 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
  94.                 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
  95.                 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  96.                 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  97.                 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
  98.         0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
  99.             0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  100.             0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  101.             0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
  102.             0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  103.                 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  104.                 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  105.                 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  106.                 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  107.                 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  108.                 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  109.                 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
  110.                 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
  111.                 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  112.                 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  113.             0x80, 0x41, 0x00, 0xC1, 0x81, 0x40
  114.                 } ;
  115.                  unsigned char code TabL[] = {
  116.                  0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
  117.                  0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
  118.                  0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
  119.                  0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
  120.                  0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
  121.                  0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
  122.                  0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
  123.                  0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
  124.                  0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
  125.                  0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
  126.                  0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
  127.                  0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
  128.                  0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
  129.                  0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
  130.                  0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
  131.                  0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
  132.                  0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
  133.                  0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
  134.                  0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
  135.                  0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
  136.                  0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
  137.                  0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
  138.                  0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
  139.                  0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
  140.                  0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
  141.                  0x43, 0x83, 0x41, 0x81, 0x80, 0x40
  142.                  } ;
  143.                   while (len--)
  144.                    {
  145.                      index = crch ^ *ptr++;
  146.                      crch = crcl ^ TabH[index];
  147.                      crcl = TabL[index];
  148.                    }
  149.      return((crch<<8)|crcl);
  150. }
  151. void Timer0Init()
  152. {
  153.         TMOD|=0X01;
  154.         TH0=0XFC;
  155.         TL0=0X18;
  156.         ET0=1;
  157.         EA=1;
  158.         TR0=1;
  159. }
  160. void UartRxMonitor(unsigned char ms)
  161. {
  162.    static unsigned char cntbkp = 0;
  163.    static unsigned char idletmr = 0;
  164.    if(cntRxd>0)
  165.    {
  166.             if(cntbkp != cntRxd)
  167.          {
  168.                   cntbkp = cntRxd ;
  169.                 idletmr = 0;
  170.          }
  171.           else
  172.           {
  173.              if(idletmr<30)
  174.                  {
  175.                   idletmr += ms;
  176.                    if(idletmr>=30)
  177.                    {
  178.                       flagFrame=1;
  179.                    }
  180.                  }
  181.           }
  182.    }
  183.   else
  184.   {
  185.      cntbkp=0;
  186.   }
  187. }
  188. unsigned char UartRead(unsigned char *buf,unsigned char len)
  189. {
  190.    unsigned char i;
  191.    if(len>cntRxd)
  192.    {
  193.              len = cntRxd;
  194.    }
  195.    for(i=0;i<len;i++)
  196.    {
  197.      *buf++=bufRxd[i];
  198.    }
  199.    cntRxd=0;
  200.    return len;
  201. }
  202. void datapros()
  203. {
  204.    int c;
  205.    c=buf[3]*256+buf[4];
  206.    datas[0]=c/10000;
  207.    datas[1]=c%10000/1000;
  208.    datas[2]=c%10000%1000/100;
  209.    datas[3]=c%10000%1000%100/10;
  210.          datas[4]=c%10000%1000%100%10;
  211.          datas[5]='g';
  212.          datas[6]='/';
  213.          datas[7]='c';
  214.          datas[8]='m';
  215.          datas[9]='3';
  216.          datas[10]='\n';
  217. }
  218. void UartDriver()
  219. {
  220.   unsigned char len;
  221.   u16 crc;
  222.   if(flagFrame)
  223.   {
  224.     flagFrame = 0;
  225.         len = UartRead(buf,sizeof(buf));
  226.     if(buf[0]!=0x04)
  227.         {
  228.          return;
  229.         }
  230.         crc=GetCRC16(buf,len-2);
  231.         crch = crc>>8;
  232.         crcl = crc&0xFF;
  233.         if((buf[len-2]=crch)&&(buf[len-1]=crcl))
  234.           {
  235.       return;
  236.         }
  237.         else
  238.         {
  239.         datapros();
  240.         }
  241.   }
  242. }
  243. void main()
  244. {
  245.     u8 i;
  246.     u8 Order[8]={0x05,0x03,0x00,0x00,0x00,0x02,0xC4,0x0B};
  247.         InitUART();
  248.         Timer0Init();
  249.   ESP8266_ModeInit();
  250.         EA=1;
  251.   while(1)
  252.   {
  253.    delayms(1000);
  254.    for(i=0;i<8;i++)
  255.    {
  256.           S2BUF=Order[i];
  257.           while(!(S2CON&S2TI));
  258.           S2CON&=~S2TI;
  259.    }
  260.     delayms(1000);
  261.         UartDriver();
  262.         ESP8266_SendData(datas);
  263.    }
  264. }
  265. void UART_1Interrupt(void) interrupt 4
  266.         {
  267.         if(RI)
  268.         {
  269.                 RI=0;
  270.                 delayms(100);
  271.         }
  272. }
  273. void UART_2Interrupt(void) interrupt 8
  274. {
  275.    if(S2CON&S2RI)
  276.    {
  277.             S2CON&=~S2RI;
  278.          if(cntRxd<sizeof(bufRxd))
  279.          {
  280.            bufRxd[cntRxd++]=S2BUF;
  281.          }
  282.    }
  283. }
  284. void Timer0() interrupt 1
  285. {
  286.     TH0=0XFC;
  287.         TL0=0X18;
  288.         UartRxMonitor(1);
  289. }
