查看: 3623|回复: 0
基于51单片机万年历LCD12864
ID:747099 发表于 2021-5-5 19:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stdio.h"
#include "math.h"
#include "macroconst.h"
#include "reg52.h"
#include "string.h"
#include "delay.h"
unsigned char code IC_DAT[];//----------------定义数组
unsigned char code pic1[];
unsigned char code pic2[];
unsigned char code pic3[];
sbit    RS =P1^0;//------------------------定义接口信息
sbit    WRD=P1^1;
sbit    E=  P1^2;
sbit    PSB=P2^7;
sbit    RES=P2^5;
void    TransferData(char data1,bit DI); //-------------函数声明
void    display(void);
void    display_grapic(void);
//void    delayms(unsigned int n);
void    DisplayLine(unsigned char line1,unsigned char line2);
void    DisplayGraphic(unsigned char code *adder);
//void    delay(unsigned int m);
void    lcd_mesg(unsigned char code *adder1);
//unsigned char code IC_DAT[]={
//"就辞白帝彩云间,"
//"千里江陵一日还。"
//"两岸猿声啼不住,"
//"轻舟已三万重山。"
//unsigned char code IC_DAT2[]={
//"海纳百川宽容为先"
//"欲成大业诚信为先"
//"游弋商海济世为先"
//"人立于世守法为先"
void    TransferData(char data1,bit DI)  //------------传送数据或者命令,当DI=0是,传送命令,当DI=1,传送数据.
            WRD=0;
            RS=DI;
            delay(1);
            P0=data1;
            E=1;
            delay(1);
            E=0;
//void    delayms(unsigned int n)//--------------------延时10×n毫秒程序
//                      unsigned int i,j;
//                      for(i=0;i<n;i++)
//                         for(j=0;j<2000;j++);
//void    delay(unsigned int m)//----------------------延时程序
//                      for(i=0;i<m;i++)
//                         for(j=0;j<20;j++);
void     initina1(void)           //------------LCD字库初始化程序
           delay(40);             //大于40MS的延时程序
           PSB=1;                 //设置为8BIT并口工作模式
           delay(1);              //延时
           RES=0;                 //复位
           delay(1);              //延时
           RES=1;                 //复位置高
           delay(10);
           TransferData(0x30,0);  //Extended Function Set :8BIT设置,RE=0: basic instruction set, G=0 :graphic display OFF
           delay(100);            //大于100uS的延时程序
           TransferData(0x30,0);  //Function Set
           delay(37);             ////大于37uS的延时程序
           TransferData(0x08,0);  //Display on Control
           TransferData(0x10,0);  //Cursor Display Control光标设置
           TransferData(0x0C,0);  //Display Control,D=1,显示开
           TransferData(0x01,0);  //Display Clear
           delay(10);             //大于10mS的延时程序
           TransferData(0x06,0);  //Enry Mode Set,光标从右向左加1位移动
void     initina2(void)           //-------------LCD显示图片(扩展)初始化程序
           delay(1);              //延时
           RES=0;                 //复位
           delay(1);              //延时
           RES=1;                 //复位置高
           delay(10);
           TransferData(0x36,0);  //Extended Function Set RE=1: extended instruction
           TransferData(0x36,0);  //Extended Function Set:RE=1: extended instruction set
           TransferData(0x3E,0);  //EXFUNCTION(DL=8BITS,RE=1,G=1)
           TransferData(0x01,0);  //CLEAR SCREEN
void Lcd_Set_Post(uchar y,uchar x)  //设置显示位置
uchar Address;
if(y==1){Address = 0x80 + x;}
if(y==2){Address = 0x90 + x;}
if(y==3){Address = 0x88 + x;}
if(y==4){Address = 0x98 + x;}
TransferData(Address,0);
void LCD_WRITE_CHAR(uchar *Word)//------------------------写字
while(*Word)
TransferData(*Word,1);
Word ++;
void DisplayGraphic(unsigned char code *adder)//-------画数字 图
   int i,j;
                                  //显示上半屏内容设置
   for(i=16;i<32;i++)              //
      TransferData((0x80 + i),0); //SET  垂直地址 VERTICAL ADD
      TransferData(0x80,0);       //SET  水平地址 HORIZONTAL ADD
      for(j=0;j<2;j++)
         TransferData(*adder,1);
         adder++;
                                  //显示下半屏内容设置
   for(i=0;i<16;i++)              //
      TransferData(0x88,0);       //SET 水平地址 HORIZONTAL ADD
      for(j=0;j<2;j++)
         adder++;
void display()                  //为反白做准备,目地是在图形显示时防止有噪点
  uchar i,j;
  TransferData(0x34,0);        //写数据时,关闭图形显示
  for(i=0;i<32;i++)
    TransferData(0x80+i,0);    //先写入水平坐标值
    TransferData(0x80,0);      //写入垂直坐标值
    for(j=0;j<16;j++)   //再写入两个8位元的数据
    TransferData(0x00,1);
    delay(1);
  for(i=0;i<32;i++)
    TransferData(0x88,0);      //写入垂直坐标值
    delay(1);
  TransferData(0x36,0);       //写完数据,开图形显示
void white(uchar x,uchar y,uchar width)                //反白,X值为0-7,Y值为0-3,width为行反白格数
  uchar i,j,flag=0x00;
  display();
  if(y>1)
   flag=0x08;
   y=y-2;
//  TransferData(0x34,0);        //写数据时,关闭图形显示,且打开扩展指令集
        for(i=0;i<16;i++)
                TransferData((0x80+(y<<4)+i),0);
                TransferData((0x80+flag+x),0);
                for(j=0;j<width;j++)
                TransferData(0xff,1);
                delay(1);
//        TransferData(0x36,0);       //写完数据,开图形显示
//        lcd_wcmd(0x30);       //从扩展指令到基本指令
51黑论坛_12864万年历.zip
227.32 KB, 下载次数: 30, 下载积分: 黑币 -5
收藏收藏2 分享淘帖 顶顶 踩踩
