查看: 1629|回复: 0
SL1573 1MHz,2A级电流模式pwm变换器
General Description
The SL1573 is a current mode boost DC-DC converter. Its PWM circuitry with built-in 0.2Ω powerMOSFET make this regulator highly power efficient. The internal compensation network also minimizesas much as 6 external component counts. The non-inverting input of error amplifier connects to a 0.6Vprecision reference voltage and internal soft-start function can reduce the inrush current.
The SL1573 is available in the SOT23-6L package and provides space-saving PCB for theapplication fields.
Features
▶ Adjustable Output up to 12V
▶ Internal Fixed PWM frequency: 1.0MHz
▶ Precision Feedback Reference Voltage: 0.6V (±2%)
▶ Internal 0.2Ω, 2A, 16V Power MOSFET
▶ Shutdown Current: 0.1μA
▶ Over Temperature Protection
▶ Adjustable Over Current Protection: 0.5A ~ 2.5A
▶ Package: SOT23-6L
Applications
▶ Chargers
▶ LCD Displays
▶ Digital Cameras
▶ Handheld Devices
▶ Portable Products
Typical Application Circuit
