查看: 4614|回复: 8
有大神可以帮忙翻译一下这段单片机代码的大致意思吗?
回帖奖励 50 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次(中奖概率 30%)
最近在做单片机项目,网上找了许多相似的借鉴,但是C语言程序实在难以看懂全部,想修改程序功能能以下手,希望有大佬可以帮忙看一下下面这段代码,解释一下每段代码、函数是什么意思,达到什么目的
#include <REG52.H>
#define uint  unsigned int
#define qiang_ledon qiang_led=1;
#define qiang_ledoff qiang_led=0;
#define biao_ledon biao_led=1;
#define biao_ledoff biao_led=0;
#define ruo_ledon ruo_led=1;
#define ruo_ledoff ruo_led=0;
#define piao_ledon piao_led=1;
#define piao_ledoff piao_led=0;
#define sgan_ledon sgan_led=1;
#define sgan_ledoff sgan_led=0;
#define jin_ledon jin_led=1;
#define jin_ledoff jin_led=0;
#define pai_ledon pai_led=1;
#define pai_ledoff pai_led=0;
unsigned char code Tab[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //数码管显示0~9的段码表
unsigned char int_time;        //记录中断次数
unsigned char second;        //储存秒
uint t=0,tt=0;
   sbit k1=P0^0;
   sbit k2=P0^1;
   sbit k3=P0^2;
   sbit sg=P0^3;
   sbit hk1=P0^4;
   sbit hk2=P0^5;
   sbit ledon=P0^7;
   sbit qiang_led=P2^0;
   sbit biao_led=P2^1;
   sbit ruo_led=P2^2;
   sbit piao_led=P2^3;
   sbit sgan_led=P2^4;
   sbit jin_led=P2^5;
   sbit pai_led=P2^6;
   sbit p30=P3^0;
   sbit p31=P3^1;
   sbit beepon=P2^7;
   sbit sm1=P3^6;
   sbit sm2=P3^7;
void delay2(void)
  unsigned char m;
  for(m=0;m<200;m++)
void delay1(int s)
   int i;
   for(;s>0;s--)
   for(i=0;i<65;i++);
void delay(uint i)
   uchar j;
   for(i;i>0;i--)
   for(j=255;j>0;j--);
void DisplaySecond(unsigned char k)
   sm1=0;        //P2.6引脚输出低电平, DS6点亮
   P1=Tab[k/10];          //显示十位
     delay2();
     delay2();
   sm1=1;
   sm2=0;       //P2.7引脚输出低电平, DS7点亮
   P1=Tab[k%10];         //显示个位
     delay2();
     delay2();
   P3=0xff;     //关闭所有数码管
   P1=1;        //显示个位
     delay2();
     delay2();
void beep()
          p30=0;
    p31=0;
           t=0;
          beepon^=1;
      delay(300);
      if(t>=80) break;
        beepon=0;
        biao_led=0;
void f_qiang()
         qiang_ledon;
         t=0;
         tt=0;
     int_time=0;
     second=00;
          if(tt>=400) break;
      t=0;
          while(t<80&&tt<=400)
            p31=0;
            p30=1;        //正转 4s
        DisplaySecond(second);
          t=0;          //反转 4s
            p30=0;
            p31=1;
          p30=0;
          p31=0;
void f_biao()
          qiang_led=0;
      biao_led=1;
          t=0;
          tt=0;
      int_time=0;
      second=00;
           if(tt>=400) break;
           t=0;
          while(t<60&&tt<=400)
          p31=0;
                  p30=1;        //正转3s
                t=0;          //反转3s
              p30=0;
                  p31=1;
       p30=0;
           p31=0;
void f_ruo()
          qiang_led=0;
          biao_led=0;
          ruo_led=1;
          t=0;
          tt=0;
      int_time=0;
       second=00;
                    if(tt>=400) break;
                 t=0;
               while(t<40&&tt<=400)
           {        p31=0;
                        p30=1;        //正转2s
             t=0;          //反转 2s
            {   p30=0;
                        p31=1;
                p30=0;
            p31=0;
void f_piao()
           qiang_ledoff;
           biao_ledoff;
           piao_ledon;
           t=0;
           tt=0;
       int_time=0;
       second=00;
                      if(tt>=400) break;
                   t=0;
               {        p31=0;
                        p30=1;        //正转2s
                   t=0;          //反转2s
               {    p30=0;
                            p31=1;
          p30=0;
      p31=0;
          piao_ledoff;
void pai_leds()
            p30=0;
            p31=0;
               pai_led=1;        //排水阀灯亮 等待霍尔开关2
            while(hk2);
            if(hk2==0)  //如果闭合
            pai_led=0;        //排水灯灭
void jin()
            p30=0;
            p31=0;
            jin_ledon;
             while(hk1);
            if(hk1==0)
            jin_ledoff;
void sgan()
            sgan_ledon;         //甩干灯亮
             t=0;
        int_time=0;
        second=00;
             while(t<=400)
                            p31=0;
                        p30=1;
        sgan_ledoff;
void sgan1()
           sgan_ledon;
            t=0;
       int_time=0;
       second=00;
             while(t<=400)
                           p31=0;
                   p30=1;
        piao_ledoff;
        sgan_ledoff;
        beep();
            t=401;
void f_an1()
        qiang_ledon; //方案1灯亮
        jin();  //进入强洗
        f_qiang();         //循环20S
        delay1(4000);//延时4s
        f_biao();  //循环20S
        delay1(4000);//延时4s
        f_ruo();  //循环20S
        ruo_ledoff;
        pai_leds();
        delay1(1000); //延时1S 进入甩干
        sgan(); //甩干20s
        sgan_ledoff;
        ruo_ledoff;
        piao_ledoff;
        jin();
        delay1(1000); //延时1S 进入漂洗
        f_piao();  //循环20S
        sgan_ledoff;
        piao_ledoff;
        pai_leds();
        sgan1();//最终甩干20S
        delay(500);//延时
        beep();
void f_an2()
        biao_ledon; //方案1灯亮
        jin();
        f_biao();  //循环20S
        delay1(4000); //延时4S
        f_ruo();  //循环20S
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20s
        ruo_ledoff;
        piao_ledoff;
        jin();
        f_piao();  //循环20S
        sgan_led=0;
        pai_leds();
        sgan();//最终甩干20s
        delay(500);//延时5s
        piao_led=0;
        beep();
void f_an3()
        ruo_led=1; //方案1灯亮
        jin();
        f_ruo();  //循环20S
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20S
        ruo_ledoff;
        piao_ledoff;
        jin();
        f_piao();  //循环20S
        sgan_led=0;
        pai_leds();
        sgan();//最终甩干20s
        delay(500);//延时5s
        piao_led=0;
        p30=0;
        beep();
int main(void)
  TMOD=0x01;       //方式1 16位计数器
  TH0=-50000/256;   //设定初值
  TL0=-50000%256;
  EA=1;               //开总中断
  ET0=1;             //开定时器0中断
  TR0=1;             //启动定时器0
  P2=0;
  int_time=0;     //中断次数初始化
  second=00;           //秒初始化
          if(k1==0)
                delay(10);
                if(k1==0)
                        f_an1();
        if(k2==0)
                delay(10);
                if(k2==0)
                        f_an2();
        if(k3==0)
            delay(10);
           if(k3==0)
                    f_an3();
         if(sg==0)
                delay(10);
                if(sg==0)
                   sgan1();
        return 0;
void time0() interrupt 1 using 1
     int_time ++;        //每来一次中断,中断次数int_time自加1
    if(int_time==20)   //够20次中断,即1秒钟进行一次检测结果采样
        int_time=0;    //中断次数清0
        second++;    //秒加1
   TH0=-50000/256;   //50000  =50ms中断一次
   TL0=-50000%256;
   t++;
   tt++;
洗衣机仿真.zip
131.02 KB, 下载次数: 6
来自 4#
ID:328014 发表于 2021-5-17 18:37 | 只看该作者
你是while(1)大循环看不懂吗?我帮你注释几行吧
while(1)//死循环
          if(k1==0)//按键消抖,如果不懂可以论坛搜索消抖教程:http://www.51hei.com/bbs/dpj-133523-1.html
                delay(10);//延时
                if(k1==0)////按键消抖
                        f_an1();//执行方案1
ID:311846 发表于 2021-5-17 10:35 | 只看该作者
一堆注释都看不懂?你C没学会改毛线,洗洗睡。一堆代码谁有这闲工夫和你扯淡,自己认真学认真看,哪个点不懂问问还差不多
ID:824490 发表于 2021-5-17 10:47 | 只看该作者
权威人物 发表于 2021-5-17 10:35
一堆注释都看不懂?你C没学会改毛线,洗洗睡。一堆代码谁有这闲工夫和你扯淡,自己认真学认真看,哪个点不 ...
霸气!
确实如此,不要一来就是一张图、一份代码,让人家帮你?帮是情分,不帮是本分,毕竟不是在学校,网友也不是你的老师,每个人都是忙里偷闲地上网看看,
应该是把你遇到的问题、你的思路发上来,这样大家才能更有效在帮你。
ID:919394 发表于 2021-5-17 18:49 | 只看该作者
谨遵教诲。小白刚接触单片机,下次注意
ID:919394 发表于 2021-5-17 18:53 | 只看该作者
while(1)//死循环
懂了 谢谢老哥
ID:919394 发表于 2021-5-17 19:05 | 只看该作者
名字不是重点 发表于 2021-5-17 10:47
霸气!
确实如此,不要一来就是一张图、一份代码,让人家帮你?帮是情分,不帮是本分,毕竟不是在学校, ...
明白了,谢谢老哥指点,下次一定改正
ID:743654 发表于 2021-5-18 08:49 | 只看该作者
确实不要做伸手党,不懂自己先查资料,哪里薄弱补哪里,C语言是基础。
遇到问题解决问题,这样才能提高!
ID:919834 发表于 2021-5-18 09:34 | 只看该作者
我建议弄个程序流程图吧。你这个照搬还不懂的。有点难搞。一个功能一个模块。这样就清晰了
