查看: 2245|回复: 0
单片机程序为什么时间有时快有时慢还有闹钟响了只会为什么秒数不会增加?
ID:924233 发表于 2021-5-20 08:47 | 显示全部楼层 |阅读模式
能不能帮我看一下,先谢谢
#include<reg51.h>
#include<intrins.h>
#define LCD1602_DB  P0 //定义1602的DB口为P0口
uchar code table[]="CurrentTime"; //当前时间
uchar code table1[]="00:00:00";
uchar key1Flag = 0;//定义按键关闭符
uchar key2Flag = 0;
uchar key3Flag = 0;
uchar key4Flag = 0;
uchar count = 0;
uchar sec = 57;//秒
uchar min = 59;//分
uchar hour = 9;//小时
uchar clockHour = 0;//闹钟小时
uchar clockMin = 0;//分
uchar clockFlag = 0;// 定义闹钟关闭符
uchar beepNum = 0;//声音
uchar temp=0;
uchar shijian=0;
sbit LCD1602_RS = P2^0;        //指令1/数据0选择端
sbit LCD1602_RW = P2^1;        //读1写0选择端
sbit LCD1602_E = P2^2;        //读1写0使能端
sbit Key1 = P1^0;//定义键位符
sbit Key2 = P1^1;
sbit Key3 = P1^2;
sbit Key4 = P1^3;
sbit Speaker = P2^5;//定义蜂鸣器
sbit LED=P2^4;
void Delay1ms()                //@12.000MHz
        uchar i, j;
        i = 12;
        j = 169;
        do
                while (--j);
        } while (--i);
void Delay20ms()                //@12.000MHz
        uchar i, j, k;
        _nop_();
        _nop_();
        i = 1;
        j = 234;
        k = 113;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void delay()
    unsigned int a;
        while(a--);
void Beep()         //蜂鸣器警报
        Speaker = 0;
        Delay20ms();
        Speaker = 1;
void LcdWaitReady()         //检查LCD忙函数
        uchar sta;
        LCD1602_DB = 0xFF;
        LCD1602_RS = 0;
        LCD1602_RW = 1;
        do        {
                LCD1602_E = 1;
                sta = LCD1602_DB;
                LCD1602_E = 0;
        }while(sta & 0x80);
void LcdWriteCmd(uchar cmd)        //写命令函数
        LcdWaitReady();
        LCD1602_RS = 0;
        LCD1602_RW = 0;
        LCD1602_DB = cmd;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdWriteDat(uchar dat)        //写数据函数
        LcdWaitReady();
        LCD1602_RS = 1;
        LCD1602_RW = 0;
        LCD1602_DB = dat;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdSetCursor(uchar x, uchar y)//时间设置
        uchar addr;
        if(y == 0)
                addr = 0x00 + x;
                addr = 0x40 + x;
        LcdWriteCmd(addr | 0x80);
void LcdShowStr(uchar x, uchar y, uchar *str)
        LcdSetCursor(x, y);
        while(*str != '\0')
                LcdWriteDat(*str++);
void InitLcd1602()//初始化LCD函数
        LcdWriteCmd(0x01);
        LcdWriteCmd(0x38);
        LcdWriteCmd(0x0c);
        LcdWriteCmd(0x06);
void WriteAddress(uchar x)
         LcdWriteCmd(0x80 + x);
void DisplayMinTens()   //显示分十位
        WriteAddress(0x49);
        LcdWriteDat((min / 10) + '0');
        Delay1ms();
void DisplayMinUnits()          //显示分个位
        WriteAddress(0x4A);
        LcdWriteDat((min % 10) + '0');
        Delay1ms();
void DisplayHourTens()   //显示时十位
        WriteAddress(0x46);
        LcdWriteDat((hour / 10) + '0');
        Delay1ms();
void DisplayHourUnits()//显示时个位
        WriteAddress(0x47);
        LcdWriteDat((hour % 10) + '0');
        Delay1ms();
void DisplayClkMinTens()  //显示闹钟分十位
        WriteAddress(0x49);
        LcdWriteDat((clockMin / 10) + '0');
        Delay1ms();
void DisplayClkMinUnits() //显示闹钟分个位
        WriteAddress(0x4A);
        LcdWriteDat((clockMin % 10) + '0');
        Delay1ms();
void DisplayClkHourTens()  //显示闹钟时十位
        WriteAddress(0x46);
        LcdWriteDat((clockHour / 10) + '0');
        Delay1ms();
void DisplayClkHourUnits() //显示闹钟时个位
        WriteAddress(0x47);
        LcdWriteDat((clockHour % 10) + '0');
        Delay1ms();
void DisplayClkSecTens() //显示秒十位
        WriteAddress(0x4C);
        LcdWriteDat((sec / 10) + '0');
        Delay1ms();
void DisplayClkSecUnits() //显示秒个位
        WriteAddress(0x4D);
        LcdWriteDat((sec % 10) + '0');
        Delay1ms();
void ScanKey4()
        if((Key4 == 0)&(clockFlag ==1))
                Delay20ms();
                        clockFlag = 0;
                        beepNum = 0;
                        key4Flag = 0;
void InitTimer0()//初始化定时器0
        TMOD = 0x11;
        TH0 = (65536 - 50000) / 256;
        TL0 = (65536 - 50000) % 256;
        TH1 = (65536 - 50000) / 256;
        TL1 = (65536 - 50000) % 256;
        ET1=1;
   ET0=1;
        EA = 1;
        PT0=1;
        TR0=1;
        TR1=1;
void main()//主函数
        InitLcd1602();
        LcdShowStr(0,0,table);
        LcdShowStr(6,1,table1);
        InitTimer0();
                if(sec == 60)
                sec = 0;
                min++;
                if(min == 60)
                        min = 0;
                        hour++;
                if(hour == 24)
                        hour = 0;
                DisplayHourTens();
                DisplayHourUnits();
                LcdShowStr(8,1,":");
                DisplayMinTens();
                DisplayMinUnits();
                LcdShowStr(11,1,":");
                DisplayClkSecUnits();
                DisplayClkSecTens();
                if((Key1 == 0)&(key1Flag == 0)) {              //设置当前时间
                        Delay20ms();
                                TR0 = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"SetCurrentTime");
                                DisplayHourTens();
                                DisplayHourUnits();
                                DisplayMinTens();
                                DisplayMinUnits();
                                key1Flag = 1;
                while(key1Flag == 1)
                        if(Key1 == 0) {
                                Delay20ms();
                                if(Key1 == 0)
                                        hour++;
                                        if(hour == 24)
                                                hour = 0;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        if(Key2 == 0)
                                Delay20ms();
                                if(Key2 == 0)
                                        min++;
                                        if(min == 60)
                                                min = 0;
                                                hour++;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        if((Key3 == 0)&(key1Flag == 1)) {                 //退出设置当前时间
                                Delay20ms();
                                        InitLcd1602();
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                                        key1Flag = 0;
                                        TR0 = 1;
                if((min==0)&(sec<5)) //时间到整点
                         LED=0;
                        delay();
                         Beep();
                         Beep();
                         Delay20ms();
                if((min==0)&(sec>=5))
                LED=1;
                if((Key2 == 0)&(key2Flag == 0))
                {                        //显示闹钟时间
                        Delay20ms();
                                key2Flag = 1;
                                InitLcd1602();
                                while(key2Flag == 1)
                                        LcdShowStr(0,0,"Clock Time");
                                        DisplayClkHourTens();
                                        DisplayClkHourUnits();
                                        DisplayClkMinTens();
                                        DisplayClkMinUnits();
                                        if(Key2 == 0)
                                                Delay20ms();
                                                if(Key2 == 0)
                                                        key2Flag = 0;
                                                        InitLcd1602();
                                                        DisplayHourTens();
                                                        DisplayHourUnits();
                                                        DisplayMinTens();
                                                        DisplayMinUnits();
                if((Key3 == 0)&(key3Flag == 0))         //设置闹钟时间
                        Delay20ms();
                                TR0 = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"SetClockTime");
                                key3Flag = 1;
                while(key3Flag == 1)
                        if(Key1 == 0)
                                Delay20ms();
                                if(Key1 == 0)
                                         clockHour++;
                                         if(clockHour == 24)
                                                 clockHour = 0;
                        if(Key2 == 0)
                                Delay20ms();
                                if(Key2 == 0)
                                        clockMin++;
                                        if(clockMin == 60)
                                                clockHour++;
                                                clockMin = 0;
                        if(Key3 == 0)
                        {                                                         //退出设置闹钟时间
                                Delay20ms();
                                if(Key3 == 0)
                                        key3Flag = 0;
                                        InitLcd1602();
                                        TR0 = 1;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                if((Key4 == 0)&(key4Flag == 0)) //闹钟ON/OFF位设置
                        Delay20ms();
                                key4Flag = 1;
                                InitLcd1602();
                                LcdShowStr(0,0,"Clock ON");
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                if((Key4 == 0)&(key4Flag == 1))         //闹钟ON/OFF位设置
                        Delay20ms();
                                key4Flag = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"Clock OFF");
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
        if((key4Flag == 1)&(hour == clockHour)&(min == clockMin))
                        clockFlag = 1;                                                         //闹钟时间到
                        InitLcd1602();
                        LcdShowStr(0,0,"Time's up");
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        while(clockFlag == 1)
                            LED=!LED;
                                Beep();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                        Delay20ms();
                                ScanKey4();
                                        Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                beepNum++;
                                if(beepNum == 20)
                                        clockFlag = 0;
                                        beepNum = 0;
                                        key4Flag = 0;
                                        LED=1;
void Timer0() interrupt 1
        temp++;
        if(temp == 20)
                sec++;
                temp = 0;
void Timer1() interrupt 3
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
