查看: 3582|回复: 5
STC15F2K60S2单片机串口2用定时器2做波特率发生器的问题
STC15F2K60S2串口2用定时器2做波特率发生器的问题:
1. STC15F2K60S2串口2用定时器2做波特率发生器
2. 用STC-ISP工具里面提供的例程
结果:通过PC端的串口助手发送数据,没有应答;重启就会收到0x00
求大神帮忙解惑,代码如下,源于例程,基本没有更改过
/* 如果要在文章中应用此代码,请在文章中注明使用了STC的资料及程序        */
//本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
//若无特别说明,工作频率一般为11.0592MHz
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 11059200L          //系统频率
#define BAUD 9600             //串口波特率
#define NONE_PARITY     0       //无校验
#define ODD_PARITY      1       //奇校验
#define EVEN_PARITY     2       //偶校验
#define MARK_PARITY     3       //标记校验
#define SPACE_PARITY    4       //空白校验
#define PARITYBIT NONE_PARITY   //定义校验位
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr AUXR  = 0x8e;               //辅助寄存器
sfr S2CON = 0x9a;               //UART2 控制寄存器
sfr S2BUF = 0x9b;               //UART2 数据寄存器
sfr T2H   = 0xd6;               //定时器2高8位
sfr T2L   = 0xd7;               //定时器2低8位
sfr IE2   = 0xaf;               //中断控制寄存器2
#define S2RI  0x01              //S2CON.0
#define S2TI  0x02              //S2CON.1
#define S2RB8 0x04              //S2CON.2
#define S2TB8 0x08              //S2CON.3
sfr P_SW2   = 0xBA;             //外设功能切换寄存器2
#define S2_S0 0x01              //P_SW2.0
bit busy;
void SendData(BYTE dat);
void SendString(char *s);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
    P_SW2 &= ~S2_S0;            //S2_S0=0 (P1.0/RxD2, P1.1/TxD2)
//  P_SW2 |= S2_S0;             //S2_S0=1 (P4.6/RxD2_2, P4.7/TxD2_2)
#if (PARITYBIT == NONE_PARITY)
    S2CON = 0x50;               //8位可变波特率
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    S2CON = 0xda;               //9位可变波特率,校验位初始为1
#elif (PARITYBIT == SPACE_PARITY)
    S2CON = 0xd2;               //9位可变波特率,校验位初始为0
#endif
    T2L = (65536 - (FOSC/4/BAUD));   //设置波特率重装值
    T2H = (65536 - (FOSC/4/BAUD))>>8;
    AUXR = 0x14;                //T2为1T模式, 并启动定时器2
    IE2 = 0x01;                 //使能串口2中断
    EA = 1;
    SendString("STC15F2K60S2\r\nUart2 Test !\r\n");
    while(1);
UART2 中断服务程序
BYTE tempData;
void Uart2() interrupt 8
    if (S2CON & S2RI)
        S2CON &= ~S2RI;         //清除S2RI位
        P0 = S2BUF;             //P0显示串口数据
        S2BUF = P0;
        P2 = (S2CON & S2RB8);   //P2.2显示校验位
    if (S2CON & S2TI)
        S2CON &= ~S2TI;         //清除S2TI位
        busy = 0;               //清忙标志
发送串口数据
    while (busy);               //等待前面的数据发送完成
    ACC = dat;                  //获取校验位P (PSW.0)
    if (P)                      //根据P来设置校验位
#if (PARITYBIT == ODD_PARITY)
        S2CON &= ~S2TB8;        //设置校验位为0
#elif (PARITYBIT == EVEN_PARITY)
        S2CON |= S2TB8;         //设置校验位为1
#endif
#endif
    busy = 1;
    S2BUF = ACC;                //写数据到UART2数据寄存器
发送字符串
    while (*s)                  //检测字符串结束标志
        SendData(*s++);         //发送当前字符
ID:911776 发表于 2021-5-31 16:57 | 只看该作者
不是代码的问题,是需要先确认是普通串口还是232?485?TTL?
ID:47397 发表于 2021-8-6 20:38 | 只看该作者
遇到类似问题,不返回正确数据,而是发送什么就返回什么,请问你说的“确认是普通串口还是232?485?TTL?”是怎么确认?
ID:161164 发表于 2021-8-6 21:27 来自触屏版 | 只看该作者
硬件接线图?
ID:47397 发表于 2021-8-9 12:03 | 只看该作者
不知怎么回事,我上传不了图片,原理图文件也传不了
ID:47397 发表于 2021-8-9 12:04 | 只看该作者
串口芯片用的是CH340C,和单片机P30、P31通讯
