查看: 2039|回复: 0
ADXL345是怎么来计算步数和判断运动状态的?
ID:890746 发表于 2021-6-7 21:38 | 显示全部楼层 |阅读模式
ADXL345模块做计步器,找到了一段程序但是看不太懂,有大佬教教我,ADXL345是怎么来计算步数和判断运动状态的啊......
#include<reg52.h>
#include<stdio.h>
#include "delay.h"
#include "math.h"
#include "adxl345.h"
#include "1602.h"
sbit led=P1^4;         //引脚定义
unsigned char ReadAdxl345;                 //定时读取adxl345
char dis0[16];                   //串口数据显示
xdata char dis1[16];                   //串口数据显示
xdata char dis2[16];                   //串口数据显示
unsigned long time_20ms=0;           //定时器计数
unsigned char ReportFlag=0;           //数据上报标志
unsigned int BuShu=0;         //累计步数
float JuLi=0;                        //累计距离
float KaLuLi=0;                        //累计卡路里
unsigned char statFlag = 0;//状态
void Init_Timer0(void);                   //函数声明
void SendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void SendByte(unsigned char dat);
void BuShuCheck(void);
void main (void)
        Init_Timer0();        //定时器0初始化
        UART_Init();
        LCD_Init();           //初始化液晶
        DelayMs(20);          //延时有助于稳定
        LCD_Clear();
        Init_ADXL345();          //清屏
        if(Single_Read_ADXL345(0X00)==0xe5)        //读出的数据为0XE5,表示正确
                DelayMs(5);
                DelayMs(3);
        led=1;
        while (1)         //主循环
            if(ReadAdxl345==1)   //定时读取adxl345数据
                        BuShuCheck();                        //检测步数
                        sprintf(dis1,"B:%04d J:%4.1fm ",BuShu/2,JuLi);        //打印
                        LCD_Write_String(0,0,dis1);//显示
                        sprintf(dis2,"%7.2fcal ",KaLuLi);                   //打印
                        LCD_Write_String(0,1,dis2);//显示
                        if(statFlag == 0)//站着状态
                        {LCD_Write_String(11,1,"Stand");}
                        else if(statFlag == 1)////躺着状态
                        {LCD_Write_String(11,1,"Lie  ");}
                        else if(statFlag == 2)//跑着状态
                        {LCD_Write_String(11,1,"Run  ");}
                        else if(statFlag == 3)//走着状态
                        {LCD_Write_String(11,1,"Walk ");}
                if(ReportFlag==1)        //2s
                        ReportFlag=0;
                        sprintf(dis0,"*B:%04d",BuShu/2);        //上报步数
                        SendStr(dis0,7);
                        sprintf(dis0,"J:%04.1fm",JuLi);                        //上报距离
                        SendStr(dis0,7);
                        sprintf(dis0,"K:%07.2fcal",KaLuLi);                   //上报卡路里
                        SendStr(dis0,12);
                        {SendStr("Stand#",6);}
                        {SendStr("Lie  #",6);}
                        {SendStr("Run  #",6);}
                        {SendStr("Walk #",6);}
                        SendStr("\r\n",2);
        static unsigned char ErrorNum=0;           //变量定义
        static unsigned char NormalNum=0;
        static unsigned char CheckNum=0;           //变量定义
        static unsigned char shuNum=0;
        static unsigned char ceNum=0;
        static unsigned int remBuShu=0;
        ReadAdxl345=0;
        ReadData_x();
        CheckNum++;//检测次数
        if((temp_X<650)||(abs(temp_Y)>400))       //查看正常次数
                led=0;                        //呼吸灯
                ErrorNum++;        //记录次数
                shuNum++;//竖直状态++
        {NormalNum++; ceNum++;led=1;} //呼吸灯//侧着状态++
        if((NormalNum!=0)&&(ErrorNum!=0))        //                        从角度判断走了一步
                ErrorNum=0;
                NormalNum=0;
                BuShu++;
                JuLi=(float)(BuShu/2)*0.45;          //计算距离
                KaLuLi=JuLi*70*0.832;                 //卡路里计算 走路 距离*体重*系数
        if(CheckNum>=20)
                if((ceNum!=0)&&(shuNum==0))
                        statFlag = 0;//站着状态
                else if((ceNum==0)&&(shuNum!=0))
                        statFlag = 1;//躺着状态
                else if((ceNum!=0)&&(shuNum!=0))
                        if((BuShu - remBuShu)>=6)//跑着 一个周期大于3步
                        {statFlag = 2;}//跑着状态
                        {statFlag = 3;}//走着状态
                        remBuShu = BuShu;//记录上次步数
                CheckNum=0;
                ceNum=0;                //清空计数
                shuNum=0;
        TMOD |= 0x01;          //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
        TH0=(65536-20000)/256;                  //重新赋值 20ms
        TL0=(65536-20000)%256;
        EA=1;            //总中断打开
        ET0=1;           //定时器中断打开
        TR0=1;           //定时器开关打开
void Timer0_isr(void) interrupt 1
        time_20ms++;
        if(time_20ms%5==0)
                ReadAdxl345=1;
        if(time_20ms%50==0)
                ReportFlag=1;
