查看: 1954|回复: 4
编译出错 求大神帮忙看一下如何修改错误
ID:935561 发表于 2021-6-11 12:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
按照教科书上的程序写的,但是测试发现好多错误。不会改,求大神帮忙改一下让程序能用。
  1. #include”reg51.h"
  2. typedef unsigned int u16;
  3. typedef unsigned char u8;
  4. sbit naodeng=P2^0;
  5. sbit S1=P3^0;
  6. sbit S2=P3^2;
  7. sbit S3=P3^3;
  8. sbit beep=P2^7;
  9. void shijian( );
  10. void Timer0Init ( );
  11. void DigDisplay( );
  12. void alarm( );
  13. void tiao_nao ( );
  14. void moshi ( );
  15. void delay ( u16 i ) ;
  16. bit nao ;
  17. u8 a =0;
  18. u8 dispiay [] = {0,0,0,0,0,0};
  19. u8 ssec, sec, min, hour, nao_hour=0, nao_min=0;
  20. void delay ( u16 i )
  21. {
  22.         while (i--);
  23. }
  24. void Timer0Init  (  )
  25. {
  26.         TMOD =0x01;
  27.         EX0 =1;
  28.         IT0  =1;
  29.         PX0 =1;
  30.         EX1 =1;
  31.         IT1  = 0;
  32.         TH0= 0xd8;
  33.         TL0 = 0xf0;
  34.         ET0 = 1;
  35.         EA=1;
  36.         TR0=1;
  37. }
  38. void DigDisplay (  )
  39. {
  40.         u8 i, j, m, temp;
  41.         u8  led [] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f };
  42.         temp=0x01;
  43.         for ( i=0 ; i<6 ; i++)
  44.         {
  45.          P1=0x00;
  46.          j=display [ i ];
  47.          P1=led [j];
  48.          P0=~temp;
  49.          temp<<=1;
  50.          for ( m=0 ; m<100; m++);
  51.         }
  52. }
  53. void alarm ( )
  54. {
  55.         if ( nao_ hour==hour && nao_ min==min && sec>=0 && sec<15 && nao ==1 )
  56.         {
  57.         beep=1;
  58.         delay (5);
  59.         beep=0;
  60.         delay(5);
  61.         }
  62. }
  63. void tiao_ nao ( )
  64. {
  65.         IT0=0;
  66.         EX1=0;
  67.         EX0=0;
  68.         delay ( 10 ) ;
  69.         while ( S1 )
  70.           {
  71.         if (S2 = =0)
  72.            {delay (10);
  73.          if ( S2==0 )   nao_ hour++;
  74.          while ( ! S2 ) ;  }
  75.         if ( nao_ hour>=24 )        nao_ hour=0;
  76.         if(S3==0)
  77.           {delay ( 10 );
  78.         if (S3==0) nao_ min++; while ( ! S3 )  ; }
  79.         if(nao_ min>=60)  nao_ min=0;
  80.         display [5] =0;
  81.         display [4] =0;
  82.         display [3] =nao_ min%10;
  83.         display [2] =nao_ min/10;
  84.         display [1] =nao_ hour%10;
  85.         display [0] =nao_ hour/10;
  86.         DigDisplay (  ) ;
  87.         }
  88. IT0=1;
  89. EX1=1;
  90. EX0=1;
  91. nao=1;
  92. }
  93. void moshi (  )
  94. {
  95.         if ( S1==0 )
  96.         {
  97.                 delay(100);
  98.                 if(S1==0)
  99.                   {
  100.                             a++;
  101.                         if ( a>=2 ) a=0;
  102.                         while( ! S1);
  103.                         switch (a)
  104.                          {
  105.                            case (0) ; nao=~nao; break;
  106.                            case (1) ; tiao_ nao ( ) ; break;
  107.                          }
  108.                  }
  109.         }while ( ! S1 );
  110. }
  111. void shijian ( )
  112. {
  113.         display [5] =sec%10;
  114.         display [4] =sec/10;
  115.         display [3] =min%10;
  116.         display [2] =min/10;
  117.         display [1] =hour%10;
  118.         display [0] =hour/10;
  119.         DigDisplay ( ) ;
  120. }
  121. void timer0 (  ) interrupt 1
  122. {
  123.         TH0=0xd8;
  124.         TL0=0xf0;
  125.         ssec++;
  126.         if ( ssec>=100 )
  127.         {
  128.                 ssec=0;
  129.                 sec++;
  130.                 if ( sec>=60 )
  131.                 {
  132.                         sec=0;
  133.                         min++;
  134.                         if ( min>=60)
  135.                         {
  136.                                 min=0;
  137.                                 hour++;
  138.                                 if ( hour>=24 )
  139.                                 {
  140.                                      hour=0;
  141.                                 }
  142.                         }
  143.                 }
  144.         }
  145. }
  146. void int0 (  ) interrupt 0
  147. {
  148.         delay (10);
  149.         hour++;
  150.         if (hour>=24)         hour=0;
  151. }
  152. void int1 (  ) interrupt 2
  153. {
  154.         min++;
  155.         if ( min==60 )          min=0;
  156.         while ( ! S3 );
  157. }
  158. void main (  )
  159. {
  160.         Timer0Init (  ) ;
  161.         while ( 1 )
  162.           {
  163.                 if ( nao==1 )  naodeng=0;
  164.                 else naodeng =1;
  165.                 shijian (  );
  166.                 moshi (  );
  167.                 alarm (  );
  168.           }
  169. }
这是一个数字钟的程序,自动计时,由6位LED显示器显示时、分、秒。 具备校准功能,可以设置当前时间。 具备定时启闹功能,可以设置启闹时间并同时开启闹钟功能,启闹15s后自动关闭闹铃。 在闹钟开启状态或闹铃过程中,可以按键关闭闹钟功能
ID:824490 发表于 2021-6-11 14:29 | 只看该作者
“测试发现好多错误”,你是不是该把错误列出来?不然谁能有这个时间帮你调试?
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:936528 发表于 2021-6-11 14:39 | 只看该作者
include""都错了
ID:799382 发表于 2021-6-11 15:25 | 只看该作者
void DigDisplay (  )
        u8 i, j, m, temp;
       请问这一段是什么,如果是LED驱动这是段选还是位选呢??????如果是段选请问位选去哪里了呢????????只有段没有位他该怎么显示出来呢??????
        temp=0x01;
         P1=0x00;
         j=display [ i ];
         P1=led [j];
         P0=~temp;
         temp<<=1;
ID:123289 发表于 2021-6-11 17:36 | 只看该作者
教科书错在哪里呢?
