查看: 2506|回复: 3
关于NTC温度二分查表法的单片机程序问题
ID:602776 发表于 2021-6-25 10:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想问下(AD_temp_data[head]-AD_temp_data[mid])中mid不是赋值给到head,AD_temp_data[head]应该等于AD_temp_data[mid]才对啊,想请教一下大神们
*        函 数 名: AD_Value_To_Temperature
*        功能说明: 折半法查表将AD值转换为温度值,精确到小数点后一位
*        形    参:AD采样值
*        返 回 值: 温度
const INT16U AD_temp_data[182]=   //-20℃~70℃  0.5一格
    2792, 2784, 2776, 2768, 2761, 2752, 2744, 2736, 2727, 2718,
    2710, 2700, 2691, 2682, 2672, 2663, 2653, 2643, 2632, 2622,
    2612, 2601, 2590, 2579, 2568, 2556, 2545, 2533, 2521, 2509,
    2497, 2484, 2472, 2459, 2446, 2433, 2420, 2407, 2393, 2379,
    2364, 2350, 2336, 2322, 2307, 2293, 2278, 2263, 2248, 2233,
    2218, 2202, 2187, 2171, 2156, 2140, 2124, 2108, 2092, 2076,
    2061, 2044, 2027, 2010, 1993, 1977, 1960, 1943, 1926, 1909,
    1893, 1876, 1859, 1842, 1825, 1807, 1790, 1773, 1756, 1739,
    1722, 1705, 1687, 1670, 1653, 1636, 1619, 1602, 1585, 1568,
    1551, 1534, 1517, 1500, 1484, 1467, 1450, 1434, 1417, 1401,
    1385, 1368, 1352, 1336, 1320, 1304, 1288, 1273, 1257, 1241,
    1226, 1211, 1195, 1180, 1165, 1150, 1135, 1121, 1106, 1092,
    1078, 1064, 1049, 1036, 1022, 1008, 994        , 981 , 968        , 955 ,
    942        , 929 , 916 , 904 , 891        , 879 , 866        , 854 , 842        , 829 ,
    816        , 806 , 796        , 785 , 774        , 763 , 752        , 741 , 731        , 720 ,
    710        , 700 , 689        , 680 , 670        , 660 , 650        , 641 , 632        , 622 ,
    613        , 604 , 596        , 587 , 578        , 570 , 562        , 553 , 545        , 537 ,
    529        , 522 , 514        , 506 , 499        , 492 , 484        , 477 , 470        , 463 ,
    456        , 450
INT16U AD_Value_To_Temperature(INT16U AD_Value)
    INT16U head, mid, tail;
    INT32U Temp=0;
    if((AD_Value<=2364)&&(AD_Value>450))  //正值  0-70
    {//在检测范围内
        head=40;
        tail=181;
        while(head<tail)
            if((tail-head)!=1)
            {//尚未在两个相邻范围内
                mid=(head+tail)/2;
                if(AD_Value==AD_temp_data[mid])
                {//AD刚好在边界点上
                    Temp = (mid-40)*10/2;
                    break;
                else if(AD_Value<AD_temp_data[mid])
                    head=mid;
                else if(AD_Value>AD_temp_data[mid])
                    tail=mid;
                if(AD_Value<AD_temp_data[mid])   //倍率为10
                    Temp = (head-40)*10/2;
                    Temp += ((AD_temp_data[head] -AD_Value)*5)/(AD_temp_data[head]-AD_temp_data[mid]);    //????
                    Temp += ((AD_temp_data[mid] -AD_Value)*5)/(AD_temp_data[mid]-AD_temp_data[tail]);
                break;
    else if((AD_Value<=2989)&&(AD_Value>2364))  //负值
        head=0;
        tail=39;
        while(head<tail)
            if((tail-head)!=1)
            {//尚未在两个相邻范围内
                mid=(head+tail)/2;
                {//AD刚好在边界点上
                    Temp = 200-(5*mid);
                    break;
                else if(AD_Value > AD_temp_data[mid])
                    tail=mid;
                else if(AD_Value < AD_temp_data[mid])
                    head=mid;
                if(AD_Value < AD_temp_data[mid])   //倍率为10   1度的偏移
                    Temp = 200-(5*mid);
                    Temp -= ((AD_temp_data[mid] - AD_Value)*5)/(AD_temp_data[mid] - AD_temp_data[tail]);
                    Temp += 10;
                    Temp = 200-(5*head);
                    Temp -= ((AD_temp_data[head] -AD_Value)*5)/(AD_temp_data[head]-AD_temp_data[mid]);
                    Temp +=10;
                //取补码加1
                Temp =(~Temp);
                Temp +=1;
                break;
    return (Temp&0xFFFF);
ID:808485 发表于 2021-6-25 17:50 | 只看该作者
我觉得你说的对
ID:718725 发表于 2021-6-27 14:33 | 只看该作者
做温度检测不错的
ID:602776 发表于 2021-6-28 15:41 | 只看该作者
这个程序还是有问题,刚才本人调试了一下,会出现AD_temp_data[head]等于AD_temp_data[mid]情况,但是程序没有跑死
