查看: 2893|回复: 5
这个单片机程序 为什么lcd不显示呀,求大佬解密
#include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rs=P2^6;
sbit rw=P2^5;
sbit e=P2^7;
sbit beep=P3^7;
sbit dq=P3^6;
sbit led=P3^1;
sbit k1=P3^2;
sbit k2=P3^4;
sbit k3=P3^5;
sbit k4=P3^3;
uint8 num[]="0123456789.C";
uint8 d1[8]="Temper: ";
uint8 d2[2]="H:";
uint8 d3[2]="L:";
uint8 tm[5],tm1[5],tm2[5];
uint8 a,c,temp;
float dio;
uint16 k;
uint8 mode,sheding=0;
char wenduh=40,wendul=20;
void delay(uint16 i)
    while(i--);
void int0init()
    EA=1;
    EX0=1;
    IT0=1;
void int1init()
    EA=1;
    EX1=1;
    IT1=1;
void wrc(uint8 c)
    delay(1000);
    rs=0;
    rw=0;
    e=0;
    P0=c;
    e=1;
    delay(10);
    e=0;
void wrd(uint8 dat)
    delay(1000);
    rs=1;
    rw=0;
    e=0;
    P0=dat;
    e=1;
    delay(10);
    e=0;
    rs=0;
void init()
    delay(1000);
    wrc(0x38);
    wrc(0x38);
    wrc(0x38);
    wrc(0x06);
    wrc(0x0c);
    wrc(0x01);
//DS18B20?ì2a??
void ds18b20init()
    dq=1;
    delay(1);
    dq=0;
    delay(80);
    dq=1;
    delay(5);
    dq=0;
    delay(20);
    dq=1;
    delay(35);
void ds18b20wr(uint8 dat)
    uint8 i;
    for(i=0;i<8;i++)
        dq=0;
        dq=dat&0x01;
        dat>>=1;
        delay(8);
        dq=1;
        delay(1);
uint8 ds18b20rd()
    uint8 value,i;
    for(i=0;i<8;i++)
        dq=0;
        value>>=1;
        dq=1;
        if(dq==1)value|=0x80;
        delay(8);
    return value;
uint8 readtemp()
        uint8 b;
        ds18b20init();
        ds18b20wr(0xcc);
        ds18b20wr(0x44);
        delay(100);
        ds18b20init();
        ds18b20wr(0xcc);
        ds18b20wr(0xbe);
        a=ds18b20rd();
        b=ds18b20rd();
        b<<=4;
        c=b&0x80;
        b+=(a&0xf0)>>4;
        a=a&0x0f;
        return b;
void time0init()
    TMOD=0x01;
    TH0=0xfc;
    TL0=0x18;
    TR0=1;
    EA=1;
    ET0=1;
void sound()
    uint8 i=100;
    while(i--)
        beep=~beep;
        delay(100);
void datapros()
    dio=a*0.0625;
    k=dio*10000;
    wrc(0x08+0x80);
    if(c==0x80)
        wrd('-');
        temp=temp-1;
        temp=(~temp);
        wrd('+');
        temp=(temp);
    tm[0]=num[temp/100];
    tm[1]=num[temp%100/10];
    tm[2]=num[temp%100%10];
    tm[3]=num[10];
    tm[4]=num[k/1000];
    tm[5]=num[11];
    tm1[0]=num[wenduh/100];
    tm1[1]=num[wenduh%100/10];
    tm1[2]=num[wenduh%100%10];
    tm2[0]=num[wendul/100];
    tm2[1]=num[wendul%100/10];
    tm2[2]=num[wendul%100%10];
void display()
    uint8 i;
    wrc(0x80);
    for(i=0;i<8;i++)
        wrd(d1[ i]);
    wrc(0x09+0x80);
    for(i=0;i<6;i++)
        wrd(tm[ i]);
    wrc(0x80+0x40);
    for(i=0;i<2;i++)
        wrd(d2[ i]);
    for(i=0;i<3;i++)
        wrd(tm1[ i]);
    wrc(0x80+0x49);
    for(i=0;i<2;i++)
        wrd(d3[ i]);
    for(i=0;i<3;i++)
        wrd(tm2[ i]);
void keypros()
    if(mode==1)
        if(k2==0)
            delay(1000);
            if(k2==0)
                wenduh++;
                if(wenduh>=120)wenduh=120;
        if(k3==0)
            delay(1000);
            if(k3==0)
                wenduh--;
                if(wenduh<=0)wenduh=0;
    if(mode==2)
        if(k2==0)
            delay(1000);
            if(k2==0)
                wendul++;
                if(wendul>=120)wendul=120;
        if(k3==0)
            delay(1000);
            if(k3==0)
                wendul--;
                if(wendul<=0)wendul=0;
void data_change()
    if(temp>=wenduh&&sheding==1)
        led=1;
        sound();
    if(temp<wendul&&sheding==1)
        led=0;
    init();
    int0init();
    int1init();
    time0init();
    led=0;
        temp=readtemp();
        keypros();
        datapros();
        display();
        data_change();
void int0() interrupt 0
        delay(1000);
        mode++;
        sheding=0;
        if(mode==3)
            mode=1;
void int1() interrupt 2
    delay(1000);
    mode=0;
    sheding=1;
ID:584814 发表于 2021-7-8 08:29 | 只看该作者
可能情况:
1、软件方面:程序写法有错;
2、硬件方面:设计或连接有错;
3、自己问题:使用盗版软件去仿真又不会按实际调整....
建议:本坛内找个能用的就好。
ID:748788 发表于 2021-7-8 11:08 | 只看该作者
一步步来,先调试好1602,使其能正常显示。
ID:539024 发表于 2021-7-8 11:43 | 只看该作者
接线跟实物不一样,
sbit rs=P2^6;
sbit rw=P2^5;
sbit e=P2^7;
在protues里面按照这样接线,或者你也可以把程序改了。
总之仿真要跟实物对应
ID:914633 发表于 2021-7-8 20:41 | 只看该作者
电源和地都没连
ID:885725 发表于 2021-7-9 08:28 | 只看该作者
和你的想法一样。
