查看: 2447|回复: 0
关于1602A显示和按键控制成果 附单片机程序
通过按键控制3个继电器开关,并在1602A液晶显示屏上显示
#include<reg52.h>
sbit E=P3^4;  //1602使能引脚
sbit RW=P3^6; //1602读写引脚
sbit RS=P3^5; //1602数据/命令选择引脚
sbit key_s2 = P3^0;//独立按键S2
sbit key_s3 = P3^1;//独立按键S3
sbit key_s4 = P3^2;//独立按键S4
sbit key_s5 = P3^3;//独立按键S5
sbit M1= P1^0;
sbit M2= P1^1;
sbit M3= P1^2;
sbit beep= P2^3;
uchar j;
uchar flag;//定义标志位
uchar code tab1[]="welcome to you  ";  //要显示什么就在这儿改
uchar code tab2[]="enter       exit";  //要显示什么就在这儿改
uchar code tabhang1[]="motor: M1 M2 M3 "; //要显示什么就在这儿改
uchar code tab00[]="enter 000   exit";
uchar code tab01[]="enter 001   exit";
uchar code tab02[]="enter 010   exit";
uchar code tab03[]="enter 011   exit";
uchar code tab04[]="enter 100   exit";
uchar code tab05[]="enter 101   exit";
uchar code tab06[]="enter 110   exit";
uchar code tab07[]="enter 111   exit";
void delay(uint del)   //延时1ms
uint i,j;
for(i=0;i<del;i++)
   for(j=0;j<=168;j++);
void writecmd(uchar com)  //写指令
E=0;
RS=0;
RW=0;
P0=com;
delay(2);
E=1;
delay(2);
E=0;
void writedata(uchar dat)//写数据
  E=0;
  RS=1;
  RW=0;
  P0=dat;
  delay(2);
  E=1;
  delay(2);
  E=0;
void kaiji()                //开机主页
                        writecmd(0x80);    //告诉液晶在哪个地方显示 (设置地址指针)//80H+00
                                  for(j=0;j<16;j++)  //有16个字符,要循环16次
                                           writedata(tab1[j]);
                                             delay(2);
                                   writecmd(0x80+0x40); //再设置第二行的起始位置80H+40H
        { writedata(tab2[j]);
        delay(2);
void delay1(uint z)        //延时子函数
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void init(void)               //初始化
delay(15);
writecmd(0x38);
delay(5);
writecmd(0x38);
delay(5);
writecmd(0x38);
writecmd(0x38);
writecmd(0x08);
writecmd(0x01);
writecmd(0x06);
writecmd(0x0c);
M1=0;
M2=0;
M3=0;
kaiji();
void moshi0()
                   writedata(tabhang1[j]);
                     delay(2);
                writedata(tab00[j]);
                                delay(2);
        if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                M1=0;
                                M2=0;
                                M3=0;
                                while(!key_s2);//松手检测
void moshi1()
                     delay(2);
                writedata(tab01[j]);
                                delay(2);
        if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                M1=0;
                                M2=0;
                                M3=1;
if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
                                while(!key_s5);//松手检测
void moshi2()
                                             delay(2);
        { writedata(tab02[j]);
        delay(2);
if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                M1=0;
                                M2=1;
                                M3=0;
if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void moshi3()
                     delay(2);
                writedata(tab03[j]);
                                delay(2);
        if(key_s2==0)
                delay1(10);
                if(key_s2 == 0)
                                M1=0;
                                M2=1;
                                M3=1;
        if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void moshi4()
                     delay(2);
                writedata(tab04[j]);
                                delay(2);
        if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                M1=1;
                                M2=0;
                                M3=0;
        if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void moshi5()
                     delay(2);
                writedata(tab05[j]);
                                delay(2);
        if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                M1=1;
                                M2=0;
                                M3=1;
        if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void moshi6()
                     delay(2);
                writedata(tab06[j]);
                                delay(2);
        if(key_s2==0)
                delay1(10);
                if(key_s2 == 0)
                                M1=1;
                                M2=1;
                                M3=0;
        if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void moshi7()
                     delay(2);
                writedata(tab07[j]);
                                delay(2);
        if(key_s2==0)
                delay1(10);
                if(key_s2 == 0)
                                M1=1;
                                M2=1;
                                M3=1;
        if(key_s5==0)
        {        delay1(10);
                if(key_s5== 0)
                                M1=0;
                                M2=0;
                                M3=0;
void keyscan()
        if(key_s2==0)
        {        delay1(10);
                if(key_s2 == 0)
                                 moshi0();
        if(key_s4==0)
        {        delay1(10);
                if(key_s4 == 0)
                                flag++;
                                if(flag==9)
                                flag=1;
                                while(!key_s4);//松手检测
        if(key_s3==0)
        {        delay1(10);
                if(key_s3 == 0)
                                flag--;
                                if(flag==0)
                                flag=8;
                                while(!key_s3);//松手检测
        init();
                keyscan();
                delay(20);
                switch(flag)
                                     case 1: moshi0(); break;
                                     case 2: moshi1(); break;
                                     case 3: moshi2(); break;
                                     case 4: moshi3(); break;
                                     case 5: moshi4(); break;
                                    case 6: moshi5(); break;
                                      case 7: moshi6(); break;
                               case 8: moshi7(); break;
                                      default:break;
参与人数 2黑币 +50 收起 理由
杨雪飞 + 10 共享资料的黑币奖励!
admin + 40 共享资料的黑币奖励!
收藏收藏3 分享淘帖 顶顶 踩踩
